Question about Olympus FE-230 Digital Camera
Camera is not getting on - after fell in sea water
Hi my camera accidently fell in the beach.Even though it was inside the cover and inside the sea water just for few sec, it is not getting switched on. I had tried removing the mositure by removing the battery and memory and keeping in sunlight for few hours.Still no luck. my camera fell into the seawater a few days ago when i was on holidays. it was an Olympus FE-320. I've tried inserting the SD card into the computer to retrieve the pictures. what happened was that the PC can recognize it but when i double clicked on the icon of the SD card it says 'please insert a disk into drive F' and doesn't read it. I wonder if cleaning it with alcohol/isopropyl alcohol like with a camera will save the card and the pictures in it?
    President:
  • 919 Answers
As long as the xD card was not formatted it is possible to recover the images that were accidently erased or unable to be downloaded to computer. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and people have had much success in recovering lost images.
Posted on Feb 12, 2009
My camera fell into the water
What kind of water? If it is sea water it is probably gone as sea water is highly corrosive. Did you immediately remove the battery and leave it out? If not, then the water, which conducts electricity, could have sent over 300 volts from the flash circuit into the rest of the camera and fried a number of circuits. Without seeing the camera it is impossible for me to give any other suggestions
May 13, 2013 | Canon 600D EF-S 18-55 mm IS II DVD EOS...
How to fix the camera is exposed to seawater
Electronic devices do not like salt water, it causes corrosion and electrical short between components especially if the device was turned on.
I would consider your camers a write off.
Apr 25, 2012 | Sony Cameras
My Sony Camera fell in the sea water, can it still be fix? How?
Salt water damage is very bad for electronic devices, especially if the device was switched on at the time when it was dropped into salt water.
The cost of repair if you can get someone to repair it would most like be very expensive.
I would recommend you purchase a new camers, it most likely be a later and better model.
Dec 19, 2011 | Sony Cameras
I dropped my camera in the sea and it wont turn on. is it fixable?
No, sorry. Seawater is every bit as bad as crushing or fire to any unprotected electronic devices.
Your camera is a total loss. The only faint chance of saving it would have been to immediately remove the battery and memory card and to immerse it in a large bucket of de-ionised fresh water (as used in car batteries and steam irons)... not exactly the sort of thing most folks have access to at sea or on the beach. Even then the chances of saving it would have been almost zero.
Sep 02, 2010 | Samsung Cameras
Dsc-s2100
You might want to send your camera to your Sony Authourized Dealer for some technical repair. Since it accidentally fell, there might be a part from your camera that is affected by the sudden hit causing your lense to jammed.
Thank you.
Aug 01, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
L18nikon coolpix got drenched by sea water (a wave).now the screen is blank when started even though it worked well immediately afterwards.it is8.0megapixels 1600antishake AE3.0inch LCD -amritsar
Turning on a wet camera almost certainly will fry the circuits. Salt water will continue to corrode the electronics inside the camera. Start shopping and be careful next time.
Jul 27, 2010 | Nikon COOLPIX L18 Digital Camera
I have dropped the camera in sea water.from then not working.
If you ever do this again then you must immediately rinse the camera in freshwater, remove the battery and get it to a repair outlet immediately. Even then your camera will likely be unrepairable if it shows any symptoms after the accident.
Sea water is about the worst thing you can subject a camera to as it's electrically conductive. When the camera dries out, salt crystals form inside and cause physical damage and chemically attack the camera to corrode it.
Sorry, but in my experienced opinion your camera is a total write off and I don't know any professional repairers who would even attempt to fix this as it would almost certainly have to be returned to them for additional work as more faults show up afterwards.
Oct 23, 2009 | Canon IXUS 860 IS Digital Camera
It fell in sea water puddle and now LCD screen won't work
If you tried turning it on before the water finally evaporated (a week or more), you might have shorted out the screen. Also, after the water evaporates, there is the problem of the salt residue left behind inside the camera. Get a repair estimate to help you decide if it's worth the repair.
Aug 13, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
My camera fell into water in the beach and it's not coming on
no wonder! he battery would have shorted out first. Beaches are camera destroyers. I would be considering a new camera now as this one will be corroded within a fornight.
You may be able to claim it under home insurance policy as an accident. They will usually allow replacements on personal goods and accidents like this. Definitely worth a try.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Aug 09, 2009 | Samsung S760 Digital Camera
Camera was dropped on a hard deck or into any water solution.
My Answer:
Whether your camera was dropped into any water (or onto a hard deck for that matter) - even for a split second - the damage has already been done. Esp with the "hard deck" drop.
Unless your digital camera is a totally "100% waterproof down to X number of feet" sports digital camera, or quite possibly a "water-resistant" sports digital camera I'm afraid you got water into the "lens barrel" area of the camera and that usually is just as FATAL as getting water into the camera anywhere else as well. Esp if it's SALTWATER!!
Saltwater will destroy any camera (or anything else electronics for that matter) just as bad as leaky batteries will. Once those micro circuit-boards get that acidic saltwater or batt acid on them it's only a matter of time before TOTAL FAILURE.
Sometimes it's immediate, and other times it takes awhile for that saltwater/acid to do it's damage inside. But it will happen - as I know very well from all my years of repairing electronic equipment no matter what it was - Marine environment stuff as well.
See - those saltwater crystals left behind never go away once the water evaporates. Only way to possibly get that saltwater out initially (out of anything electronic dropped in ocean water btw) - with any luck - is to first remove any and all batteries from the damaged electronic item(s).
Next - squirt ALCOHOL (91% or higher rubbing alcohol, or better yet 99% Isopropyl Alcohol) into the openings where you suspect the saltwater got into the camera (or other items) to begin with, and then hold the camera with the lens barrel facing down while shaking the excess Alcohol out. Just letting the excess ALCOHOL drain out by itself won't do, as you need to get out as much as possible thus carrying the saltwater by-chemicals out with it as well.
If you have a compressed air source - no higher then say 20-30 psi, or a LPHV (Low Pressure High Volume) regulated air pressure source - use it instead to forcefully blow out any and all Alcohol as best you can.
Next - take the flushed out camera and open up any access panels, memory card slots, battery port doors, display panels, etc and place the camera in a kitchen oven that uses GAS ONLY, and with ONLY the PILOT LIGHT burning leave the camera in there for no less then a complete week (7 days)! NO LESS then 7 days!
That low PILOT LIGHT ONLY heat temp ( < ~ 110-115F ) will never harm anything electronic (as I use mine all the time to naturally dry things out that have gotten wet for one reason or the other). It will thoroughly dry out the camera insides and hopefully remove all traces of moisture and salt residue! Hopefully!
If you keep using that camera without at least doing the above FIX with Alcohol - after you have exposed it to saltwater - then I'm afraid your camera will have suffered unrecoverable internal damage and will fail totally at some point thereafter.
Saltwater and Electronics DON'T MIX - plain and simple.
Same goes for any camera that has been dropped on the "hard deck".
The guidelines and consequences of a dropped camera are listed below as a general guideline of what NOT to do, what to do afterwords, and what to do to try and prevent a camera drop to begin with.
I'm afraid that "drop", or "small drop", or even that "very big" drop you - or anyone else here posting - spoke/speaks of was more like that of a camera ending life - as related to all digital cameras. No matter how much that ?-year old ???? camera cost when new.
Not all digital cameras are created equal, and if you are an active sports person, or something close to it whereas your camera is subject to or exposed to this kind of rough treatment then you might want to consider doing several things from now on.
Unfortunately it sounds like you dislodged the imagining converting pixel matrix chip and/or the related optical components that convert the optical picture information into digital information that is processed to the memory card for storage.
You may have even possibly dislodged some PC connectors (printed circuit board connectors) inside the camera. Not to mention pulsed servo motor drive components as well.
Each camera is different as to how many individual circuit boards they have inside. Could be 3-4-5 or more. Each is interfaced by a paper thin flat interface type cable and it's possible that particular board cable could be damaged as well. Hard to say. Very very complex inside!
I've had a few destroyed digital cameras apart myself (that people gave me to try and fix) - just to see how they were put together, as I knew they were toast right off the bat in less then 5 mins after looking at them. If it wasn't bad batteries leaking inside and destroying the many smaller circuit boards inside, then it was dislodged and broken parts inside from being dropped.
In any case - each digital camera I had apart WAS NOT worth repairing if taken into an authorized repair dealer or even the main factory repair outlet. Esp if it is/was a SONY!! Sony anything is really not worth the repair charges they want today. Totally ridiculous as they charge you roughly $35-50 today just to even look at whatever is broken of theirs. Then comes the actual repair cost on top of that. I won't buy anything of theirs anymore, as they burned me twice before years ago - and twice was enough....
Not so with Olympus and other digital camera makers! That is why all my cameras today are Olympus because of the GREAT factory warranty or out of warranty service I received past to present. They are the best in my books and I have NO TIES AT ALL to them in nay matter or form!
One thing I should mention here regarding digital cameras in general, as with all 35mm film cameras as well is this.
With digital cameras that cost less then $200 (esp those under $100), and those that are say 3 to 5 years old already - if they break internally for whatever reason (ie: batts leaking - worn out drive motors - dropped camera - water damage - etc) they are considered THROW AWAY CAMERAS and NOT WORTH FIXING. Plain and simple - all sentimental attachment aside btw. Always remove and keep the Memory Cards before throwing out any damaged "beyond repair" camera though. The cards can always (possibly?) be reused on your next digital camera purchase.
With any new camera purchase over $200 it's always an added decision whether to buy the 2 or 3 year EXTENDED WARRANTY - as related to the added cost. I know I would have, and I have done so on my $400+ higher ended Olympus 35mm film camera not only because Olympus builds the best and are renown for their lens QUALITY worldwide, but because I wanted the extra PEACE OF MIND knowing an act of God or Mother Nature could occur at any time. It just made sense to me at that time!
Continued below:
May 27, 2008 | Pentax Optio S5n Digital Camera
Olympus FE-230 Digital Camera Logo
133 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
