Question about D-Link DI-704P Router
Remote Desktop logging me out
I am able to connect to my remote desktop to get to my work terminal; however, after a few minutes it logs me off/closes all applications completely and I have to type my password and open all my applications again. I am also using a D-Link wireless router. Why is this happening?
  • 1,902 Answers
Try disconnecting your firewall. It sounds like your firewall is kicking you off. common problem
Posted on Feb 12, 2009
The following is a generic outline for using FTP clients since I'm not sure which specific FTP client you want to use. Where an example is needed, I'll illustrate using the ftp command in Terminal.
First, open a connection to the remote computer. This is usually done using the remote computer's IP address, e. g.,
You may be prompted for your user account name and password on the remote computer. If you are using a command-line client such as that found in Terminal, you can consolidate the login with a URL:
Once you are logged in, you can view directory contents (pls or dir), delete (rm or rmdir), upload (mput), or download (get) files. Be sure to log off or otherwise close the connection when you are done (bye).
There is not enough space here for a comprehensive description of all of the features of a typical FTP client. Many have graphic user interfaces with selector menus, file tree display and possibly even click and drag file manipulation resembling the Finder. For more details on the Terminal's ftp client, open Applications/Utilities/Terminal and type "man ftp" (without the quotes).
Jun 15, 2013 | Computers & Internet
How to Connect a Windows 7 Computer to a Windows XP
Even though Windows XP and 7 are different versions of Windows, you can still connect a computer running Windows 7 to an XP computer using Remote Desktop Connection. Remote Desktop Connection is a utility in Windows that allows you to log in to a remote computer directly from your computer's desktop. However, before you can use the utility on your Windows 7 computer, you must enable it on the Windows XP computer. To connect to the Windows XP computer, you also need to know the XP computer's name.
Enable Remote Desktop on the Windows XP Computer
  1. Click "Start" on the Windows XP computer, and then right-click "My Computer."
  2. Click "Properties" from the pop-up menu.
  3. Click the "Remote" tab, and then click the "Allow Users to Connect Remotely to This Computer" check box.
  4. Click "OK" to confirm the change when prompted on the pop-up window. Click "OK" on the open windows to close them.
Connect to the Windows XP Computer
  1. Click "Start" on the Windows 7 computer, and then type "Remote Desktop Connection" in the search box. Press "Enter."
  2. Click "Remote Desktop Connection" from the results list.
  3. Type the name of the XP computer in the "Computer" box, and then click "Connect" to connect to the XP computer.
  • ( Microsoft Support ) How to Use the Remote Desktop Feature of Windows XP Professional
  • !!!!CLICK HERE!!!!!
  • ( Microsoft Windows ) Connect to Another Computer Using Remote Desktop Connection
  • ( Microsoft Windows ) Remote Desktop Connection: Frequently Asked Questions
*please leave a rating if this information is helpful and beneficial to you.
on Jun 05, 2011 | Computers & Internet
My d-link adapter won't allow me to connect using remote desktop
Try an external usb wi fi adapter and see if that works - if so, then your initial diagnosis is correct.
Aug 31, 2017 | D-Link Computers & Internet
Is there any software by which i can work on my computer when i am away from my home ?
Hello,you can work with your pc even away from it without a software.. In Windows, Remote Desktop allows you to access your computer from a remote location. To enable Remote Desktop, you must have administrative rights on the computer you want to use as the host (i.e., the computer to which you will connect from a remote location), which must be running one of the following versions of Windows: Windows 7 Professional, Enterprise, or Ultimate Windows Vista Business, Enterprise, or Ultimate Windows XP Professional The Remote Desktop Connection client software (for the computer from which you want to connect) is installed by default on all computers running Windows 7, Vista, or XP. Enable the Remote Desktop feature on your host computer From the Start menu, select Control Panel (or Settings, and then Control Panel). Double-click System. In Windows 7 and Vista, click Remote settings. In the "Remote Desktop" section, select one of the two options to allow connections from other computers. In Windows XP, select the Remote tab. Select Allow users to connect remotely to this computer. To choose which users will have remote access, in 7 and Vista, click Select Users... or in XP, click Select Remote Users... . Typically, all administrators of the computer will have access by default. Each user must have a password before you can allow remote access. When you are finished, click OK. Your computer will now be able to accept incoming Remote Desktop connections. Open a connection If you have configured your computer to accept remote connections, to establish a Remote Desktop connection: Depending upon your network configuration and system requirements, you may first have to establish a VPN connection to your host computer's network. From the Start menu, select Programs or All Programs. Select Accessories, and then Remote Desktop Connection. In the space next to "Computer:", type the name or IP address for your host computer. Click Connect. Note: If you would like to adjust any of your connection settings such as screen size, login information, availability of local hard drives and printers, or keyboard and sound behavior, click Options before clicking Connect. In the Log On to Windows dialog box, type your username, password, and domain (if required). Click OK. Once you are connected, you can use your remote computer as if you were sitting in front of it. When you are finished, in the Remote Desktop Connection window, select Start, then Shut Down. In the Shut Down Windows dialog box, from the drop-down menu, select Log Off username, where username is your username on the remote computer. Click OK. goodluck!don't forget to rate,thanks'''''****
Feb 21, 2011 | ViewSonic VG2230WM LCD Monitor
How do i connect this terminal to windows 2003 server please give me the settings
Open Remote Desktop Connection loadTOCNode(2, 'summary'); To open Remote Desktop Connection, click Start, point to All Programs, point to Accessories, point to Communications, and then click Remote Desktop Connection.
Create a Terminal Services Connection loadTOCNode(2, 'summary'); To create a Terminal Services connection, follow these steps:
  1. Open Remote Desktop Connection.
  2. In the Computer box, type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
    Note: To connect to the console session of the remote computer, type computername or IP address /console.
  3. Click Connect.
  4. In the Log On to Windows dialog box, type your user name, password, and domain (if necessary), and then click OK.
Save Connection Settings loadTOCNode(2, 'summary'); You can save a connection as a Remote Desktop protocol (.rdp) file. An .rdp file contains all the information for a connection to a terminal server, including the Options settings that were configured when the file was saved. You can customize any number of .rdp files, including files for connecting to the same server with different settings. For example, you can save a file that connects to MyServer in full screen mode and another file that connects to the same computer in 800×600 screen size.
To save your connection settings, follow these steps:
  1. Open Remote Desktop Connection, and then click Options.
  2. Specify the connection settings that you want for this connection.
  3. On the General tab, click Save As.
  4. In the File name box, type a file name for the saved connection file, and then click Save.
Note: To edit an .rdp file to change the connections settings it contains, click Start, click My Documents, right-click the file and then click Edit.
Open a Saved Connection loadTOCNode(2, 'summary'); To open a saved connection, follow these steps:
  1. Open Remote Desktop Connection, and then click Open.
  2. Double-click the .rdp file for the connection that you want to open.
Copy Files Between the Local Computer and the Remote Computer loadTOCNode(2, 'summary');
  2. Type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
  3. Click the Local Resources tab, select the Disk Drives check box, and then click Connect.
  4. Click Start on the task bar of the remote computer, and then click My Computer, or double-click the My Computer icon on the desktop of the remote computer.
    Note: The drives on the remote server appear with the drives on your local computer. Your local drives appear as driveletter on tsclient, where tsclient is the name assigned to your (local) computer.
  5. Locate the file that you want to copy, right-click the file, and then click Copy.
  6. Locate the folder where you want to paste the file, and then click Paste.
Log Off and End the Session loadTOCNode(2, 'summary'); To log off and end a session, follow these steps:
  1. In the Remote Desktop Connection window, click Start, and then click Shut Down.
  2. In the Shut Down Windows dialog box, click Log Off username, and then click OK.
Amit Bhardwaj
Skype Id:- amit.bhardwaj4
May 05, 2010 | VXL Instruments Itona CE Windows CE VIA...
My Harmony 880 will not communicate with the computer. It just says "Communicating with your Harmony Remote. This may take a few minutes...", and freezes. How do I get it to work? I tried uninstalling the...
HI. So there are a counple of things you will have to ensure for the connectivity to be successful.
1. You are not connected to the internet via a router
2. You are not on a wireless network
3. Any firewalls on your computer are disabled
4. Your USB cable and port are good, and the remote is not connected to a USB hub but right into the compter.
Now, please do the following:
1. Uninstall the software
2. Download it again at
3. Install
4. In your computer's add/remove programs, uninstall the Logitech Desktop Messenger
5. Take out the battery, press and hold the "OFF" button, and re-insert it. The remote will display "Safe Mode"
6. Connect your remote and log in to your account
7. Click "Downloads" at the top and select "Firmware". The firmware on the remote will update.
8. Click "Replace Remote" to conduct a connectivity check.
9. Update the remote.
That should get the remote working. :)
Mar 05, 2010 | Logitech Harmony 880 LCD Remote Control
Hi i just can not see my Linksys WVC54GCA over the net, it is set up at home and i wish to see it from work
Copy this site and paste it in your ADDRESS BAR and hit ENTER.
Remote Access to Your PC or Mac LogMeIn Free gives you remote control of your PC or Mac from any other computer with an Internet connection.
Simply install LogMeIn on the computer you want to access (it takes about 2 minutes), log into your account from another computer and click the computer you want to control. You'll see its desktop and be able to use all the applications on your remote computer as if you were sitting in front of it - even if you're across town, across the country, or across the world.
  • Works with Windows PCs and Mac OS X
  • Two-minute set-up
  • 100% free
Want file transfer, remote printing, desktop sharing, and more?
You need LogMeIn Pro² LogMeIn Pro² provides full remote access so you can transfer files between computers, print documents from your remote computer to a local printer, share files with others and more. It is the complete remote access solution for mobile professionals and telecommuters.
Hope this is of some help. Bud
Feb 19, 2010 | Linksys Wireless-G WVC54G Network Camera
Remote Desktop Log In
check firewall settings and try logging in with admin accounts
Jan 30, 2009 | Microsoft Remote Desktop (V3H011652)
Remote Login Failure
This message means that the user account you are trying to use does not have rights to log on remotely. You need to go to the server, log on as an administrator at the console. Once logged in, add the user account you want to use to the local "Remote Desktop Users" group.
Jun 17, 2008 | Microsoft Windows XP Professional With...
RPC Service not running
Please restart the service of RPC.
Write the script for RPC services by the help of google ur problem will be shortout .
May 27, 2008 | Microsoft Windows Server Standard 2003 for...
D-Link DI-704P Router Logo
54 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
