Question about Polaroid 4241-TLXB 42 in. LCD Television
No picture, good audio. Replaced motherboard...
Bought motherboard from Polaroid. This fixed the problem for approx. one week now picture gone again...black screen with good audio. Help.
  • 6 Answers
I think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Posted on Aug 04, 2009
  • 1 more comment
  • gjjg Dec 28, 2010
    Do you know what the BURN switch does?
  • jd0770 Mar 07, 2011
    No, but its been 2 years and no issue.
  • garytx Jul 03, 2011
    Where's the "power board"? Inside the set?
5 Suggested Answers
SOURCE: POLAROID FLAT PANEL TV PICTURES JUST GOES!!!!!!!!!
Its under warranty
Posted on Jan 24, 2009
dsacco86
  • 1077 Answers
SOURCE: no picture on the t v
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
  • 8457 Answers
SOURCE: Polaroid Flat Screen TV not working
Ur LCD inverter board is dead.Replaced this board will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter card to replaced.The board shape is a long board.
Posted on Apr 06, 2010
SOURCE: polaroid tlx-04240b loses picture
I'm very appreciate to jranada's solution, my tv gets new life.
It's very simple to fix the problem to everyone.
My tv capacitor was not the problem.
I hope this will help everybody.
Posted on Apr 27, 2010
Horizontal lines and no picture or sound after approx. 5 minutes
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 10, 2012 | RCA Scenium HDLP61W151 61 in. HD-Ready...
No picture on tV
Yes,Ur LCD inverter board is dead.Replaced this board will get ur picture back.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Apr 25, 2010 | Polaroid TLA-01511C 15 in. LCD Television
Help me please i cant miss sunday football
More than likely the lamp ballast power supply has gone bad. If its still under it's 1 year warranty they will fix it for free. If not a good service shop will probably charge you between $100 to 200 to fix.
Blessings,
A/V Media Tech Guy.
Sep 26, 2009 | Polaroid FLM-2632 Television
Polaroid hdtv flm 3732 37''
the noise is probably due to bad caps-stiv0 has tips on how to change capacitors. I had the same noise and tv would come on after plugging and unplugging but eventually stopped coming on. I just changed the caps and now it works perfect and took approx. an 1hour and supplies cost approx. $10.00. Good Luck
Mar 11, 2009 | Polaroid FLM-3732 Television
No picture just sound
its the problem of internal video ic in your tv that has gone faulty so no video only audio you receive.the number of IC is 343ij.this component has to be replaced from the main board of the tv.
Mar 11, 2009 | Televison & Video
Polaroid FLM 323B - No picture
Problem Solved, I replaced the third capacitor (the same mf and V as the other two) and now it works great. I'd like to say "Thanks" to all of the folks who had a helping hand in this one!
Dec 02, 2008 | Polaroid FLM-323B Television
Polaroid i531 Card Error
Recuva and RePicvid are also free to recover photos. The best solution is to create a backup for the important photos to avoid loss again. https://www.gihosoft.com/free-photo-recovery.html
Jan 28, 2018 | Polaroid i531 Digital Camera
No Picture in my 1 Year Old Polaroid FLM-2632 LCD TV
had the same problem. if you take out the power supply in the back of your tv ( easy to get to just a few screws in back to get to the box then a few more to get into it and some quick disconnects) you can take it to a local tv repair shop and they can remove the two green capacitors in the upper left of the circuite panel and place in 16v ones that can actually handle the power needed. do not try to do it yourself although the new capacitors only cost 2 dollars one wrong move and you burn the wires on the board. the repair man only charged me 54 dollars well worth it considering polaroid wanted to charge me 500 to fix a 2 dollar part that should have been recalled. they are in the busines to make money but if any of us did what they did wede be considerd con artist. final note since ive replaced the capacitors my tvs worked better than when i bought it
Nov 19, 2007 | Polaroid FLM-2632 Television
Polaroid LCD only shows green verticle lines?
your picture tube is not blown you are having problem in the color circuit there is an ic that controls that circuit,the tv is also having a vertical problem an ic also controls that circuit you will have to call a tech to repair your tv good luck
Apr 27, 2007 | Polaroid FLM-2011 Television
Polaroid 4241-TLXB 42 in. LCD Television Logo
770 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
