Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster 1/3 HP opener won't close
I replaced the gears and as per directions I put door in closed position, cycled motor to open position but it won't cycle back to closed position so that I can install chain. Motor hums and then stops. There is no blinking and the eyes on the sensors are aligned. If I move the limit switch it will run but not change direction. I could use any help offered!Thamks
    Champion:
  • 244 Answers
Strange, was going to say eyes not aligned but you say they are. try over-riding by holding down wall pushbutton or jumping from red and white terminals. Did you increase down force. Are limit switch terminals moving, If it hits one, it should go back to other,
Posted on Feb 12, 2009
  • marty metzger Feb 12, 2009
    did you reinstall rpm sensor board, plug and interrupter cup.
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but door won't open. checked chain, seems to be ok
The problem is not the chain, it is the plastic gear in the unit of the liftmaster Garage Door 1/2 Hp.The plastic gear is not engaging, although it sounds like it is working.
You will have to replace it with a new one, then the liftmaster Garage Door 1/2 Hp will be able to open up once again.
Once you open and remove the old gear, Be sure to thread the screws in all the parts before you install them. Pre-threading them once would really help. Secondly, label the wires on the back of the opener before lowering it to the ladder, so you can put them back in their proper place.
Hope this was helpful.
Goodluck
Elect_Comp
Jun 27, 2011 | liftmaster Garage Door 1/2 Hp
All started when the chain got loose, I tried to force it back in place and I end up braking the gear on the top of the Garage Door Opener. I replaced the main shaft that holds that gear and put...
10 beeps signal a blockage. This is what happens: the control board monitors the current absorbed by the motor; when a mechanical fault or something else is blocking the movement the motor automatically tries to overcome it by delivering more power, in the process absorbing more current; this current triggers the warning and the door system goes in danger mode - it returns the entire unit to the original state (fully closed or fully open). This happens like that so if someone gets caught it won't gets squished.
In your case the damage is internal, in the gearing between the motor and the chain sprocket - it occurred when you have tried to install the chain. You will have to completely dismantle the motor and its gearing to see what broke in it and fix it if possible. Worst case scenario: you will need a new unit.
Jun 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/2 HP Garage Door opener won't open or close. Has been working fine until I pulled out this morning. The door will move freely if I disengage from opener. Went up ladder to see chain not...
The shaft on these garage door motors are not direct drive systems. You'll have to open up the box to see what the actual problem is. I have had stuff like this happen where a gear just slipped out of place.
http://www.aaadooropeners.com/?gclid=CLH3wt628p8CFVZS2goduwSLYQ
Here is a link for a parts supplier. I don't know your model but it looks like most of the Liftmaster worm screw gears and drive gears are plastic so it's possible that one of them has cracked.
Feb 14, 2010 | liftmaster Chamberlain Garage Door Opener...
My liftmaster 2265 1/2 hp remote does not close
If the door starts to close and the main light flashes 10 times and the door reverses to the open position it is a problem with the door sensors. Make sure they are pointed at one another and they each have a small light that must be on and not flickering.
If it starts to close but reverses and the main light does not flash 10 times it is possibly the RPM sensor which is a small printed circuit board just in front of the motor.
Nov 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens 4 inches then reverses and stops
you need to replace gear when the door is fully closed. then do your tweaking.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door doesn't open or close
You should check the gears inside the box, After years , the gears get dry and die, you can by online or from Sears the kit and replace the old gears. I just changed mine...not too difficult :) .
Mar 11, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
CRAFTMAN 1/2 HP OPENER
You say it only opens two feet?? Then closes?? If I may if you a little bit more costly option. Dont replace the gears. They used to be really good 8 years ago but the way they make the gears now there too soft and often strip out much faster. I would suggest that you do what we call a motor head change out. Take off your old chain drive motor head and buy a new one. Pretty simple. Two things though one always make sure you put the new one in with the door down. And the traveler in the down position ( The traveler is the metal thing hooked up to the chain) but far and your gear that you have it sounds to me that you dont have the gears close enough.. but 100 percent on that but a door should never close on it own. It's not safe.
Feb 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2hp won't open/close and learn LED flashes 5 times
The gear needs to be changed kit #41c4220a. Be sure to change the bottom bushing on the motor mount.
Jan 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1265LM 1/2 HP does not open or close with remotes
is chain moving. if not, gears are shot. if moving, is trolley connected.
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
186 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
