Question about Brother HL 1450 Laser Printer
Brother printer Drum problem
After changing the printer cartridge also showing the drum problem. I am having a pick-up roller or drum problem. The rollers aren't picking-up the paper.
  • 62 Answers
Several things to check, the P/U roller is warn down, could be the paper sensor or the paper in the tray is set too tight
Posted on Feb 12, 2009
Why does my Brother MFC-7360n Does Not Pick up paper?
Leave the machine and attend to it at a later time repeating all you initially did.
Aug 28, 2014 | Brother MFC 7360N - Multifunction fax /...
My printer show me drum error problem i change the drum of my printer of brother MFC-7320 but i face same problem.
It looks like that you printer is old one. Please take out the cartridges & clean the space, roller with a soft dry cloth. After that install the cartridges back in place & power on, do the allignment & take a test print
Apr 04, 2011 | Brother MFC 7420 All-In-One Laser Printer
Laser head and paper rolers need cleaning geting speckles. Have drum out but how do i get it them and what is best to clean them with
Spots on the laser glass would show up as white vertical stripes in your print.
The drum unit has a soft plastic blade inside it to constantly clean the drum as it turns. Sometimes a clump of toner gets caught under the blade, but that usually shows up as a narrow band of spotty or gray stuff down the page. The clump may carve a groove in the drum, too. The cure is to replace the drum unit, unless it's new, in which case the cure is to make the store replace the drum unit.
In the back of the printer is the fuser, which runs the paper between hot rollers to bake the powder into the paper. The rollers are coated with Teflon or similar stuff, to prevent picking up toner and laying it back down further down the page. With age & use, the coating fails, and spots appear. Look for a pattern that repeats every 3 inches or so as the roller comes around.
Brothers are also prone to spot due to a bad toner cartridge. Take the toner cartridge out of the drum cartridge, hold it over a sheet of paper or two, and try to shake toner out of it. A little toner spill is normal, but if you get a pile under one end, a seal has gone bad in the cartridge. You need a new toner ctg.
Every manufacturer wants you to spend your money on their own supplies, of course, but in the case of Brother laser printers & faxes, refilled toner cartridges can sometimes break your machine. At the end of the cartridge is a wheel that stirs the toner inside; it's engaged by a thing in the machine that comes out as you close the toner door. Brother uses toner with smooth, round particles in their cartridges. Some refillers use toner that's just as fine, but ground to rough shapes. It resists stirring enough to sometimes break the gear inside the machine, making for an expensive repair. That's not your problem here, but you should consider that if you're headed to the store for new toner.
Oct 22, 2010 | Brother HL-2040 Laser Printer
I get a line in the print how do i fix it
Lines on the page is usually due to debris or scratches on the laser drum or fuser roller. These are situated within your toner refill cartridge. Check these rollers by removing the cartridge and pulling back the flap which conceals the rollers. Take note that the drum is sensitive to light & should not be exposed to light for prolonged periods. Check that there are no marks or scratches on the drum or fuser roller. Whipe off marks on the drum with a soft cloth or if there are scratches, replace the whole cartridge unit.
Best wishes,
Graemevm
Aug 02, 2010 | Brother HL-4050CDN Printer
I have changed cartridge and drum in the printer
If the cartridge has irregularities on it you will get poor results. The large black roller should be smooth all the way around. Any bumps will cause lines and spots. It is not recommended but I have had luck cleaning that large black roller. Once smooth the lines went away.
May 18, 2010 | Brother MFC 7420 All-In-One Laser Printer
My all-in-one printer keeps telling me that I need to change the drum soon. I bought a new drum inserted it into the printer and now I can't print anything. Plus, it is still telling me that I need to...
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Note
    Brother strongly recommends that customers do not use generic drum units and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brother limited warranty does not apply to any problem that is caused by the use of unauthorized third party drum units, toner cartridges or toner.
    If you are using a genuine Brother drum and toner and after following this procedure the unit continues to show "CHANGE DRUM SOON", your machine may require service. Please contact the Customer Service Center.
May 01, 2010 | Brother MFC 7420 All-In-One Laser Printer
Our printer makes three dark marks on left side of printer. We have replaced the roller once and we still have the three dark marks on left. it is getting worse every day
Did you replace the toner cartridge or the imagine drum? My bet is you have only change the toner cartridge. The drum unit will require changing from time to time as well. It is likely that drum is worn out in that spot.
Mar 23, 2010 | Brother MFC-8460N All-In-One Printer
Printed sheets come out with blackish/greyish lines on the right side
Use follow these cleaning steps for your printer:
1. Open the front cover of the printer and remove the drum/toner unit.
2. Gently wipe the scanner window with a soft dry cloth. The scanner
window is located on the roof of the inside of the printer.
3. On the top of the drum unit, locate the blue tab on the left side.
Slide it back and forth across the drum about 30 times.
4. Remove the toner cartridge (TN430 or TN460) from the drum unit
(DR400). To remove the toner from the drum: hold down the blue lever on the right side of the drum (DR400) and lift the toner (TN430 or TN460) off of the drum unit.
5. Inside the drum unit (DR400) there is a green roller. Wipe the green
drum roller with a dry tissue (i.e. Kleenex). You may turn this roller
by moving the gears on the far left side.
6. If the pages area gray pages or have gray vertical lines, install a
brand new toner cartridge. If pages have dots, spots, smudges or
horizontal lines, install a brand new drum unit.
OR
If you are still experiencing gray pages or gray vertical lines,
please install a brand new toner cartridge (TN430 or TN460).
Brother strongly recommends that customers do not use generic drum unitsand/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability.
The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | Brother HL 1230 Laser Printer
Printer ghosting(?) after replacing toner cartridge/drum assembly
helo braxtol! tell me, are you using brother oem toner and drum or are you using a generic brand. you could also have a bad power supply. this is what charges the drum and toner. good luck brother tech
Jan 31, 2009 | Brother MFC 7420 All-In-One Laser Printer
Drum replacement but not printing
Your almost there. Now you need to replace the 'Transfer Roller'. The transfer roller transfers the image from the drum onto the paper. If this roller is worn out all you'll get is blank pages printing out. Ray CompuGuy44
Jun 20, 2007 | Brother HL 1430 Laser Printer
Brother HL 1450 Laser Printer Logo
238 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
