Question about Samsung SF-5100 Plain Paper Laser Fax
Can't receive fax but can send fax
Toner empty message comes on in the middle of a fax transmission. When empty toner cartridge replaced with a new one, the "toner empty" and "memory received" message still remains on the LCD display. Can't receive fax as machine won't register the new toner cartridge.
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Posted on Mar 07, 2009
The printer samsung scx-452f cannot print out fax in,it shown on screen as memory receive
you have received faxes, but they can't be print until you replace toner because probably you have TONER EMPTY message also on the display.
You can buy only fuse for toner cartridge (25mm, 250V/ 0,063A or 0,1A and maximum 0,125A)
When you pull out toner cartridge you will see the glass fuse on the front left side of the cartridge.
The new fuse will reset toner empty condition
pifonski
Feb 28, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Cant send faxes
It sounds like the faxes memory is full, either from receiving or transmitting faxes, try turning it off and on again, the fax might just need to recognize you have installed a net toner cartridge.
Oct 16, 2009 | Office Equipment & Supplies
Toner empty message after replacing the toner Ricoh fax2210L
menu # 1934 menu search for new cartridge and then click yes yes ,turn power off and on.
Jun 18, 2009 | Ricoh FAX2210L Plain Paper Laser
Toner Empty
it it was receiving fax before replacing the toner then it still should be able to receive so just turn your printer once off and turn it back then see what happens.
if problem still remains then please post back.
and rate all answers.
Feb 11, 2009 | Lexmark X215 MFP All-In-One Laser Printer
Low toner message
sounds like you have a bent toner sensor. turn the machine off and take the toner out and place on the side
what you could try to do is grab a piece of paper fold it in 4 like so
__ __
|__|__| __
|__|__| then rip one piece like so |__|
then rip one piece off and fold that 5 times over it self.
look into where the toner goes in the middle you will see a silver bracket with a black round piece of plastic on the top left conner you need to put that piece of paper under that coner where the black circle is and turn the machine back on then put the toner in.
if this does not work you need a tech to look at it
Dec 04, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF560 Message reads "toner empty". Replaced new toner cartidges and still get same message. have change toner in fax but getting message (jam 1) or toner empty it seems pretty common problem as...
Turn off the Machine for safety.
- Try to double check if the toner cartridge is properly installed
- Clean it also if dusty
- Make sure he sensor have no paper or dust.
Apr 15, 2008 | Samsung SF-560 Plain Paper Laser Fax
GestetnerDsm516pf
I'm surprised you're trying to make a buck off this kind of stuff. Instead of being part of the solution you're part of the problem. Easy one .....get the service manual. Mfg has rigged it so you must buy New cartridge unless you can discover the key to reset counters.
Thanks
Mar 26, 2008 | Gestetner Office Equipment & Supplies
Ready Memory Received
Dear guys, your toner cartridge is low and as a preventive measure, the unit stores the faxes in order to give priority to copying and printing. If you are using remanufactured cartridges, the unit might not be displaying the low toner warning.
Jan 24, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Toner Cartridge reading has empty but have replaced toner
Try to see in the software if there is any reset option for the toner.
Nov 06, 2007 | Ricoh FAX2500L Plain Paper Laser
Samsung SF-5100 Plain Paper Laser Fax Logo
350 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
