Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Dishwasher wont start, light are flashing
Dishwasher will not start, none of the buttons do anything when you press them, and the lights on the front of the machine are flashing.
  • 2 more comments
  • mposner2 Feb 13, 2009
    That didnt work. Nothing happened at all the exact problem still exists. I also tried resetting the power by switching the breaker but had no luck with that. Any other help?
  • derbyguy69 Feb 23, 2009
    My problem is very similar - however
    The light on the front display says "LO" after it completes the dishwash cycle.
    But no matter what I do at this point, push click it will not reset so I can run another cycle. Just sits stuck on "LO"
    I have to go flip the breaker in the garage, give it a sec then it allows me to reset after the flashing lights.
  • jsmittygirl Mar 31, 2009
    I have a Frigidaire PLD4375RFC1 Professional Series Dishwasher.  All the lights on the display are flashing and it will not clear or turn on.  We tried flipping the circut breaker to reset and that didn't work.
  • Anonymous May 23, 2009
    lights on front are flashing, but none of the buttons work.
    President:
  • 1,314 Answers
Should indicate that a power failure has occurred try pushing start cancel then reset options and re start
Posted on Feb 12, 2009
  • 1 more comment
  • robert samples Feb 13, 2009
    were not done yet get with you later
  • robert samples Feb 14, 2009
    take the bottom kickplate off should be a troubleshooting sheet there if not send me an email at b4829@yahoo.com will send you one
  • ke chan Jan 30, 2013
    what are the reset options/reset? This happened last year and i believe I had to hit the light wash and start button about 7 times. however i can't recall for the life of me what i need to do. i reset the circuit braker and nothing. i know it needs reset,but can't find how to reset it.
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Dishwasher won' t start. None of the lights are coming on
dishwasher wont start. none of the lights are coming on.
Nov 09, 2012 | Jenn-Air 24 in. JDB1080AWS Built-in...
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
Clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
2,456 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
