Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Blue lines I have a JVC model # AV-56WP74 56 inch projection T.V., Blue lines are showing on the screen, and messing up the colors on the t.v.
    Scholar:
  • 150 Answers
Hi, convergence amps have failed, your going to need a tech for that repair, involves un--soldering and re-installing parts as well as an alignment, hope this helps, video-tek
Posted on Feb 12, 2009
My red color on the color convergence does not match the blue and green color
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | JVC AV-56WP74 56" Rear Projection...
Color convergence drops on left side
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 13, 2009 | JVC AV-48WP30 48" Rear Projection...
Model# AV48WP30 Picture show double vision. Colors cant be adjus
you need to replace the convergence ICs and associated resistors you can get the repair kit at the following link for your model which contains the two ICs and all the feed resistors plus step by step instructions with detailed photos how to do the repair. Heres the link to the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Mar 05, 2009 | JVC AV-48WP30 48" Rear Projection...
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 started displaying vertical lines every inch
it looks like theres a wave in the top of my screen on my jvc av-48wp30 not sure but i think it has something to do with the bulbs because the projection mirror wasfine and all wires seemed to be hooked up properly.. can you help? tell me where i can find the bulbs to replace them?
May 13, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-60D501 I belive it is a 60" full screen projection tv for the last few months the picture has been flickering, Flickering like a VHS with bad tracking. It does this in all imputs, from cable imput...
From what you're describing your focus block is probably failing JVC p/n#129P059050. It's probably also very vibration sensitive. They're about $80.00 dollars and they are also interchangeable with the Mitsubishi focus pack p/n#920p016010. Not a difficult repair - we do about 5-6 a month. Real easy in-home repair. Hope this helps. Bill
Jun 18, 2007 | JVC AV-60D501 60" Rear Projection...
Red, Blue And green put of alignment- see double on screen all 3 colors off
Your convergence amps are bad. Replacement is necessary and I would recommend contacting a servicer in your area. You can find an authorized JVC serivcer at this link http://maps.jvc.com/cAscList/
Jun 06, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
138 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
