Question about Samsung WF337AA Front Load Washer
Samsung WF317 Front Load Washer code nd
My washer has had many problems which we have mostly repaired ourselves, unfortunately it looks like we are stuck with it so our current issue is the washer does not seem to drain properly, either the pump or the drain/water level sensor does not work properly. We get a code nd a which point I run the washer through another rinse/spin, (they are still sudsy) then a spin. I can then put the clothes in the dryer. Any ideas?
  • 7 more comments
  • Anonymous Feb 21, 2009
    my washer does not spin all of the water out of the clothes. I run it through two or three spin only cycles before the clothes are dry enough to put into the dryer. Any ideas???
  • Anonymous Mar 05, 2009
    anyone else have a problem with the water coming out of the soap dispenser on fill?
  • Anonymous Mar 08, 2009
    something is rubbing against the drum
  • Sheila Feist Jun 15, 2013
    well there is a plug that needs to be cleaned out and then it will work again
  • Anonymous Mar 16, 2014
    i cant get the spin cycle to drain all the water out of my maytag samsung washer
  • Anonymous Mar 20, 2014
    The code being displayed is "nd".
    Any idea what could be the issue? According to the manual I should power off/on the washer and try the "spin" only cycle. Tried that and still no spin. The spin icon/symbol just flashes.
    Any other wash cycle - and the "wash" icon flashes.
    thanks for suggesting any workable solution.
    If in the Sanford/Lake Mary area of FL, would appreciate if you can please suggest a competent repair contact.
  • Anonymous Mar 21, 2014
    won't spin or drain, shows nd code
  • Anonymous Mar 22, 2014
    I EVEN TRIED TO RESET AND NOW IT BACK TO THE ND CODE
    the washer works but wont drain or spin drum appears to drop down inside but remove wet clothes wait and it will drain and spin then will do a load and same thing happens again
    President:
  • 1,902 Answers
Check the drain pump itself. But at the same time if your clothes are still sudsy it sounds like it is not going through all the cycles. Almost like it is skipping a cycle
Posted on Feb 12, 2009
When the washer mark nd,what that mean?
SAMSUNG Silvercare Front Load Washer will not drain ...
? 3:06
www.youtube.com/watch?v=JozFGnPsQvA
May 4, 2013 - Uploaded by eallevato Troubleshooting a Samsung front load washer that is displaying ...Ordered a new pump and still no spin and "nd" code comes on after a while.
Sep 27, 2015 | Washing Machines
Samsung vrt nd or nb error code
ND is not draining, the washer probably has water in it and won't open. In which case you need to open the little tiny panel on the front of the washer and pull out the little hose and drain the washer and then clean our the filter next to the hose. NB means not balanced and the clothes have become unbalanced, move the clothes around and start it back up. If it happens a lot the washer is not on even ground and needs to be leveled.
Feb 18, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung wf 210 front load washer nd code
Check out the drain hose and connection hose to pump and then check out the pump in the washer for any clog or junk stock in the pump and clean it with warm water and test it is working properly or replace if it is not and reinstall the pump
May 21, 2014 | Hotpoint Aquarius WF210 Front Load Washer
New pump installed, still not working and nd code
look at ( have a technician look if you want to save money) at the program board for a problem there
Apr 25, 2017 | Samsung WF328AA Front Load Washer
A "nd" code displayed,
How to fix a Samsung Washer nd washer error code. You can make this repair your self and in most cases without parts.
Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain.
When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front.
If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise.
If the front panel does not have the access panel the washer will need to be slide forward.
With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible.
Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation.
If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced
Feb 27, 2013 | Samsung WF206ANS Front Load Washer
Where do i find the filter on my samsung WF317 washer?
It is probably located behind the front kick panel which will be held on with clips or screws.
Dec 22, 2012 | Samsung WF317AAG Front Load Washer / Dryer
Nd on screen will not spin
How to fix a Samsung Washernd washer error code. You can make this repair your self and in most cases without parts. Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain. When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Nov 10, 2012 | Samsung WF337AA Front Load Washer
Samsung WF209ANW front load washer -- ND error code. I cleaned debris filter and all hoses, however it still will not drain. How can I tell if the drain pump needs to be replaced? Is there a diagnostic...
Hello & Welcome to FixYa
ND error in your Samsung Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Sep 25, 2011 | Samsung WF328AA Front Load Washer
I have a ND code on my samsung front load washer
ND error in your Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Apr 13, 2011 | Samsung WF328AA Front Load Washer
I have an error code of nd on my washer
If your washer is beeping, and the display is flashing "Nd", your debris filter may be clogged. To check for a clogged debris filter, goto back of machine, look for little door at bottom remove cover and remove filter and clean
Dec 19, 2010 | Samsung WF306BHW High Efficiency Front...
Samsung WF337AA Front Load Washer Logo
1,597 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
