Question about Kenmore 22422 Top Load Washer
Pf and of codes comming up on screen
I have a kenmore top load washer that pops up pf when you select what cycle you want to run. when it gets to the rinse/spin cycle the water just trickles.it takes about 1hour ot fill up again before rinsing and spinning
  • robert samples May 11, 2010
    the fill on your washer is determend by the flow from your house check the hoses for kinks chech the screens on the inlet valves last get a five gallon bucket and take the lines loose from the back of the washer and see how the flow is then get back to me pf could be poor fill
  • 15,935 Answers
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Kenmore he4t washer codes
The control for the washer likely detected a problem. The failure code will not be displayed on all models of washers. You can recall the error code by using this procedure:
  1. Select the "Drain/Spin" cycle.
  2. Select No Spin.
  3. Press the "Prewash" options and hold this button for 5 seconds.
  • Immediately after those 5 seconds the last stored failure code is displayed for 4 seconds.
  • After those 4 seconds the display switches automatically back to the selection mode
NOTE: If your washer does not have the Pre-Wash option. Then use the 2nd Rinse button (called Extra Rinse). The failure code should stay in the memory so that it can be recalled as often as necessary and as long as it is the youngest failure Code.
Nov 30, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Code 06
In the manual for a Kenmore washer the instruction for an F06 code (electrical problem) is :
Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN/SPIN if there is excessive water in the washer. Re-select cycle and press START.
After that, you might try unplugging then plugging it in again.
Jun 06, 2010 | Kenmore 23822 Top Load Washer
PF(Power Failure) error appears each time the washer starts.
PF simply means there was a power failure since the last time you used the machine.
To clear it - simply power cycle it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Code pf came up and the washer does nothing
PF Power failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost.
OR
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Apr 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops washing and gives a p5 trouble code
Mar 12, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore top-load washer,"Elite" touch-pad control shows "PF" , how do I reset to get a cycle start?
PF is power failure. Your home has experienced a power failure since the last use.
Unplug it for 40 minutes to reset.
Jan 16, 2009 | Washing Machines
Won't run
found a pf not an a fp
PF Power Failure PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Apr 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
My Kenmore Catalyst's control panel is flashing "PF"
PF means power failure
the power must have went out in your home some time during the day or night
Jun 21, 2006 | Kenmore 23822 Top Load Washer
Kenmore 22422 Top Load Washer Logo
187 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
