Question about GE Spacemaker JVM1640SJ Microwave Oven
The microwave stopped heating. Everything else is working fine.
I turned the microwave on to defrost some meat. It ran fine, everything was working, i.e., clock, light, turntable, fan, etc. except it didn't heat and did not defrost. It hasn't worked since. Its a GE Spacemaker JVM1630WJ03, April 2006. If it can not be fixed, I need instructions on how to remove and replace it.
  • 3 more comments
  • robgag01 Feb 12, 2009
    Same issue as above. Everything seems to be working fine, but nothing is getting cooked.
  • Anonymous Feb 12, 2009
    I have same problem, it happened all the sudden. It worked great the evening before, went to heat up something for breakfast next morn. and just heard a humm about twice as loud as normal(but not crazy loud) and NO heat! but everything else worked fine, the control panel, lights, turntable, etc. I have basic common sense/knowledge in electrical for appliances, very well versed in high and low voltage automation systems and small electronics. With that being said i had hoped to be guided in the right direction from this forum. I plan on digging into this and let you all know what i find. It seems to be a VERY common problem. In this time in all or lives it would be very cool to be self sufficient.
  • Anonymous Feb 14, 2009
    Yes, we have the EXACT same problem.
  • missflynn May 15, 2009
    This morning , I went to heat my food and there was a change in sound,a larger humm started and then the food did not heat. I have tried moving it places but it still did not heat the food.
    Every thing else works, time, clock...
    what could be the problem?
    janice gallant
  • Anonymous May 17, 2009
    I have a GE Profile Spacemaker XL 1800. Everything works but it has stopped heating. Is it fixable or does it need to be replaced?
  • GE Master
  • 9,086 Answers
GE MAGNETRON REPLACEMENT
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and your magnetron is still under the part warranty, but you would have to pay labor.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
The microwave stopped heating. Everything else is  - d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
Since it's within the magnetron portion of the warranty (5-9 years) but out of the original full warranty (1 year), G.E. will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Sometimes they will send you the magnetron to do it yourself.
If nothing else, you can save about $50-75 if you remove it from the wall and take it to a GE-authorized servicer.
You can find a GE-authorized servicer by calling GE Appliance Service at 1-800-848-7620 or here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Feb 15, 2009
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
My microwave is not heating up.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/./.,
Jul 06, 2010 | Kenmore 80012 Microwave Oven
Ok, concerning the heating issue. you will need to replace the Magnetron to restore the heating feature in this unit. this device is damaged.
Concerning the motor(circulation). If the motor is not working, this will damaged the Magnetron, due to poor circulation. i recommend replacing the motor asap.
In conclusion, you will need to replace the Magnetron and the circulation motor as well. replacing these two vital devices will fix your issues. the total cost for these parts are estimated at $87.90
Jun 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
It just stopped heating.
make sure the defrost isn't on
Apr 09, 2009 | Magic Chef MCD990W Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Ge microwave won't heat everything else works fine
Hello t_sumner4756,
Everything else can work perfectly fine but if it doesn't generate microwaves to heat your food than it is not working ( you knew that anyway).. Unfortunately, and in most cases when you microwave stops working in that manner..the components at fault are either the Magnetron, Filament PS or a High Voltage Capacitor..What that means is that you are probably better off just replacing the entire appliance rather than attempting to repair it. If it is a year old or less, bring it back to where you purchased it and have them replace it.. I am sure that is not what you wanted to hear but when the cost to repair exceeds the cost to replace... it just isn't worth repairing.. Plus.. there is an element of danger associated with these kinds of repairs...
Regards,
Rick
Nov 22, 2008 | Sharp R-303CW Convection / Microwave Oven
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
Microwave not heating up
that has happened to me twice, the only thing that you can try is to change the setting to make sure that its not on DEFROST setting, and if this is fine, they I recommend U to get a new Microwave. :)
Feb 10, 2008 | Microwave Ovens
Maytag Over the oven microwave
is the turntable working
Dec 29, 2007 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
310 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
