Question about Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp Aquos LC-32D44U stuck in ""Mono"
HELP! I just got the LCD tv and set it up but the speakers are stuck in Mono and I can't find anything in the manual beside toggling the Audio button on the remote. I have triple checked the hook ups in the back but it's still very tin-y and shows "Mono"
  • 3 more comments
  • ldymcd23 Feb 12, 2009
    It's got to be a set up issue... I can't imagine a 2009 HDTV can't handle 1980's stereo tech. It's in Mono on all TV & input settings - except when we plug in our Wii (also uses 3 wire AV cable). We're using the 3 wire red/yellow/white AV cables connected to a Digital DishTV sat & a tivo running in series into input one. We've run a diagnositic on both sat & tivo and both are running fine - even replugged in old set & worked fine again. Old tube TV never had issues with stereo sound.
  • PrdCanadian Mar 14, 2009
    I came downstairs today and turned on my TV to find out there is no sound. It was working fine last night. The other inputs are working, it just a problem with the TV input. It seems to be stuck in "mono" and i can't switch it out. The Audio button on the sharp remote is not doing anything.
    Anyone else have this problem or hear of a fix?
    It's an LC-37D44U
  • Anonymous May 04, 2009
    LC-32SB27U model, just bought yesterday and started off great then switched to mono and now stuck.
    Called sharp and they told me to run the RYW AV wires to fix, didn't solve the problem.
  • Devon Sacco
    Devon Sacco May 11, 2010
    Well, maybe the TV needs a software update on Manual page 26. They may have made a software patch for this problem.
    Best to call 1-800-BE-SHARP to find out what they can do.
    Sorry can't help you more.
  • Devon Sacco
    Is it stuck on Mono at other inputs? Like input 1- input 6.
    Is it Mono only on TV/CABLE mode?
I dont know if this will work for you, but its worth a try. I had the same problem.
1. I changed to a station that was having the problem (an analog station with MONO displayed on the screen).
2. I unplugged the TV for about 15-20 minutes. (I was thinking maybe something needed to refresh, so thats why i unplugged the tv.)
3. I plugged the tv back in and voila. The station showed up as MONO then immediately swtiched to STEREO.
After that, i was able to use the AUDIO feature on the remote to actually change from MONO to SAP, etc.
Ive had my Sharp for about 5 months now, and thats the first time its happend to me. Luckily, i solved the problem...this time.
Hope it helps.
Posted on May 24, 2009
    Problem Solver:
  • 16 Answers
Do the factory initial
Posted on Mar 31, 2009
I have a sharp aquos tv model lc-32m400x. When i turn the power on via button at the back the green light comes on for about 10secs then turns to red and flashes about every 11/2 - 2secs. Any ideas.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 11, 2017 | Sharp Televison & Video
Sharp aquos tv not turning on
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 09, 2017 | Sharp Televison & Video
Why won't my LC-32CHF5111K tv turn on I have a steady glowing red stand by light
It could be the power supply board on the TV. It could also be a blown capacitor on one of the circuit boards.
Jan 08, 2017 | Televison & Video
Sharp lcd tv. Grn lite flashing, reset by unplug, vol + ch - , plug in. Tv came back on, after few mins screen goes blk, have sound. turn off and on picture back for few minutes, goes blk, snd ok.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jan 07, 2017 | Sharp Televison & Video
What is password for Sharp tv 21Mf2-Amk2 ask
Finding the Manual   Go to the Sharp website, look it up and download it. It should be there.
Nov 03, 2014 | Televison & Video
How can I fix blue dots on my Sony TV screen?
Seems like a problem with a lot of Sony TV's. Wish i could be of more help, but check this site. Your not alone! Sony LCD Rear Projection TV Problems hope this helps!
May 23, 2014 | Televison & Video
My tv has gone some orange colour
Try unplugging your tv and anything connected to it - you might want to take a picture first so you have a reference. I would also unplug everything connected to the tv: cable, stereo, etc. Wait a few minutes, then plug in and re-connect everything.
You can also go into your TV's setup menu and adjust the picture settings - try restoring the default settings first.
Mar 22, 2013 | Televison & Video
Comcast remote code for 42in sharp aquos lcd
the 10093 code worked perfectly!!! YOU ROCK! the codes in the comcast manual dont work. i don't have an aqquos, but a regular sharp hdtv... purchased in nov '07
Dec 14, 2007 | Televison & Video
Sharp AQUOS LC-32D44U 32 in. LCD TV Logo
1,402 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
