Question about JVC HD-52G786 52" Rear Projection HDTV
JVC DLP lamp blows
I have a JVC HD56G786TV. I have had it for about 18 months. I had a DLB bulb blow after the warranty expired and replaced it. Everything worked well for a month and that one blew as well. I have now blown my third lamp since the warrenty expired. Any clues as to the cause of this?
  • 14 Answers
SOURCE: Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
Posted on Dec 29, 2008
SOURCE: No picture
The lamps life span is 1 - 3yrs, Purchase your lamp directly from JVC.com $199 they back up there products. Good luck
Posted on Jan 30, 2009
  • 556 Answers
SOURCE: have lamp message in JVC HD-52Z585 to replace lamp #TS-CL110U.
I would, it's cheaper than replacing the whole TV and you can do it yourself so no labor bill. The new lamp usually comes with directions and in my experience the JVC lamps are outlasting some of the other ones.
Posted on Sep 10, 2009
ladywinn
  • 5138 Answers
SOURCE: I just replace the bulb in my JVC HD-52Z575
Ballast Board? it is what Powers Lamp, or CK Lamp Fan if it stops running and is not Keeping Lamp Cool
set is designed to shut off to Protect lamp from being burted up, you could have either Bad Ballast Board or Defective Lamp Fan,there is a few test you can do to see which Part is Bad.
Posted on Jan 25, 2010
  • 8457 Answers
SOURCE: Hi I have a JVC DLP HDtv that uses a Bulb JVC CL11...
It not the bulb,it still good.Ur tv have a problems known as convergence,"have colors shadows,colors misalinement,picture look like 3D" it dead.This convergence problems it happen to all DLP TVS sooner or later. The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts in the convergence board must be change to fix this.The shop will cost u $300-350 for parts and labors.
Posted on May 23, 2010
Tv won't power on anymore. i get a solid red light. why?
Solid red light means the lamp has failed. Try replacing the lamp first. Mitsubishi DLP TV Bulbs
These folks have the proper lamp you need and have a 6 month warranty
Sep 16, 2015 | Mitsubishi WD-60735 60" DLP HDTV
On RCA HDTV wh74xy1 lamp blows out every three months
fan has a lot of dust on it.get a can of air take lamp housing and hold fan fins and blow off dist also there is a nothe fan on dlp chip.in front. take of lower back cover easry to do.good luck
Nov 17, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv has sound but no picture.
Yes, dust is the number one cause to all electronics, i recommend using compressed air to clean the inside every month or so.
Jul 19, 2010 | Mitsubishi WD65737 65" DLP TV
Samsung HL-T5076S Tv blows bulbs about once a month
You're definitely not having a lamp problem. It can be your ballast not providing your lamp with the correct amount of voltage. Lamps should last a minimum of 1 to 3 yrs. specially if you bought a Philips lamp.
Look into your ballast. Samsung has a history with this ballast.
Mar 30, 2010 | Samsung DLP HL-P5663W 56" TV
I have samsung HL-T5076S, it blows bulb every three months or so. Its getting expensive, can you help?
Bulb life of only 3 months! You could get a bad bulb, that is possible... but if this has happened more than once, you need to look for the cause. You could have poor air flow due to dust on the cooling fans or vents. Another cause could be the lamp ballast. It supplies the lamp with power. If it is malfunctioning, it could cause the lamp to fail prematurely. If you want to dig into the ballast yourself, post back. We can get you through this repair. I hope this helps.
Mar 23, 2010 | Samsung DLP HL-P5663W 56" TV
I have a panasonic DLP TV model PT56LC70 lamp is blown and out of warranty. Dealer will not renew warranty. and manufacturer says bulb discontinued. lamp original part is luxim lifi electrodeless RF lamp (...
Just to be sure, I looked at your Model Number and found a PT-56LCX70.
I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
The part number that I was able to find was LFS4000PA1EB.
But I would contact Panasonic about this problem, they have an 18 month warranty on the lamp product.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Mar 12, 2010 | Panasonic PT-56LCX70 56" HDTV
Samsung hln5065w dlp blows bulbs
The N series, needs to be told via service menu options, what type of bulb is being installed.
Jun 23, 2009 | Samsung HLN5065W 50" Rear Projection...
Spin master 3 light bulbs blow on almost every 4 hour disco I do
I too used to purchase a lot of disco items from Maplin, however, I have found that thier products are not always the top of the range you would assume. with regards to any replacment lamp/bulb you purchase from Maplin I have found that they not only go quickly, but the ecl's tend to self destruct and last maybe 2 shows, and at the time they were £10.00 eache. I have since come accross a reasonable seller via ebay who I now purchase all of my replacment bulbs from, and they are boxed as sound lab bulbs, less that half some time a third of the price of a Maplin replacment bulb.
hope this helps
Dec 22, 2008 | Office Equipment & Supplies
How long does a lamp/bulb of a Toshiba DLP 46HM95 46 in last?
Your bulb may be blowing because of airflow issues or power cycling issues, first does your outlet get switched off at any point in time? if so you may be killing the bulb before it cools, if you turn the set on/off alot and or restart it after off quickly this could lead to permature bulb failure, if the original lamp was not replaced with a proper lamp to match the ballast it could blow the bulb. If your tv is too near a heat vent or the airflow thru the set is not adequate it could blow the bulb.
Aug 01, 2007 | Toshiba 46HM95 46" HDTV
JVC HD-52G786 52" Rear Projection HDTV Logo
174 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
