Question about Minolta EP1083 CS/PRO Copier
Minolta CS PRO black/white copier has error code
This older machine was donated to me. When I power it on an error message says: code: COF3O. Is this something I can fix myself?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
COF30 THIS CODE SHOWS THAT THERE IS PROBLEM IN AUTO TONER SENSOR.MAY BE IT IS DIRTY .CLEAN IT PROPERLY .OR REPLACE IT.PROBLEM WILL BI REMOVED.DO NOT FORGET TO RATE A SOLUTION.MIAN JEE
Posted on Feb 22, 2009
Error code c0510 for a minolta cs pro
Change the fusing unit heatre lamp thermistor,reset the error code.
Jan 22, 2012 | Minolta Office Equipment & Supplies
Error code of C-50 showing in my CS/PRO Copier
C-05 Error code occurs on fuser unite.
When it display open back cover and press reset button.
Machine ready.If are not fix this problem.May be change or replace thermostat or lamp fuse.
Apr 06, 2010 | Minolta EP4000/5000 CS/PRO Copier
C05
Sir to fix will require you to take the rear panel off with the copier on. the upper rear panel once you have it off. Then find the circuit board on it will be a small black button, lower right side. press it. the machine will reset if it comes back your fusing unit (The HOT) part has a bad lamp thermistor, or thermosat. And will need replacing. The code will not clear by powering off then on. or by opening and closing front door.
Mar 10, 2010 | Minolta EP1083 CS/PRO Copier
Malfunction code C00 71
These codes are generally related to the toner motor, if you have changed the toner lately.Check the install of the toner cartridge, remove it and reinstall it, close up the machine and try again.
Hope this is of som help.
Ed
Apr 26, 2009 | Minolta Office Equipment & Supplies
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
MINOLTA EP5000 CS/PRO
Code COb31 means that the sorter didn't reset after a job. If you try doing a reset by opening the sorter as if there was a paper jam and it doesn't reset, it means that you have a problem with the sensors by the motor that turns the bins to open and clause as the paper passes. Give it a good blow with air. GOOD LUCK.
Nov 05, 2008 | Minolta EP4000/5000 CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
Minolta CS Pro Error Code C0070
Turn on and off WITHOUT toner bottle inserted to reset to home position. If message comes back, the toner motor/drive gears are busted. Time consuming repair, be warned!
Dec 07, 2007 | Minolta Di3510f Bizhub Copier
188 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
