Question about Microtek ScanMaker 9800XL Flatbed Scanner
Lines across scan
With every scan there are faint horizontal lines appearing on the scan. The overall effect is that each line appears as a combination of a red and green line. The red line is directly above the green line. The lines appear randomly throughout the image. Has anyone ever had this problem and know how to solve this?
  • 490 Answers
It appears to be a freak problem. The best way is to bring it to original condition. Try uninstalling the scanner, run Scandisk on the Comp, Switch off and reinstall the driver. this may work.
S. Mohan
Posted on Feb 13, 2009
Two horizontal lines appeared near bottom of screen
You can spend $300 to $500 fixing this or just do the best thing most cost effective thing and replace the TV.
Aug 23, 2016 | Sharp Aquos Televison & Video
Despite inserting new black cartridge (Brother LC57 BK), print is faint and on spreadsheets is blurred and has horizontal lines across pictures.
Hi
If a single inkjet in your printer is not functioning then output will appear as a horizontal line across the page. If one of the jets is on all of the time then output will have black or colored lines across the page. Use the following steps to isolate the problem: - Replace the ink cartridge - Check the flexible cabling for continuity and for short circuits between adjacent conductors - Exchange the control board for a good one - Finally check the power supply
Good Luck
Mar 09, 2011 | Brother MFC 210C All-In-One InkJet Printer
Very horizontal faint white lines running down the screen
hi,
check if the line appears in BIOS...dont worry when i say BIOS...not sure how to check...turn the system off...restart the system and keep tapping the F2 key...you would get a Blue screen...check if the lines appear on this screen...if it appears...it could either be b'cause the display driver has gone wrong or the system might have a physical damage.....if the lines does not occur on this screen....it is a manufacturing defect...please contact the manufacturer and report the issue for solution.......
regards
Rocky
Jan 12, 2010 | Acer AL1717 17" LCD Monitor
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Microtek ScanMaker 9800XL Flatbed Scanner Logo
944 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Tony
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
