Question about Bosch DKE 9365 Stainless Steel Kitchen Hood
Install the chimney cover
We don't know how to install a chimney cover
  • Anonymous Mar 21, 2009
    i don't know how to fix the chimney to the wall
  • 547 Answers
There should be 2 or 3 peices of alum off the hood predrill hole's then rivet or steel screws
Posted on Feb 12, 2009
I have touch screen kitchen chimey of glen make, how to install it give the guidance
Posted on Apr 17, 2011
Smoke not going up chimney
damper closed in chimney or blocked chimney
Jan 04, 2017 | Cars & Trucks
How to put the mantel and flue parts back on in the fireplace
Fireplace and Chimney Parts: Diagram and Anatomy
https://www.highschimney.com/.../parts-chimney-anatomy-fireplace-chi...
Nov 30, 2011 - A chimney is made up of up to 22 parts. ... Mantle - Also known asmantel piece or mantel shelf, this piece of hardware is more than a .... I have an old Blaze King Fireplace Insert that was purchased back in the mid 1980's.
How to install a wood burning fireplace insert - Hearth.com
www.hearth.com/econtent/index.php/articles/install_insert
A Heatform is a metal firebox which is built into a full masonry chimney. ... The distance to the adjacent wood trim and the mantle. ... All the way back in the fireplace, or out on the hearth? ... Rockford Chimney Supply - We are the best source forChimney liners and Stainless steel chimney liner kits to install your insert or ...
Dec 20, 2015 | Heating & Cooling
I'm installing a wood stove insert with a 6" flu. Can I use a 5" or 5.5" chimney liner and be ok? Thanks in advance. Jacob Ullucci
If the stove exhaust pipe is 6", you need to have a minimum of 6" all the way up your chimney. If you use a smaller pipe you will limit your flow, which causes excess cooling and crystalizing of smoke creating more creosote, and more of a chance for chimney fire. The perfect solution would be to run a 6" liner down your chimney, and connect it right to the top of your insert. Make sure you install a top plate at the top of the chimney to insure pieces don't fall outside the liner. Lastly install a stainless steel cap to keep any animals out.
Sep 13, 2013 | Hearth Products Controls Round Match Lit...
How much does a Chimney Sweep cost?
Man or woman, the women are much more expensive.
Oct 16, 2012 | WatchBuddy Santa Claus in Chimney Watch
Fl3 code. heater working fine when i closed last year. will not start this year. showing fl 3- does not ignite , does not do anything ..help please
3.
Spillage at A.Cold chimney A.Allow heater to operate 5 minutes to create draft action.
draft hood B. Vent pipe pitches down to chimney B. Reinstall vent pipe to pitch up from heater to chimney.
C. Blocked chimney C. Remove blockage.
D. Draft hood altered D. Install factory-provided draft hood.
E. Prefabricated chimney with incorrect cap E. Install a Nationally Recognized Testing Lab (NRTL) listed vent
http://www.jandy-downloads.com/pdfs/Lite2_LJ_IO_H0248900F.pdf
I tried to copy the FL3 write up from the chart but it screwed it up a little. Look at Page 35 of the manual for a clear copy
Jun 10, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Screen over chimney?
Screen is not the correct product to use to bird or squirrel proof the chimney. Your local hardware will have what is known as hardware cloth. It's actually a heavy wire mesh with 1/4" or 1/2" square pattern. you should be able to purchase it, by the foot, off a roll.
Jan 06, 2010 | Bosch 36 Inch Pyramid Chimney Hood - Black
I have just opened up my chimney and took it back to the bare bricks and was giong to install a wood burner but decided to fit a gas stove instead. there was originally a gas fire installed so it has a...
You will need to install a flue liner ( i know its a nuisance) to allow the products of combustion to escape as quickly and as safely as possible.
If you installed a gas appliance without a liner, due to the temperature of the flue gases (lower than solid fuel) the emissions would struggle to exit via the flue terminal.
If you install the appliance following the manufacturers instructions, you cannot go wrong. The other recommendation is get a 'Gas Safe' engineer to carry out the commssioning/testing.(house insurance void if not certified)
I hope this helps.
Jul 07, 2009 | Ovens
We have a old house and the gas hot water heater and the central heating unit is vented out an old chimney and the heater is building up condinsation, how do i vent the heating unit out the wall, unstead...
actually if you vent your furnace by code, it would probably be cheaper to have a chimney liner installed up the old masonry chimney. you may be able to buy a kit and do this yourself. any time a new furnace with a draft inducer on it is installed, it must be vented into the proper flu material. if it was vented into your chimney, it may not have be installed by code for your area. you may talk to the instaled if they are still available and maybe that can return and do it correctly. if you leave this vented into your masonry chimney, the acid content of the exhaust will ruin the chimney. a liner will also get rid of the water problem you have.
Jan 26, 2009 | Heating & Cooling
Bosch DKE 9365 Stainless Steel Kitchen Hood Logo
390 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
