Question about Frigidaire FRS26R4A Side by Side Refrigerator
I can not get water nor ice side by side refrig
I have taken the hose in the back off to check the line. There is water coming out. The machine acts like it wants to work. I still can not get ice nor water out of the refrig
  • 1 more comment
  • edleejordan Feb 12, 2009
    also same refrig Frigidaire FRS26R4A the top of the freezer is not cooling
  • robert samples May 11, 2010
    is there hevy frost at the bottom of the freezer on the back wall
    check the filter to see if its frozen or cracked
    Problem Solver:
  • 8 Answers
Hello...the water valves might be the problem, seeing how you've checked the water line and water flows out. I had the same problem. No ice, no water. The water valve was defective. Hope this helps you out. :)
Posted on Feb 20, 2009
Ice maker not getting water to it, I recently replaced the copper line from the wall to the refrig with a flexible stainless steel. The refrig stayed disconnected for a week before replacement now I...
Hello DeWayne,
That hose that connects to where the water comes out as it cycles,the end of it where it goes to the top and enters into the freezer/icemaker is frozen and needs to be removed and thawed,you could take that hose off at the water valve and blow through it if you can not blow through it easily its defiently froze,if once you thaw it it becomes froze again within a couple days up to a couple weeks the water valve where that hose connects to at the bottom is bad and causing it to freeze and that valve should be replaced.
I hope this will help you to get your icemaker working,
Gene
Aug 08, 2011 | Frigidaire FRS3R5EMB Side by Side...
Tip
No Water Coming Out of The Water Dispensor on G E Refrigerator ?
If you are not getting water thru the door dispenser , first thing to check is if you are getting water to the water valve behind the refrigerator . This is the part in the back of the refrig , that the wall water line connects to .
If your ice maker is making normal size cubes , then you ARE getting water TO the water valve .
However , there are 2 coils on the water valve ( G E ) of which 1 is for the ice maker , and , the other , is for the water dispenser .
1 ) Remove the kick plate from the bottom front of the refrig . On some models , the kick plate " snaps " on , and other models , it is held on by a small screw on each side on the top portion of the kick plate .
Once the kick plate is removed , follow the plastic water line from the bottom of the freezer door , about 6 " , to a small coupling . This coupling , has a " ring " on both ends , one of which has to be pushed in as you pull the tubing from the coupler . Once this is accomplished , put a towel under the end of both ends of the tubing , to keep the floor dry .
2 ) Activate the water dispenser arm . If water comes out in a good stream , from the tubing which goes under the refrig , the water line inside the freezer door is frozen . You can either turn the freezer temp warmer for several days for the line to un-thaw or use compressed air ( I have heard using computer cleaner air bottles with the small tube works ) to the water line going up form the bottom of the freezer door to blow out the frozen ice .
Once the ice thaws , G E has a dispenser heater , part # WR49X10173 which comes with installation instructions , to keep this from happening again . If NO water comes out of either hose , then either the water tank inside the bottom of the refrig is frozen ( which would require several days of warmer temperature settings ) OR the refrig could have a bad coil on the water valve , which would require replacing the complete water valve .
I have only come across maybe 1 tank which was frozen , and the rest have been either the line in the door was frozen OR the water valve needed replaced .
Please note....if using compressed air in the door water line , DO NOT USE EXTREME HIGH PRESSURE , as this could burst the line in the door , causing the complete door to have to be replaced . Just the water line inside the door , is not replaceable .
on Apr 10, 2010 | Refrigerators
No water will come out of the door
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR41X10173 to stop this freezing and it comes with instructions .
May 25, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water not working but still makes ice
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR49X10173 to keep this from happening again ( comes with instructions ) .
May 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool GS5VHAXWY00 25 cu. ft. side by side contour door - in door water has stopped flowing. Refrig is 6 months old. Water still flows to ice maker.
when you push the button inthe front of the machine it should give power to the valve in the back of the machine .check the valve in the back of the machine where the water line connects to make sure there is no blockage in the line next thing to check is if your getting power to the valve on that side of the valve that the water is connected
Apr 28, 2010 | Refrigerators
The water dispensor line clogged.
you will need to replace the line from the back to the dispensor
Nov 21, 2009 | Amana 22.6 cu. ft. Side-By-Side...
No water from door. I've taken the water line loose from the siloniod water will flow when activated. but will not come out at the door.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then , the water tank inside the refrig section , behind the crispers , is frozen . If the door line is frozen , pt # WR49X10173 , is a dispensor heater kit , with instruction , to keep the door line thawed .
Nov 11, 2009 | Hotpoint HSS25GFP Side by Side...
No ice & water in water dispenser on Whirlpool side-by-side refri
take the hoses off the other side of the solenoid and have someone push the button to check the valves usually they are the problem unless you have very hard water in which case you can use compressed air to clean them while they are off the valve.
Jun 26, 2009 | Whirlpool ED2FHEXN Side by Side...
PULL THE TUBE BEHIND THE ICEMAKER OUT AND SEE INSIDE IF IT IS FROZEN,IF NOT ALL THAT'S WRONG IS THE WATER INLET VALVE ON LOWER BACK OF FRIG.IS BAD,YOU HAVE A WATER DISPENSER HOSE ON ONE SIDE AND A ICEMAKER HOSE ON THE OTHER,THE ICE MAKER SIDE OF THE VALVE IS BAD,THANKS-MIKE
May 29, 2008 | Whirlpool GS5SHGXLS Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
