Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I lost spark to the spark plug!
I had spark to the plug. The tiller fired up quickly, then died.
I now have no spark to the plug. I replaced the spark plug but I still have not spark!
What could be wrong?
    President:
  • 1,902 Answers
There is a magnet on the above the flywheel that creates spark. It is called the armature. This will allow you to get spark as long as your flywheel is good, but this is the most common cause besides electric start system
Posted on Feb 12, 2009
Tiller will not start, new plug, rebuilt carb,replaced upper oil seal, cleaned exhaust port.
You didn't say if there is a spark. Pull the plug out and hook the wire to it and ground the plug to engine. If there is spark then it is likely a fuel problem. Squirt a little starting fluid or gas in the sparkplug hole before putting the plug in and see if it fires. Pull the fuel line off the carb and check the flow.
Dec 06, 2015 | Garden
My super bronco will run but occasionaly starts missing and dies (carb is brand new) I don't think it is getting spark consistantl;y.
it could have a bad coil when it dies check for spark it's not uncommon for a coil to die when it gets hot take a old spark plug and put it onto the plug wire and hold it against a bolt pull the engine over and look for spark
May 19, 2012 | Troy bilt Super Bronco Tiller 208cc
I have a craftsman Air-cooled, 2-cycle mini tiller.
first make sure the motor isn't engaged when trying to start it, and If it has been sitting for awhile, (in between seasons), It's likely that the carb is clogged, try cleaning it out, make sure the spark plug is firing correctly. And if it's getting spark, and its getting fuel, but still wont start, then the carb may need adjusting.
May 08, 2012 | Craftsman Garden
My mantis starts easily - but then dies. it sometimes doesn't even rotate. i can do about 3 seconds before it dies. help. what do i do?
The Carb is either cracked or needs to be rebuilt - OR - you might get luck and just blow it out with a professional dose of AIR from a larger compressor like used at mechanics shops.
Gary @ Fix Ya
Sep 05, 2010 | Mantis 2-Cycle Tiller
Won't start, no spark--
un plug kill wire
or try spark tester on coil wire
Sep 01, 2009 | Mantis Tiller
Mantis tiller not firing
hello jenny - did u replace that spark plug with a new one with exactly the same numbers on it and did you gap the new spark plug according to your owner manual...........get back as i will hang in there with you on this.
Joe
Aug 20, 2009 | Mantis 2-Cycle Tiller
I have 1980's model troy built pony tiller that won't fire
Great machine, I had one. The points need replacement. Look for a gadget that replaces the points. I found mine in PepBoys. Search the Internet, the cost was about $5.00.
May 17, 2009 | Troy-Bilt Pony Garden Tiller
Engine floods,gas dripping out of carburetor,any idea what is causing this? Zama carburetor.
Obviously fuel is flowing but not being ignited. Check spark plug and replace with a new one, then check for spark using a spark testing tool if still having problems. You need three things to get it to fire: fuel flow, spark, and compression... Hopefully the motor still has good compression, but check for spark problems first.
Mar 16, 2009 | Mantis 2-Cycle Tiller
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
398 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
