Question about Kenmore 15529 Built-in Dishwasher
Model # 665.15529000 will not spend water out.
Power is on. When I turn It on the wash cycle, it will fill up with water but it won't start washing. It click like it wants to start but it doesn't.
  • 641 Answers
SOURCE: wash cycle
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
Posted on Jul 02, 2006
bigg t
  • 640 Answers
SOURCE: Kenmore model 665 dishwasher
the timer is bad.the 42 min cycle and the 6 min cycle share the same timeline.try northernparts.com for the part number and price.installing the timer isnt that difficult.
Posted on Jan 05, 2008
  • 9 Answers
SOURCE: Kenmore dishwasher 58715142400 fills but doesn't wash
All kinds of qwerks with newer Kenmore units. When did u buy it?
Posted on Jan 26, 2008
IFIXALL
  • 868 Answers
SOURCE: kenmore dishwasher model 665
check for a clog at the water valve under the dishwasher.Remove lower panel of D/W(dishwasher)Shut off power supply to D/W.Remove the water supply line from your water valve(its most likely mounted underneath to the left side of frame.After removing this ,very slowely turn water back on just enough to determine if you have a clogged line. Let me know when you are there.
Posted on May 21, 2008
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Posted on Sep 04, 2009
When I start the washer cycle on any cycle, it does nothing, doesn't fill, doesn't sound like its even moving. Dryer works fine. I checked power and I seen to have power coming out of thermocouple.
when washing machine is started ( after applying the wash settings as to water fill , load size rinse etc) the first action is to turn on the water tap solenoid
from there the water fills to the set level at which time the pressure switch turns of the water solenoid and switches on the motor to start the wash
following that line of procedure , if you do not get water flowing after pressing start, the problem is in the water control solenoid , tap turned off or problem in the program board
Call in a technician after checking the other items first
Feb 02, 2016 | Washing Machines
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Fisher & Paykel wahsing machine GWL10 stuck in rinse cycle.
no power from the control board to the diverter.replace control board.it is about $150.00 for the part
Jan 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Open Questions:
Kenmore 15529 Built-in Dishwasher Logo
206 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
