Question about Ariens 34 In. Zoom Series Riding Mower
Snowblower won't start
Ariens 5520 having trouble starting it. It kicks on but won't run. It stalls as if flooded. It seemed wrunning good last time I used it. It was very cold and snow load was wet and heavty. Toay it's above freesing and raining.
  • jserge1 Feb 12, 2009
    Thanks for speedy reply. Will try that.
SOURCE: snowblower starts, but always almost stalls, then finally stalls,
gas fliter or clean the bowl on the carb and drain oll of the gas
Posted on Dec 22, 2008
  • 2692 Answers
SOURCE: My Ariens snowblower (model #924048) won't start
Dissamble carburator. Spray Carburator cleaner  through passages, and wash out bowl. Dump gasoilne if old.  Reassemble Carburator. PS count the turns on the two Jet (mixing) screws and place back into the same position after cleaning passages.
Posted on Dec 27, 2008
  • 205 Answers
SOURCE: how do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Posted on Oct 12, 2009
  • 486 Answers
SOURCE: I have a 1984 ariens snowblower with a Tecumseh and no spark
Electronic Ignition was introduced on many engines about that time frame. I would need to have model and type numbers from the engine to fully determine that question. However, have spark is still the issue. If the unit has a switch installed on the operator's console, it should be disconnected at the engine so that any safety switches are not masking or causing a problem that is not engine related.
Let's investigate a few basics first.
a) How have you determined that there is no spark?
b) Have you used a type of spark tester?
c) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug, it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Posted on Nov 13, 2009
  • 1627 Answers
SOURCE: ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Posted on Feb 17, 2010
Why do I have hard time starting my ariens snowblower when cold?
does it have a primer bulb been seeing a lot of the bulbs with cracks
Feb 17, 2015 | Ariens Deluxe 28 Model 921022 St28le 2...
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
Ariens Snowblower flooding
remove the plug and pull it over
fix the needle and seat problem in the carby
Feb 03, 2018 | Ariens Garden
My toro snowblower keeps stalling. It starts up fine, but won't run continuously.
If you haven't already, dump out gas and put fresh in it and try this, if it doesn't work you will have to clean the carb, take it apart and clean all jets ports etc and put back together and you should be Good to Blow Snow, pretty common problem with Small Engines that set half the season.
Dec 04, 2011 | Garden
Ariens sport zoom 1232.It stopped running,will not start unless
Small piece of dirt or debis under the fuel inlet needle causing the engine to flood out. I would clean the seat with a q-tip and a little jewlers rouge, polish the seat and install a new needle. Hope this helps. If it still leaks then replace the needle and seat due to it being damaged
Nov 21, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens 2 cycle snowblower runs a short time then stalls.
That sounds like a float problem. When you tip it back it is raising the floats letting the fuel go through the carb. But when back at normal it closes the the fuel feed and thus stalling the engine check the float assembly.
Jan 22, 2009 | 2002 Husqvarna TE 400
Snowblower starts, but always almost stalls, then finally stalls,
Dec 22, 2008 | Ariens 34 In. Zoom Series Riding Mower
Snowblower won't start- electric or manual - has only been used a few times and always had difficulty starting it Model 8524
Sounds like its flooded. This same exact thing just happened to me.
Let it sit with the the choke off. After a few hours, try starting it again, but don't mess with the choke (leave the choke set as if it was running hot). By your pulling of the recoil cord, you will be helping to clean out the flooded engine. Don not prime it during this excercise. (only pull the recoil 4 or 5 times).
Then let it sit again for a few hours.
After that waiting period, you should be able to start as normal, use the electroic start to get it going and lest it run, as normal.
You should then be all set.
Ariens 34 In. Zoom Series Riding Mower Logo
306 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
