Question about Motorola Mobility H700 Wireless Headset
No voice dialing
The manual says for voice dialing Press and hold button. When I try that all it does is beep once and nothing else. So is the H700 truly able to work with voice dialing?
  • 88 Answers
Hi when you press and hold the button you redial the last call, and when you press just once quickly this button your phone pass in voice call( if your phone has this function...lol) and don't forget to activate the function voice call in your cell phone.
hope this helps you
sserpentio
Posted on Feb 12, 2009
H700 now only dials last number called
On mine, if I wait for it to be fully connected with the phone, then press the button one time, the blackberry ask for the correct voice command. However, if I press the button twice, it will dial the last number called.
Aug 02, 2009 | Motorola Mobility H700 Wireless Headset
Where can i get an online Manual for a Voice Star VS700 Bluetooth
Hold the power button down, once it beeps, keep holding down the power button but push in the volume up button, once it beeps let go of the volume up button and while still holding the power button push in the volume down button. the pass code is "0000".
Dec 11, 2008 | Radio Communications
Cannot Voice Dial from Bluetooth H700, Address book won't transfer
May not be the best one, but I just removed my battery and put it right back in and it works again.
Oct 17, 2008 | RIM BlackBerry Curve 8310 Smartphone
Will not voice activate
Does your Treo 700W support "voice dialing"? I searched the whole user guide for the Treo 700W and it does not say anything about dialing by voice. If the phone does not support it than no matter what Blue Tooth unit you use you will not be able to voice dial.
Jun 02, 2008 | Motorola Mobility H700 Wireless Headset
H700 won't play music thru bluetooth
Pushing in the button (I don't know what you mean by "the middle button" when there is only one button on the H700) it starts the voice dial feature. It will listen for a second and then tell you with a beep that it did not recognize the name. That is your cue to try again. When it does not recognize it again in a couple of seconds ti shut off. The H700 was not designed to use to listen to music on your phone with. If you want to do that you need to purchase something like the Motorokr Blue Tooth unit.
May 19, 2008 | Motorola Mobility H700 Wireless Headset
H700 will pair, but won't connect.
To successfully pair the Motorola 700 with the Centro:
Select Bluetooth from the Home screen.
Select "On".
Under "Visibility", select "Visible".
Now click "Setup Devices".
Click "Hands-free Setup"
On the Motorola earpiece, with the flip-out mouthpiece in the closed position, press and hold the multi button until ring around it glows purple. Flip open the mouthpiece.
Now click "Next" on the Centro's screen.
The Centro should find the Motorola. Hold the Motorola to the right side of the phone if you have difficulty getting the Centro to find it.
Once found, click the Motorola H700 listed in the window and click "OK".
The Centro will ask for the device password. Enter 0000. Be sure that the checkbox for "Add to trusted device list" is checked. Click OK.
The two devices should now be paired to work together and the Motorola's multi button should rapidly blink blue; NOW click "Done".
You will be taken to the Trusted Devices screen.
You will see your Motorola in the list of Trusted Devices. Click on it to highlight it, if it is not already highlighted.
Click the menu drop-down key (located to the right of the ALT key).
You will now see a drop-down at the top of the screen that says "Connect". Click the "palm" center button on your Centro.
NOW the two devices are connected. The phone name will now be bold, and a small Bluetooth icon will appear to the right of it.
When you click the Phone key on your Centro, you will see a tiny blue headphone symbol now at the top right of the screen where the Bluetooth icon used to be.
To use the earpiece:
Flip it open and hang it on your ear.
Dial the number you want to call on the phone.
Press the multi button once and now you should be connected via the earpiece.
To receive a call, when your Centro rings, press the multi button once.
It took me a few hours to figure it out. Hopefully you can do it in a few seconds.
Dec 28, 2007 | Motorola Mobility H700 Wireless Headset
Connection failed
I have a similar problem with my blackberry curve, it connects but when I hit the key on earpiece for voice dial, the blackberry says setting up, or something like that, and it never connects all the way, just keeps trying, i can dial a call through my phone and then i do hear and can be heard with earpiece, just no voice dialing options??
Oct 10, 2007 | Motorola Mobility H700 Wireless Headset
Tried unmuting the headset
voice dial work throught your phone.unmuting the headset is it at the phone not at the headset.
Jun 21, 2007 | Motorola Mobility H700 Wireless Headset
Voice Dialing Issues
I am sad to say that the voice recognition failure is permanent on most of the E815 phones. Your phone will likely never support voice dialing again, even though the cause remains unknown.
I too had the peculiar problem of pressing the voice button and hearing a beep, but no voice prompt ("Say a command"). When I researched the issue, I found a plethera of similar problem reports. Very few reported recovery after simply restarting the phone. I even found one report of Motorola tech support giving up and instructing the owner of the phone to have it replaced.
Feb 14, 2007 | Motorola Mobility E815
Motorola Mobility H700 Wireless Headset Logo
138 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
