Question about Sanyo 09KS51 Mini Split Air Conditioner
Condensation from the coils
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I have a Sanyo Cooling Only Mini Split Air Conditioner it is installed in a small room with two driers. I am having condensation from the coils dripping down from the bottom of the inside unit. I have installed hoses on both sides of the drip pan but the condensations on the coils are causing it to miss the drip pan all together. So what can I do to stop the condensation from building up? Do I need to add more Freon? Or what will be the best solutions?
  • sloeridre May 11, 2010
    need to know room ambient temps, and pressure readings while running.
  • Pyldrvr May 11, 2010
    Check to make sure that 1 you drain line going from evaporator is not plugged up. If it is not plugged up then you will need to tell me what your freon pressures are before I can tell you if you need freon or not.
  • 121 Answers
Check drain hose maybe is obstruct or have bad plunk.
Posted on Feb 17, 2009
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
What is error E5 on pioneer mini split air conditioner?
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in.
Try cleaning it (them if inside one too), with dishwashing liquid and spray outside hose.
Jun 03, 2014 | Pioneer Ductless Mini Split INVERTER Air...
Hello We just installed a Sanyo KHS1271 mini-split
The condensate drain line was not properly installed. Make them pull the wall unit and correct the problem.
Be persistant until you are satisfied they have the problem corrected. Do not pay any additional money. If they do not correct the problem then report them online to the state board of heating and air. Fill out their requested complaint form and follow thru with a second complaint if you do not get total satisfaction from the contractor that installed the unit.
Hope this helps.
Sep 23, 2011 | Sanyo Split System Air Conditioner
LM-2430C2L 24000 BTU Cooling Only Dual Zone Mini Split Air Conditioner: Does LG makes AC which can cater two rooms at time...
Yes they Do they are called Dual Zone Units. At http://www.paylessminisplit.com they are very helpful if you call them they can answer alot of questions about many brands of mini split air conditioners.
May 16, 2010 | LG LM-2430C2L Cool Mini Split Air...
Mini Split Condensation Problems!
Maybe you need to invest in a good De-Humidifier.
Jul 08, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Computer room cooling
I work on and like the sanyos.Yes there is usually a crankcase heater and fan cycling controls.As far as efficiencies.....thats up to what you wanna spend upfront or on electricity later on.Im in Ohio.
Nov 03, 2008 | Sanyo 24KS32A Cool Mini Split Air...
York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Oct 21, 2008 | Sanyo 09KS51 Mini Split Air Conditioner
Sanyo 09KS51 Mini Split Air Conditioner Logo
446 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
