Question about Compaq FS7600 17" Flat Glass Monitor
Screen fades to white 30-60 seconds then comes back.
Is this a problem with the monitor. I am under warranty for 2 more weeks
    Problem Solver:
  • 17 Answers
Well check its not the graphics card first, plug another monitor into your pc to see if the same thing happens... if it works fine then yes bring it back quick!!
hope this helps
Posted on Feb 12, 2009
Aoc led showing a line of faded pixels after regular intervals
i encounter this and found out that the signal from pc is the source of the problem and not the monitor itself mine is failing video graphics card
Jan 26, 2014 | Computers & Internet
My Acer S200hl monitor suddenly has horizontal white lines on the screen. It gradually fades from very severe lines on the right side to virtually unnoticalbe lines on the left. Any ideas?
It's dying. Pretty much simply that, something electrical or electronic (connections from panel to panel edge connectors, connection to circuit board, or internal to a panel matrix chip). Very likely unserviceable, if under warranty, take it back for service. Only other thing, check connector under back of monitor (if it has a connector at both ends). It's an Acer monitor, they aren't terribly durable, so if it's more than 2 or 3 years old, it's probably on it's way to deadville.
Dec 04, 2013 | Acer S200hl Abd 20" Class Widescreen Led...
The colour of the screen became white. There was a smoke at the back.
1. Please try to use a different Monitor just to check if you still see the white screen.
2. If you still see the white screen on a different monitor, then your video card is affected.
3. But if you don't see the white screen using a different Monitor then, I would say that your monitor is defective, now if your monitor still under the warranty, I would suggest to get in touch with your manufacturer so that they can fix or replace your monitor.
Jun 12, 2011 | LG W2042S 20 inch LCD Monitor
The monitor worked fine when we received it several months ago. Recently it started going all white, except for a few very thin colored vertical lines. I could shut it off wait a few seconds and torn it...
If this is still under warranty, then send it back for repair. If you have connected it to 2 PCs with the same results, then the problem is internal to the monitor.
Oct 20, 2010 | Computers & Internet
Bottom Half of Laptop Screen quickly fades to white!
1. you can replace it with a new screen. (expensive) 2. have a technician to repair the board of the screen, the cable, the IC's, etc. (save you money but the length of repair is very long. maybe it will take a week or two.)
your choice.
May 24, 2010 | Dell Studio 1737 Laptop
Trying to find out if this ACER monitor is under warranty
Your monitor is still under the 3-year warranty. Go to this Acer website https://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
to begin the process. Hope this helps.
Jul 09, 2009 | Acer AL2216WBD LCD Monitor
My flatscreen dell monitor fades out to dark gray, sometimes pink
Its definetely the monitor thats having a problem. when it blacks out during th monitor self test. i suggest you can ask for a replacement monitor.
Mar 19, 2009 | Dell E193FP 19" LCD Monitor
Westinghouse lcd monitor 19" - screen turns white
I have the same problem with my LCD tv... The DVI-D (white connector in the back) and the D-SUB (connector on main-board next to the DVI-D) work great for my computer. However, the antenna returns only a white screen no matter what I plug into with it using a coaxial cable. Judging by the modular configuration on the TV (1 main board with LCD monitor attached to it and the 2 computer inputs, and a smalled board on the back with the antenna, component video, S-video, mini-jack out, and composite video.) I think the smaller board which I believe is called a "NR Unit" is what has failed. I took off the back mini-panel of the TV off, which just slides off when you press down 2 tabs. And, I found the small board which is only held down by 5 small screws, and it pops right off. So, if you can find a NR board from westinghouse that works, it's a quick and easy (hopefully inexspensive) replacement. Hope this helped.
Oct 13, 2007 | Westinghouse LCM-19v1 Monitor
Dell 17inch LCD Display - Blank
Hi, My name is Todd and I'm a customer advocate at Dell's corporate headquarters. My team helps customers via blogs, forums, and other tech sites online. You said the monitor is 2 years old. Do you have the original order number still? Depending on how you purchased the monitor it may have up to a 3 year manufacturer warranty and I may be able to replace it if it is within that warranty period. Please email me at Customer_Advocate@Dell.com if you can locate the order number and I'll be glad to see if its still under the manufacturer warranty. Include my first name (Todd) in the subject line of the email so it can quickly be routed through to me, and include the order or customer number if you have it. Thank you, Todd Customer Advocate Dell, Inc. http://direct2dell.com/one2one/archive/2006/11/19/3648.aspx
Apr 25, 2007 | Dell E173FP 17" LCD Monitor
Compaq FS7600 17" Flat Glass Monitor Logo
269 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
