I have an Onkyo SKW-210 sub that has an annoyingly auto standy high input signal level (where it shuts off if it doesn't get a loud enough input signal). Is there something inside it I can tweak to lower this input signal threshold or something? I bought another brand sub before this one about a year ago (when I bought this one) and there was an internal switch that could make it always on, but I didn't like having to do that since it was annoying having to manually turn it off--and this sub doesn't even have a power switch (have to unplug it) so that's really not an option. I'd really just like to lower its sensitivity to input signal levels so it remains on even on low volume (hence the meaning of a sub in the first place!).
It has a 12-volt DC trigger input for controlling the power, overriding the input-sensing auto on/off circuit. As long as your preamp or receiver has a trigger output, this solution will solve your problem. (My Proceed AVP preamp does have two such outputs. I use one to toggle power to my power amp.)
That said, I don't use the sub's trigger input. The Sunfire seems to turn on and off 100% reliably via the input signal.
- Bob
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on subwoofer input signal level auto standby annoyance:
Solution #3
posted on Aug 08, 2005
Mini Me - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
Ah, yes, Cerwin-Vega was the brand of the sub I tried before this Onkyo. But I'm interested in the subs you've had experience with that DON'T have this problem...
Solution #4
maartenw - usenet poster
A technician would have to examine the schematic and see what parts are involved with the auto-sensing. I wasn't able to find an SK-W210 service manual, only a W200. If the 210 is the same circuit, then a mod could be worked out. Trouble is, tech time is expensive - it might cost 100.00 or more for the job.
Mark Z.
Solution #5
2Pansy - usenet poster
Have had same problem with different subwoofers. Techs tell me to just turn the switch to "ON" and leave the units on all the time. Power consumption when no signal is present is pretty low and no harm will be done.
Solution #6
Hart - usenet poster
Well, I'm not even sure this particular sub HAS a switch--but I haven't tried opening it yet so hopefully it does. Hate to waste power like that though--no matter how little. Ah well. Thanks. :/
Oh, just out of curiousity, which subs have you had experience with that don't have this problem (i.e. have higher input signal level thresholds)?
