Question about Mitsubishi WS-55511 55" Rear Projection Television
How do I re-attach the power switch?
The power switch became loose & fell into the set. How do I access it?
Is there an easy way?
  • lkahan747 Feb 16, 2009
    Great advise. I was able to access the switch through the front grill and replace the little plastic extension to the switch.
    Thank you!
  • albert getty
    albert getty May 11, 2010
    you need to take off back of tv and screw it back in.
  • 43 Answers
Pop the speaker grill off and you will see 3 little screws holding the bottom of the screen to the set. Take those out and lift the screen up and out. Be carefull of the cables holding the control board to the set though. You may have to take the front cover off first to loosen the stress on that cable.
Posted on Feb 12, 2009
Battery door metall batterry connectors fell out
When you can't close the battery door as it should be closed, you can't turn on the camera. In almost all digital cameras there is a protection switch, that prevents the camera to work, with an open battery door, because the camera could stop any moment when the battery comes loose. When the camera was accessing the memory, when it falls without power, the memory can be damaged and you could loose all the pictures saved on the memory card.
I'm afraid, when the battery door came out, some things are missing, like a spring, axel and perhaps some other little metal or plastic things. To come out, some mechanical damage must be there, so it won't be easy to reinstall the door yourself.
Bet thing you can do is show it in a service centre and ask if it can be repaired and what it will cost.
Service manuals, with pictures about all parts, are only sold to approved repair centres.
The only chance to find anything, is on ifixit dot com, because they have manuals and videos of lots of electronic stuff for free.
Repair over there is on your own risk.
Jan 17, 2014 | Samsung SL30/ ES15 Digital Camera
I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
Answer
FRONT DOOR TRIM PANEL
REMOVAL
Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
Disconnect wire connector from courtesy lamp.
If equipped, remove screws attaching door assist handle to inner door panel.
If equipped, remove screw attaching door pull cup to inner door panel.
If equipped, remove screws attaching trim panel to door from below map pocket.
If equipped, remove window crank.
Using a trim stick, remove screw cover from switch panel.
Remove screws attaching switch panel to door trim.
Remove power accessary switch from door trim Front Door Switch Panel
Disconnect power switch from wire connector.
If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
Lift trim panel upward to disengage flange from inner belt molding at top of door.
Tilt top of trim panel away from door to gain access to latch linkage.
Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
Separate linkage rod from latch handle.
Remove front door trim panel from vehicle.
INSTALLATION
Hold top of trim panel away from door to gain access to latch linkage.
Place linkage rod in position on latch handle.
Engage clip to hold linkage rod to inside latch release handle.
Place front door trim panel in position on door.
Install trim panel into inner belt molding at top of door.
Install clips to attach door trim to door frame around perimeter of panel.
If equipped, install screw to attach door trim to door panel behind inside latch release handle.
If equipped, connect power switch into wire connector.
Place power accessary switch in position on door trim.
Connect wire connector into memory seat/mirror switch and install switch into trim panel.
Install screws to attach accessary switch panel to door trim.
Install screw cover into switch panel.
If equipped, install window crank.
If equipped, install screws to attach trim panel to door inside map pocket.
If equipped, install screw to attach door pull cup to inner door panel.
If equipped, install screws to attach door assist handle to inner door panel.
Connect wire connector into courtesy lamp.
Install lamp in door trim.
Feb 02, 2012 | 2000 Dodge Caravan
The on/off swith fell off. How do I remove the cover (gray frame) to reattach the switch? Thanks.
You remove the stand and all the screws on the back, then use thin flat blade screw driver to separate the case starting at the bottom edge and work you way around, the case is held together by plastic finger hooks, they go together real easy but hard to separate.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Feb 01, 2011 | HP Pavilion F70 17" Flat Panel LCD Monitor
Button has pushed in dropping into opening behid front panel;To access, must top of washer be removed to allow access to fron wall where button has dis-engaged?
This model usually has two screws hidden under corner trim sections that snap on each end. The best thing to do is grab the top part of the endcap and pull back towards yourself. this will make it come loose and then remove it. Under these endcaps will be two screws...one in each corner , remove these and pull towards you and up the whole console should come up......now, sometimes, there are four screws holding a back cover on...if so, just remove these and you can see everthing there. the start switch just is held in place by a plastic tab thats attached to the switch. The switch has a square shape which you line up into frame and turn switch like 1/4 turn until the locking tab snaps into place...its possible that the switch fell apart and if it did...you will need to replace switch
Bruce Denton
Dec 12, 2010 | Kenmore 84052 Dryer
Water is leaking from the bottom of the machine and will not fill up
Your water leak can come from 3 areas:
1) drain hose on back of washer is coming off / splitting / getting loose
2) water pump is leaking (cracked?) or has a gasket that has deteriorated.
3) hose between tub and water pump has come off / split / became loose.
Since your washer isn't able to hold water, it makes it easy to remove the clothes, and lean the washer forward to see what is going on. Most washers' mechanicals can be acessed from either the bottom, or from the back via access panel. The water leaks are generally a pretty easy repair.
Sep 18, 2010 | Admiral Washing Machines
My door wont unlock after my driver side door panel fell off as i was opening the door..heeeelp
make sure that none of the wires didt pull loose on the bottome of the switch
Mar 14, 2010 | 2002 Jaguar X-Type
Lexmark P3150 was working fine.But paper got jammed. I pulled the paper out and color cartrdge went to left side like a bullet and blue light in On Off switch started flickering. When I start printer...
Maybe you somehow detached the encoder strip when removing the paper.
First, before you put your hands inside the printer, unplug the power chord from your printer. This is important.
Then open up the lid and locate the horizontal metal bar.  Right above this there should be a semi-transparent plastic strip attached in the right and left side of your printer. If you see this, try moving it with your finger. If its properly attached, it should bounce back to it's original position. If it's loose, try to attach it to the right/left side again. If you can't find it, it probably fell off and is jammed inside the printer somewhere.
If the encoder strip looks OK, your carrier might have jammed in the left side of your printer. Keep the power chord unplugged.
See if you can unjam the carrier by pulling it along the metal rod. If should be fairly easy to move back and forth, so you'll know if it's stuck. If you can't loosen it, your printer is probably damaged beyond repair. Check if you have warranty on it.
Mar 05, 2010 | Lexmark P3150 All-In-One InkJet Printer
USB connector for Western Digital My Book fell off inside
its some difficult to repair. you should purchase a newer case for your Hard disk
Aug 16, 2009 | Western Digital (WD3200JS) 320 GB Hard...
My Nokia 1100 fell down and display is not working.
if you are good at opening the handset then just open the handset and adjust the display the screen correctly bcoz it will be in loose contact as it fall it might have became loose or the display might have gone one you open the handset and adjust it will work ...
once you press the display screen after opening the panel near edges and in the middle with a little pressure ...
if the display is gone then you can get the new display screen and you can replace that by your self it is easy to do it ...
the display screen of the 1100 is very cheap so no problem if it is gone means ...
if you are not good at opening then just take your cell to the service center he will do it but he may take some service charge ..
i think you can do it ,it is not so much difficult task ..
thank you
regards
-Dileep
rate my solution
Nov 14, 2008 | Nokia 1100
Access to tighten my antenna
Is it a power antenna ? or a regular antenna ? you may have to remove the wheel well liner to acess the antenna.Remove the clips that attach the liner.Hope this helps.
Jun 26, 2008 | 2000 Toyota Tundra
Mitsubishi WS-55511 55" Rear Projection Television Logo
22 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
