Question about Kenmore Dryers
Kenmore 80 series runs but dont blow hot air
Is this heating element My 80 Series worked all day and now it will not heat up. Is this the heating element?
  • 1 more comment
  • brad_e_ellis Feb 12, 2009
    This is a gas dryer.
  • Mark Egan May 11, 2010
    Reply the full model number so the wiring diagram can be reviewed.
    Do you know how to use a voltmeter, and are you comfortable with troubleshooting electrical circuits?
    When you go outside to where the dryer vents to the outside, do you feel a strong blast of air being discharged?
    Is the dryer vent duct clear of lint and are you certain the hose behind the dryer that connects the dryer to the vent duct is not crimped?
    Is this a gas or electric dryer?
    If electric, it could be the heating element, but could also be one of the two thermostats.
    If gas, it could be the same thermostats, or additional components in the unit.
    President:
  • 1,902 Answers
Check your heating element. #1 cause for no heat. Easy to replace and ea VERY easy to break. Just for your own well being also make sure that gas pressure us correct
Posted on Feb 12, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 12, 2009
    Replace the heating element and that will solve your problem. Please rate
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
Where is the thermal fuse on a series 80 kenmore electric dryer. will this act as though the power is off? How can i test the fuse?
Yes, but there are several thermal limiters, they should reset when the unit cools, so likely that is not what is happening.... Forcefully turn the breaker FULLY off, and then back on, and test again...
The thermal limiters are located along the air flow path, typically downstream of your burner, the purpose is to prevent overheating and fire. These limiters stop the HEATING element and not the drum motor...
Feb 27, 2011 | Kenmore 63942 Dryer
Kenmore dryer Part# 8562458 Series 80. not heating, glow bar is not getting hot.
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Nov 25, 2010 | Kenmore Dryers
Kenmore 80 series quit heating after burning smell..
Any kind of lint or cobwebs on the element would cause a hot spot and fry the element or pop the limit that is mounted on top of the chamber. What your hubby soulda done is take the machine down and vacuum it out after sitting up so long. The fuse is not blown because it still runs so it must be the small guy pictured. It mount up top of the heat element chamber.ff8b5e7.jpg
Dec 22, 2008 | Dryers
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
KENMORE 80 SERIES NOT HEATING
you need to check the heating element and the thermal fuse in the back of the dryer, they should be their. do you have an ohme meter, if not barrow one or you can pick one up cheep and lowes or homedepo .
Dec 13, 2008 | Kenmore 659 Electric Dryer
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Dryers Logo
359 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
