Question about Motorola Mobility KRZR K1m Cellular Phone
Cant get my phone to hook up to the computer
When i first put the usb in the computer it asked me for disc, which i put in and right after i did that the computer then said that it could not install the software. i dont know what to do!! anybody help???
  • 1,800 Answers
Maybe the Disc is damaged.
u can download the software from
download section.
Posted on Feb 12, 2009
Cant put music on my phone ugh
Try the following:
1. Attach your USB cable to the Phone and Computer.
2. Navigate your computer, to find the phone. It generally appears as a USB stick or Ext HD would.
3. Within your Phone there will be several folders. One will say music.
4. You can copy music (MP3 format) to and from your phone this way.
I hope this helps. Regards,
Feb 24, 2010 | Samsung Hue (SCH-r500) Cellular Phone
Verbatim 4gb flash cant be recognised
1. Download this tool:
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 02, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
My g1 wont install on vista?
ok people i have solved the problem with the g1 not recognizing being hooked up to the computer. the usb cords that are sent with the g1 are very crappy. use another usb mini to connect to your computer. theres no installation required just hook it up and select mount and open up my computer and go to removable disk to access you files.
Dec 30, 2008 | HTC G1
Can not connect printer to acer aspire one ZG5 Any advice would be great, Im trying to hook i up using a USB cable. Computer is not even recognizing that i have plugged in a usb cable
Well it all depends on what type of printer it is. Most printing companies don't give a disc with their printer. Mainly because they are supposed to install automatically when plugged in. If your computer asks for a disc, maybe it needs one to install the printer. try contacting the company who mad the printer. You never know if they forgot to put the disc in when they packed it. If that is the case, they probably will be more than happy to give you another disc.
Hope this helps!
Dec 13, 2008 | Computers & Internet
Sad to say but every data cable needs a disc installer, I also thought that it is possible to use a datacable without an installer it but it is impossible. Yes u can use it...only to charge your phone unit but not to transfer data and files from your computer.
The only thing to use your datacable is having an installer or buying a new datacable, an installer is along with it.
But for better transfer without an installer (disc) needed.
Use a Bluetooth USB Dongle.
A rate for this solution will be much appreciated, thank you!
Jul 23, 2008 | Samsung SGH-P310 Cellular Phone
Razr v3xx mp3 player
all right so you purchased the memory sticks and the usb cord so your good to go first thing is the small memory stick needs to go in the phone so to do this remove the back cover of the razor and there should be underneath the battery left to the sim card a slot insert the memory stick in the slot(follow the arrows) attach the cover. next take the larger of the memory stick or the adapter and if computer compatible insert into computer (optional) next take the usb adapter cord insert the large usb side into the computer the other side in to the charge port on the razor. a window should come right up asking ou what to do click view folders now when next window comes up select the folder and drag music into appropriate folder. any further questions or more indepth instructions only for actual help no **** please
Apr 29, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Setting up the internet on my phone
call ur network provider and ask for gprs configuration and they'll send it to you and just save it....this will solve ur problem.. .
Apr 19, 2008 | Sony Ericsson K800i Cellular Phone
Can't download photo's onto computer
Are you connecting your phone as a Mass Storage Device?
  1. From the home screen, attach one end of the Motorola Original Enhanced USB cable to your phone and the other end to a USB port on your computer.
  2. On your phone, press Yes to use the phone as a portable USB storage device.
    Note: When connected as a storage device the phone cannot perform regular phone activities. Disconnect to resume normal operation.
  3. On the PC, open the My Computer window and find where your phone displays as a Mass Storage icon.
    Double click the Mass Storage Device icon.
  4. Drag and drop files between your computer and phone.
  5. When finished, remove the phone safely from your computer. Right click the "Safely Remove Hardware"
    icon at the bottom of your computer screen, then select "USB Mass Storage Device" and click Stop.
  6. Select USB Mass Storage Device and click OK.
    Now it is safe to disconnect the cable. When the cable is disconnected, the phone restarts
Jan 02, 2008 | Motorola Mobility W375 Cellular Phone
LG Shine
The software it comes with doesn't do anything for music. When you hook it up to the USB it should go into mass storage mode. Then you just drag and drop music files over. The only problem I'm having is figuring out which folder to put music in since there are 2 menus for sounds/music on the phone. And when you plug the phone in, it brings up 2 drives. One for the internal phone memory and one for the external memory card.
Dec 14, 2007 | LG Shine KE970 Cellular Phone
Motorola Mobility KRZR K1m Cellular Phone Logo
60 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
