Question about Microsoft Xbox 360 Console
Mtu can someone help me with the mtu?
  • 360CFW May 11, 2010
    A Slight bit more info would be apreciated and i may be able to help. Whats the problem?
  • 23 Answers
You must set your MTU in your modem/router just login to it and search for it in the configuration menu.
Usually you have to set it to 1492 though so if you should have set the MTU to 1364 already and it didnt work try this one as well.
For cable and DSL modems you should set it to 1492 in general as well for a proper connection.
The MTU is the maximum size that an IP-packet that is transfered across the internet may have just for general information.
I hope this helps.
Kind regards,
Wilhelm@Xboxexperts.com
Posted on Mar 06, 2009
MTU settings
So your first problem is to learn how to login to your router. Please see your documentation. You can usually find the documentation for any router/homegateway at the vendors website.
If you still can't logon you may have to do a "hard reset" of the router/gateway to force it back to the default logon/password.
Now having solved that you need to understand that the largest MTU setting that you can use to increase your internet performance must be equal to or smaller than the smallest MTU setting between you and your internet target. If you make the MTU larger than that it will slow down your connection because it will now have to use 2 frames transmit and recieve what it used to only use one for.
While there are tools that can help you with that, the simplest solution is to find out what your ISP says the MTU should be.
Tom
Aug 21, 2009 | Toshiba WRC-1000 Router (PA3227C1ETC)
How to change mtu settings to get x box live?
heres a good site that discusses adjusting the MTU(maximum transmission unit)
Usually in most cases MTU of 1500will work just fine, I suggest using DrTCP a free program available online to help you tweak your settings
http://help.expedient.com/broadband/mtu.shtml
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I need help changing the MTU settings on a D-link DI-624 router.
you have to enable wi fi in your router for that you need to access it.
Coonect your router to 1 computer with ethernet cable then access following link
http://192.168.0.1
or
http://192.168.1.1
then type username as "admin" and password as "admin" or blank or "password"
Then go to wirelesss and enable wi fi .
Jun 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cant find any options in the Web configurator about MTU!
My MTU is at 1500 and I get the same message. I don't think XBL is up yet.
Jun 16, 2009 | Zyxel Prestige 600WH Wireless Router...
Can't coonect my Xbox 360
Hope your still there... what its telling you is that you need to change the settings on your router go to internet explorer type in 192.168.1.1 and login go to "WAN SETUP link on the LEFT" change the MTU value to 1500 hit apply or save and that's it Good Luck ;]
Jan 31, 2009 | NetGear WGR614 Wireless Router
Xbox 360 mtu how do I change mtu on my DLINK ADSL2
I have the same problem, call the support line or resort to this website it helped me a lot... http://help.expedient.com/broadband/mtu.shtml
Sep 29, 2008 | Microsoft Xbox 360 Console
MTU setting
Browse to the router's setup page, should be 192.168.1.1 or 192.168.1.0 and log into it. You just have to change the MTU. Put it to 1500.
Once logged in to the router, go to :
Setup
Basic Setup
Wireless Setup
Internet Connection Type
Connection Type = Static IP
Internet IP Address = 192.168.0.1
Subnet Mask = 255.255.255.0
Gateway = 192.168.0.1
Static DNS 1 = 192.168.0.1
Static DNS 2 = 192.168.0.1
Static DNS 3 = 192.168.0.1
STP = Enable
Optional Settings (required by some ISPs)
Router Name = client-mode
Host Name = 2WIRE383
Domain Name = [empty]
MTU = Auto
Please remember to rate all users who assist you for free :)
Sep 29, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Mtu test is failing
I've had the same problem and struggled with it for hours... If your on the Comcast network, there seems to be problems with adjusting MTU. I have a Dell 2350 router and that particular router cannot have MTU modified. Also, sometimes the MTU is effected by computers or phones in the house being on. One more suggestion, try a gaming router. Good ones start at 90 dollars, somewhat expencive but well worth it.
Jun 03, 2008 | Microsoft Wireless Network Adapter Xbox...
Westell 6100 problems
we had the same issue. Here is how we fixed it. I had the xbox 360 plugged directly into the westell 6100 modem via ethernet cable. the mtu test failed everytime. I was extremely frustrated and called microsoft and verizon (dsl) about 10 times each and they kept giving me the wrong solution. (get a new modem, get a new server, pay us money and we'll figure it out etc...) Here is what a man at microsoft told me to do and finally it worked. Power cycle your equipment (unplug modem and xbox 360 for 30 sec.) then, plug in modem first and wait until all lights are back on. Then plug in xbox and run test. In my case mtu failed again. I was then instructed to go to my dashboard and restore xbox to factory default which I did and rerun the test. This time everything FINALLY passed. We were in business. I then decided to try connecting through my airport extreme router. I power cycled again starting with the airport then the modem then the xbox and ran the test and unbelievable as it sounds it all passed and my son is now sitting happily on the couch playing a game online with his xbox 360. This took away days of my life to get this simple thing done. I was given codes to change and change back on the computer, phone calls to everyone and the solution was so simple when you finally reach a knowledgeable person. Hope this will help save someone else the time I spent!
Oct 31, 2007 | Westell Wirespeed LiteLine 6100...
MTU
MTU, Partial Loss of Internet Connection, and Performance MTU (Maximum Transmission Unit) is the largest packet a network device transmits. The best MTU setting for NETGEAR equipment is often just the default value. MTU is sometimes presented as something that can be easily changed to improve performance, but in practice this may cause problems. Leave MTU unchanged unless one of these situations applies: 1. You have problems connecting to your ISP or other Internet service, and their technical support (or NETGEAR's) recommends changing MTU. For example, these services may require an MTU change: * Yahoo email * MSN * AOL's DSL service 2. You use VPN, and have severe performance problems. 3. You used a program to "optimize" MTU for performance reasons, and now you have connectivity or performance problems. * An easy solution to most problems is to change MTU to 1400. * If you are willing to experiment, gradually reduce MTU as described in "Details of MTU", below. How to Change a Computer's MTU Size Note: If you change MTU on one computer, it is likely you will want to change it on your other computers, switches, and routers, as well. Instructions for changing MTU on other NETGEAR devices is found in the Reference Manuals. The third party Dr. TCP software can be used to change the MTU setting. 1. Download it from this link, choosing the zip file or the exe file at the top of the page. 2. Run the utility. 3. In the Adapter Settings pull down, select the Ethernet driver and adapter used to connect with the network. 4. In the MTU box, type the MTU size you are trying. 5. Click in any other box, without changing the data there. 6. Click Save. 7. Click Exit. 8. Restart the computer. Details About MTU A packet sent to a device larger than its MTU is broken into pieces. Ideally, MTU would be set to the same ? large ? value on all your computers, routers and switches, as well as on all the parts of the Internet that you access. But you cannot control the MTU on the Internet, and in practice the optimum MTU size on your LAN is related to your hardware, software, wireless interference, etc. * Tweaking MTU size may work well in one situation, but cause performance and connection problems in others. * When network devices with different MTU settings communicate, packets are fragmented to accommodate the one with the smallest MTU. * Windows XP sets MTU automatically, that is, it optimizes computer MTU for you. This Microsoft article explains resolving lack of connection to a broadband ISP using Windows XP: http://www.microsoft.com/windowsxp/using/networking/learnmore/ppoe.mspx * Once a network device fragments a packet, the data stays fragmented until arriving at the destination computer. Setting MTU size is a process of trial-and-error: start with the maximum value of 1500, then reduce the size until the problem goes away. Using one of these values is likely to solve problems caused by MTU size: * 1500. The largest Ethernet packet size; it is also the default value. This is the typical setting for non-PPPoE, non-VPN connections. The default value for NETGEAR routers, adapters and switches. * 1492. The size PPPoE prefers. * 1472. Maximum size to use for pinging. (Bigger packets are fragmented.) * 1468. The size DHCP prefers. * 1460. Usable by AOL if you don't have large email attachments, etc. * 1430. The size VPN and PPTP prefer. * 1400. Maximum size for AOL DSL. * 576. Typical value to connect to dial-up ISPs.
Feb 19, 2006 | NetGear DG814 DSL Modem Internet Gateway...
Microsoft Xbox 360 Console Logo
124 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
