Question about Optoma EP716 Multimedia Projector
Comes on but won't project from laptop
I have used this projector many times and have never had a problem, my program always comes right up and displays with no problem. Today, it's like it's not connecting, it just keeps projecting the little screen that says "searching." Someone gave this projector to me and there is no Owner's Manual. I never needed one because it has always come on. I can't wait for a manual, I have a really important presentation to do tomorrow. Anybody have a clue what I can try?
  • kmdovette Feb 12, 2009
    Figured out my combo was FN + F3, thanks.
  • Anonymous Feb 24, 2009
    my laptop was connecting fine with the projector in class in the morning, but by last class, the project would turn on fine, but would not show the image from my computer, it just stayed at the "In Focus" screen. I connected the same projector to a different laptop today and it worked fine. Is it something in my laptop settings? I've tried two different projector cables and two different projects and always the same result.
    President:
  • 2,976 Answers
Plug it into the s-video port and press the combination of buttone for your computer, that assigns a different monitor. Mine is FN + F5, yours could be different.
Posted on Feb 12, 2009
The tv comes on but no sound or picture
Your rear projection lamp is defective you need to reset the program when your replace the lamp because you already reach the hrs use of the projector. Or the connector on the lamp lose.
Sep 24, 2011 | RCA D52W19 52" Rear Projection Television
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
sonsunny
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
When connecting projector to my laptop, the picture comes up as right to left so impossible to read anything. I have tried to flip it landscape way but that flips it upside down and still reading right to...
If you push the button one more time to flip the screen it should read properly, otherwise bounce it off of a mirror and adjust the keystone if it is a permanent mount.
Jul 05, 2011 | Sharp XR-10SL DLP Projector
InFocus Won't turn off, no powering down, and no projection
The 4805 does not have a power button it has a power switch next to the mains power connector but that switch has no lights near it.
If you meant the power light on the top of the projector right next to the menu button is yellow that is bad. it indicates that the main board is not working which would explain the projector always being on. also the led being orange means that both the green and red led's are on at the same time (this is BAD)
This is not a valid function for the led's. Another indicator that the main board is wacked. By the way if you received the projector less than 30 days ago you can file a claim with the eBay resolution center that the projector is not as advertised/Described in the listing. And you might be surprised when you get your money back! the "NO RETURNS"is null and void if there was any gross misrepresentation or deception in the listing!! i.e. Not as described...
Sep 19, 2009 | InFocus In Focus SP-LAMP-021 Replacement...
Apple laptop and Toshiba digital projector not communicating
You need to TURN ON MIRRORING. Then everything displays the same on the computer & projector. This is an iPhoto limitation, which utilizes only 1 screen, not 2.
Apr 04, 2009 | Apple MacBook Mac Notebook
When trying to watch a film off the computer through the projector the colour red comes out green on the projector.
check your cable and use a different laptop or desktop to eliminate the projector. always do a factory reset.
Sep 08, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Toshiba LCD projector
always make all connections first !! after that : switch on the laptop, or else no detection of an external monitor/projection device is possible.
Please check also your bios settings, some can be set to force simultaneous display of external screen and lcd of the laptop.
some laptops also require ddc communication between external connected devices.
Try to use a full wired ( except pin 9) VGA cable.
succes
Aug 31, 2008 | Radio Shack Cinego D-1000 Multimedia...
Unresponsive projecter
You need to replace the logic board.
Aug 05, 2008 | HP VP6310 Multimedia Projector
Optoma EP721 - reverse image
Go to menu, select Projection and choose your desired projection scheme (Desktop, ceiling mounted, behind the screen, etc.)
Jun 03, 2008 | Toshiba TDP S3 Multimedia Projector
Optoma EP716 Multimedia Projector Logo
706 people viewed this question
Top Optoma Office Equipment & Supplies Experts
Electro Med Services...
Computer Links
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
