Question about Kenmore Oasis HE 27082 Top Load Washer
Fabric softner dispenser not draining
My washer will not drain the fabric dispenser does anybody know what seems to be the problem and if there is anything i can do?
  • Anonymous Mar 30, 2014
    fabric dispenser will not drain.
  • 547 Answers
Run on differnt cycle
Posted on Feb 12, 2009
Whirlpool washer wtw6800 fabric softener dispenser drains out before cycle
You can remove and wash the fabric softner dispenser drawer . It can also be adjusted on top of the dispenser
Oct 04, 2017 | Whirlpool Washing Machines
The fabric softner tray isn't draining
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Feb 21, 2011 | Frigidaire GLTF1240A Front Load Washer
FABRIC SOFTNER DISPENSER NOT DRAINING
you can try putting a dishwashing tablet in it with some hot water and let it sit overnight ...the tablet has something in it made to desolve build up for water ,soap,ect...and it safe to the washer and to you too.I used one in my water drain on a water in the door ice box worked like a charm.
Dec 03, 2009 | Kenmore Washing Machines
Fabric Softner
that is normal you can either add water to make it drain or pull out the drawer and dump it.
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water collects in the fabric softner dispenser during in the washing and doesn't drain. We have to pour it out vbefroe washing the next load.
Take the dispenser out the washer and clean it very good.
Pull the caps off and make sure no fabric softner is hanging around the hole. The unit uses a siphon effect to drain the compartments.
It's normal to have some water left over tho. Just not full of water.
Sep 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Nov 25, 2008 | LG WM-2277HW Front Load Washer
Fabric softener dispenser is filled with water
I had this same problem. I found a repair manual online and found out how to get into Service Test Mode. There is a test (t12) for the dispenser motor/mechanise. Running this test basically just runs water through each of the dispenser compartments (prewash, wash, bleach, fabric softner). All ran fine - no error codes. I continued to run the test on the fabric softner dispenser repeatedly and after 5-10 cycles it started draining properly. I think a tube (or valve or opening) was just clogged with the built up softner. I also put some vinegar in the compartment a time or two just to clean out any residue. Be careful with the Service Test Mode - read directions carefully - the manual warns that if you don't get out of it corretly that it can lock up you washer.
Jun 18, 2008 | GE WBVH6240F Front Load Washer
Softner will not dispense
not draining from compartment is usually caused by a blockage it compartmnet, try pooring boiling water into the compartment, this will usually resolve problem
Dec 08, 2007 | Maytag Neptune MAH5500B Front Load Washer
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
77 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
