Question about Alpine IDA-X300 Car CD/ MP3 Player
Subwoofer makes a loud bass machine gun noise when powered up
Hi, I have an alpine ida x-300 stereo in my car with 2 500w subwoofers and a 1200w amplifier in my boot. The system used to work absolutly fine until the last few months. Now when i power up my system the subs make a VERY loud machine gun sort of bass tone for around 2-3 seconds as they power up but then play absolutly fine for hours and hours until i turn off my stereo and turn it back on at where the subs make the noise again. Even when the volume of the stereo is on 0 it is the same loudness as if the volume was on 30. (It is so loud it makes you jump.) The noise is now extremely annoying and even embarrasing when for example in a car park turning on my stereo ready to leave. I have tested all of the connections and they seem fine. I was wondering if installing a capacitor would help :S Could someone please help me! I would really appreciate your suggestions, Thanks.
  • Rakyth May 11, 2010
    Sounds fun :D
    Capacitors turn an alternating current into a smooth, steady current, in fact, this is why LEDs fade out when the device is turned off.
    I'm not an audio guy, but your setup sounds power-consuming. Try getting your battery checked, as the 2-3 seconds of loud could be your battery struggling to keep up with the load :P
    Habit-Forming:
    New Friend:
  • 8 Answers
Are your power wires on the same side as your RCAs? Is so, i would buy a new rca cable and run it on the other side of power wire. For example i have my power wire on passenger side and the rcas and speaker wire in driver side.
Posted on May 23, 2016
Stop terrorizing your community or I'll set your car on fire you selfish *****!
Posted on Mar 02, 2011
Well, I have the same problem and I would think it has something to do with the RCA-connections. If I power up my head unit while I have my main fuse for the amp's removed and then replace the fuse as the head unit is already playing music (thus putting out a current through the RCA-connections) it works just fine. But if I just power up my stereo with the fuse in, my subs go all crazy. I guess it has something to do with disruptions in the rca cable. Maybe they are drawn too close to some power cables or speaker cables? Good luck!
Posted on Apr 14, 2009
  • Conciti Mar 02, 2011
    Stick that stereo bass up your *** you selfish ************!
I lost some settings in the volume menu and sub volume
did you blow a fuse, or did you blow out your speakers.
Jan 30, 2013 | Alpine iDA-X100 Car CD/ MP3 Player
"pop" in speaker when turned up
more likely your deck is just running out of power. another cause is the speaker leads could be hitting the metal of the car with the bass, check for clearance.
May 19, 2010 | Alpine SPS-609 Car Subwoofer
Car subwoofer makes deep bass when i hit the gas.
there could be 2 reasons why, first make sure your power and remote wire is ran down one side of the car, second make sure the rca jacks is on the opposite side of your alternator, make sure they are that way, this will work, if noise is still there, then you may need and inline noise suppressor. but you shouldn't
Feb 20, 2010 | Kicker 05C104 Car Subwoofer
Alpine 9845 cde head unit car stereo i Cannot figure out how to access the Fader not the balance,altho i havent seen that function either. ive been to the alpine site and they dont even mention it. im sure...
Press the Rotary encoder (CDE-9845/CDE-9843
only) or press MODE (CDE-9841 only) repeatedly
to choose the desired mode.
Each press changes the modes as follows:
BASS → TREBLE → SUBWOOFER* → BALANCE → FADER
→ DEFEAT → VOLUME → BASS
BASS: -7 ~ +10
TREBLE: -7 ~ +7
Subwoofer : 0 ~ +15
Balance : L15 ~ R15
Fader : R15 ~ F15
Defeat : ON/OFF
Volume : 0 ~ 35
Feb 11, 2010 | Alpine CDE-9845 CD Player
Subwoofer doesn't play through ipod, only radio and cd's
Hook up the remote wire from the head unit (grey w/ orange stripe) to the power antenna wire (blue) on the wiring harness adapter.
Jan 15, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Alpine MRD-M1005 Subwoofer Amp Problem
He may be right! You might try finding a new source of contact for your ground cause it may not be sufficent enough to ground to, also make sure that no wires from the back of your radio have any wires sticking out touching other interfering things that could possibly be causing the noise
Sep 14, 2008 | Alpine MRD-M1005 Car Audio Amplifier
Bass sounds only
That is tricky one. Did you try adjusting the EQ on both the stereo and the amp? Is the Mute turned on because it will act like that? Is both rca jacks plugged in on stereo and amp?
Aug 20, 2008 | Alpine CDA-9856 CD Player
My subwoofer stops when volume is increased
have u check the radio out do u have an eq
May 19, 2008 | Kicker CVR12 Car Subwoofer
Woofer making horrible noise! HELP!
Think as an expert... Probably from my experience repairing woofers etc... the cone (1) or the spider (2) isn't well glued onto the woofer skeleton(or both???) The woofer cone must be absolutely centered or else you will get those clicks in low frequencies(you also get them in higher frequencies but you can't hear them!) I must say that it is very difficult to repair a woofer by your own. I suggest to return it back where you bought it and take another one (i suppose that you have a guarantee ha?).
Aug 10, 2007 | Alpine SWR-1542D Car Subwoofer
Open Questions:
See all Alpine IDA-X300 Car CD/ MP3 Player Questions
Alpine IDA-X300 Car CD/ MP3 Player Logo
990 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
