Question about Pioneer Elite VSX-91TXH
No HDMI Output thru' receiver
Last night there was thunderstorm in our area. Since then I can not see any display on my TV thru' HDMI output from the receiver. Everything else works fine. It was working great for last 1.5 years and also gone thru' several severe thunderstorms.
I have dish network receiver (DVR) connected to receiver via HDMI cable, receiver is connected to Plasma TV via HDMI cable.
HDMI output from receiver is thru' AMP.
Is there a way to reset the receiver to factory defaults? OR Do I need to take it to the repair shop?
  • sudhirkatke Feb 12, 2009
    Thanks for you quick reply, dragonsthatk.
    Well. I have connected all my Electronic gadgets thru' surge protection devices. As I mentioned in my original post that everything works fine except HDMI output. So I doubt it is related to fuse.
  • 547 Answers
You most likley blew a fuse . take it to a repair shop it you live in an area that has lot's of storm activitey you might want to look in to getting serg protection on your elect panel to save repairing other thing's in your home. thank you please rate mee
Posted on Feb 12, 2009
Cant get ps4 to pass signal thru avr to projector.
Possible PS4 HDMI Handshake Output Problem - AVS Forum ' Home ...
www.avsforum.com/.../1508885-possible-ps4-hdmi-handshake-output-p...
Dec 31, 2013 - 20 posts - ‎15 authors
Nothing seems to make the PS4 pass a signal through the AVR. .... can output videothrough the Integra, why can't Sony get the HDMI working? PS4 - 3D Playback Not Working :-(
Aug 12, 2014
Run HDMI Directly to TV or A/V Receiver?
Dec 19, 2013
AV receiver problem with Xbox One
Nov 23, 2013
Solution to HDMI @ 1080p receiver/display HDCP ...
Dec 14, 2008
More results from www.avsforum.com
My Denon AVR-X4000 won't output video signal from attached HDMI ...
forum.blu-ray.com > Audio > Receivers
Dec 21, 2015 | Denon AVR-3311CI 7.2 Channel Networking...
Can I get Chromecast to play thru my surround sound?
If your receiver has an HDMI input that you are connected to from an HDMI output of your TV; then yes you can listen to it in surround sound.
The HDMI input that you are using on your receiver must be designated as a TV input if it has the capability of being "assignable" in your receiver setup options; or otherwise just connected via HDMI on the rear or front panel of the chassis on TV inputs section.
Once the proper connections are confirmed, select your receiver input to TV. The TV output mode must be set to HDMI; or you will not get any sound or picture if that is the only connection. You'll have to refer to the receiver manual on how to do this if the output mode does not select automatically as I do not know what gear you are using.
If you have your speaker setup in a 5.0 or 5.1 setup; depending on the decoding capabilities of your receiver; you should be able to get audio through each channel in a variety of ways. Refer to your receiver manual for the decoding format compatibility. The decoding may also be performed by your TV as well.
Dec 08, 2014 | Denon Audio Players & Recorders
How do I get picture back on TV which was working the night before, which is hooked up to HD cable box, thru HDMI?
OS info is always helpful, if say you are running some type of nix, it's likely not getting recognized by xserver or if your running some version of windows your display manager has shut it down because of a resolution mismatch.
May 26, 2014 | Amstron Fujitsu LifeBook E390 Laptop DC...
Incompatible video signal has received check output device settings
My guess would be that your PS3 has somehow switched the output settings. You can reset the settings by pressing and holding down the power button till it starts blinking. Try connecting it with your RCA cables to a TV and if that works try going into your settings and setting the PS3 back to HDMI.
Jan 23, 2014 | Sharp Aquos Televison & Video
HDMI Output driver for MSI-7267 ver:4.2?
Is this a laptop or desktop? More than likely it's an output port. Output to what? A tv?
Normally you would just connect the cable between the computer and the tv. Then take the tv's remote and press Select Input. Then select HDMI as the input source. Reboot the laptop or computer and it should show on the TV.
If it's a laptop The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 31, 2012 | Computers & Internet
How to connect to my Yamaha R-V503 from my HDTV that comes with HDMI and Optical Output? Thanks!
Hi,here is the possible solution......
** you need to connect "Audio Output " as either : "Optic cable output" or "HDMI "connector " of your TV ,
** to "Optic Cable input"
or if you have "HDMI input" of your YAMAHA Receiver
** than just switch to respective mode on
Receiver corresponding the connector you have used on the back of Receiver ..You can use "HDMI" connection as well but sometimes HDMI creates problem on Audio..I recommend you to use Optic cable..
There you go..your Tv sound are on the
YAMAHA receiver as SURROUNDING SOUND .
By this means ,whatever you watch on the TV
will come thru your
Receiver
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 07, 2011 | Yamaha R-V503
I have yamaha rx-v465 receiver and yds-11 docking station. how can i get tv{through hdmi 1}to display what's on ipod.i have nano w/video camera{newest one]. is this possible
I think it is not possible, because RX-V465 does not have HDMI-video processing. It can only pass-thru the HDMI video to HDMI-out, but not alter the signal in any way.
If it should support TV output with YDS-11, it will work only via analog video out (s-video / composite / component).
Dec 30, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
Onkyo TX-SR875
My mistake, HDMI in is not routed to any other output but HDMI out
Oct 04, 2008 | Onkyo TX-SR875 Receiver
Xbox 360
There are a couple of options you can use.
Are your DVD and cable actually going to the Onkyo first and then to the TV? I am assuming it is, if you listen to the Onkyo when watching a DVD or cable.
The Onkyo receiver you have has 2 hdmi inputs and 1 hdmi output.
Does your Xbox360 have an hdmi output and that is what you want to connect to the Onkyo? Some do and some don't.
If your Xbox has a hdmi output and you are already using the 2 hdmi inputs on the Onkyo, you can not connect the Xbox using the hdmi, you have no more hdmi to connect to, so you must go thru one of the other inputs of the Onkyo.
The hdmi has the video and audio together, the other video options do not. you would need to run seperate audio cables as well.
Your Xbox should have a composite video (yellow RCA jack) output or a component video (1 red, 1 blue, 1 green RCA jack) output.
When you connect the Xbox thru, lets say the composite video of the Onkyo , you will also need to connect the audio from the Xbox to the Onkyo on the same input. It should be right next to the yellow RCA jack or right under it. They are 2 RCA jacks, one red and one white.
You will then need to connect the composite output of the Onkyo to the composite input of the TV.
When connecting like this, you will also need to select the composite input on your TV with your remote for your TV. Your TV should have an input button that lets you go thru all the different inputs to it.
you can also use the component video from the Xbox if it has that. But you must also run the audio to the Onkyo as well to the corresponding audio inputs of the component video input on the Onkyo.
This may sound a little confusing, but remember that the hdmi has the audio and video in one cable, the other video options do not, so you must run additional cables for the audio to the Onkyo from the Xbox.
Also remember whichever video you use from the Xbox to the Onkyo, you must also run that same video from the Onkyo to the TV and then switch the TV over to that input when you want to watch the Xbox on the TV
Jun 21, 2008 | Onkyo TX-SR605 Receiver
Pioneer Elite VSX-91TXH Logo
542 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
