Question about Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television
Sony kdf50e 2000- green power light turns red what to do
When turning on the tv, the green power light comes on for a few seconds then turns red and screen does not appear. Just had a new lamp installed 2 days ago. Whats up
  • 4 more comments
  • arkbenz Feb 12, 2009
    ok just went to ck.. red light blinks 3 times then there is a pause of 5-6 seconds, then blinks again 3 times. Tv was working fine earlier. its storming here, but other tv is working fine
    tv is now powered on , and red light is doing what I mentioned above, blinking 3 times, pause blinking 3 times. please help, just kicked out money fw days ago for lamp repair
    called sony. pulled up manual- states lamp door or lamp is not replaced properly lights will blink 3 times.. thanks
  • Anonymous Feb 15, 2009
    my red light blinks 5 times...i tried removing and replacing lamp cover but no good....tv will not turn on
  • arkbenz Feb 20, 2009
    My tv is actually good to go now. a few times after I posted the comment the tv wd go back out, but we tightened the cover, and its now good to go :{
  • jrcarpenter4 May 11, 2010
    kdf-55wf655 red lite flashes6 times
  • 10,594 Answers
Does red light blink? if yes, please count blinks as there would be pause of 3 seconds between blinks and let me know to help you out.
Posted on Feb 12, 2009
  • Shahid Electronics
    Shahid Electronics Feb 12, 2009
    Thats correc, 3 times blink shows that Lamp Cover is not attached properly.
    Please remove lamp cover and make sure to fix it properly, well seated in its place and tight screw. There is a safety switch under lamp cover that should be pressed when lamp cover is closed.
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Tv won't turn on
I had to same problem. It is mostly an internal board problem and you may need to service the TV or buy another one.
Mar 20, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
413 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
