Question about Frigidaire GLER331A Electric Dryer
LER331SRO Frigidaire electric dryer won't come on!
Is it the door switch? Thermo switch? or fuse? I put a multimeter at the outlet-It was good. Breaker good. Cord good too.
    President:
  • 1,902 Answers
Check the voltage on the door switch, you can even jump the wires and see if it comes on, if not then replace the swiitch, Sounds like the door switch or the fuse. Door switch first though
Posted on Feb 12, 2009
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
Get dryer to work, no instruction manual for Indesit Washer WDG 1195 W
What to check when your dryer won't start-
The wall outlet 240 volts:
The first thing to check when your Whirlpool dryer is not starting is the wall outlet to make sure that the dryer is getting the proper voltages. On an electric dryer there should be 240 and 120 volts present at the terminal block.
A blown fuse or tripped circuit breaker are one of the major causes why the dryer won't start. To check the voltage on an electric dryer you will need to use a multimeter.
The wall outlet 120 volts:
A gas dryer connects to a 120 volts wall outlet, and it is very easy to check the outlet. Disconnect the dryer and connect a hair blower or any other small appliance on the outlet.
If they work, then the problem must be on the dryer. If the don't work, check for a blown fuse or tripped circuit breaker. If the problem is bigger than that, have a license electrician check the house wiring. A bad wall outlet could be the reason why your Whirlpool dryer is not starting.
The thermal fuse:
The thermal fuse is use on an electric dryer as a safety devise to open the motor circuit if the operating thermostat fails to open at the preset temperature or if the motor draws too much amperage.
A blown thermal fuse could be the reason why your Whirlpool dryer is not starting. It is located behind the back panel on the dryer.
The door switch:
The door switch is another safety device use on the dryer. It is connected on the neutral line of the motor circuit. A door that is not closing properly or a bad door switch could be the reason why your Whirlpool dryer is not starting.
The push to start switch:
The push to start switch is use to start the motor. There are two types of switches. The older type switch is a solenoid operated door switch and the other one is a simple push to start switch.
A bad solenoid operated or regular push to start switch could be the cause why your Whirlpool dryer is not starting.
The timer:
The timer is the distribution center or the brain of the dryer. Inside of the timer is that the electricity gets routed to the different electrical parts in the dryer.
The timer has contact points, and the contact points wear or burn out depending on the amount of use. Contacts burnt inside of the timer, could prevent the dryer motor from starting..
The motor:
Also, the motor could be burnt bad. A motor that smells like rubber burning, makes growling noises, runs for a wile, the won't start until is cool down or a motor that runs fine, but the centrifugal switch is not making the right connections is a bad motor and must be replace.
So...as you could see, there are many parts that could be the reason why your Whirlpool dryer is not starting.
Feb 16, 2008 | Washing Machines
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
see this causes and fix it. God bless you
Sep 28, 2012 | Dryers
Dryer model #GLER642AS3 has no power, won't start.
You may have a bad timer, door switch, start switch, motor or terminal block. You should have a repairman test them all.
May 06, 2012 | Frigidaire GLER642A Electric Dryer
Troubleshooting whirlpool electric dryer WED5530SQ0
The only thing that is left is the timer. Use a multimeter and wiring diagram prior to replacing it. It is something that doesn't go out often.
Good luck.
Semper Fi,
Z
Feb 01, 2018 | Whirlpool Dryers
How do replace heating element in dryer
Instructions
Things You'll Need:
* Volt meter
* Clean cloths
* Waste bin
* Replacement fuse (optional)
1. Secure the power cord in the Frigidaire dryer as well as the power outlet if the dryer does not start. Replace the fuse or reset the circuit breaker if necessary.
2. Check the fuse if there is power but no heat, as dryers need two fuses in order to operate properly. Replace the fuse if necessary. Select heated cycles if items are wet and cold after drying.
3. Open the dryer door and slide out the lint screen if the dryer seems to be taking a long time to operate. Clean off the lint and return the lint screen to the unit. Use a volt meter to check the power outlet for proper electricity, which should be 240 volts or more. Clean the exhaust hood outside the home and straighten the exhaust vent if bent.
4. Keep the load size medium and distribute pieces evenly inside the drum if items are wrinkled or damp. Increase drying time or temperature as necessary.
5. Check pockets for hard objects before putting pieces in the dryer, as items can create scratches or chips inside the drum and cause a clinking noise during use.
6. Contact Frigidaire for assistance if the problem continues.
Feb 24, 2011 | Frigidaire Electric Dryer
I have a maytag electric dryer it wont start on and the light does dont come on when door open i checked thermo fuse it tested good any other ideas
Did you pay the electric bill?
Seriously the door switch must be broken or stuck in the IN position. Seen it. Some repair info with pictures and locations of hidden safety devices.
Oct 24, 2009 | Dryers
Over the weekend, I notice a bird flying in and out of my dryer vent... then our Kenmore electric dryer stopped heating. I'm think that there wasn't enough airflow and the thermo-fuse probably blew... What...
Ah Yes! the old bird in the dryer vent problem!
I would say you are correct. The thermo-fuse blew because of not enough air flow through the heat tunnel.
You probably have a nest in your vent line now.
Clear the entire line from machine outward, replace flex hose if needed and get a new outlet cover with the flaper door on it.
I avoid the ones with screens on the outlet, because it catches lint.
Except in severe cases where a mouse or some other varmit has figure out how to lift the door.
Apr 27, 2009 | Kenmore 62602 Electric Dryer
Dryer won't start
Does the unit have power? Have you physically turned the breakers off and then back on? Have you checked that the dryer cord is good? Have you checked that the outlet has not shorted out? If you have check all these things and it still won't start then it can either be a bad door switch or the on/off switch is bad.
Apr 11, 2009 | Maytag Dryers
Frigidaire electric washer dryer combo
i am asuming that when you say it works you mean it runs but not with heat? the thermo fuse is behind the back panel of the dryer the unit needs tobe pulled out to get to the back, you should see a bigger black thermostat next to a smaller thermo fuse, you can just jump the thermo fuse to see if that is your problem. it is not a fuse like you think of in your home.
May 22, 2008 | Dryers
Frigidaire GLER331A Electric Dryer Logo
61 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
