Question about Sony Ericsson W380i Cellular Phone
SE W380. Won't even power on.
Had it for less than a year but threw out the receipt. No matter what I do, it just won't show any sign of life. Bought it BNIB.
Looking for somewhere in the Toronto region that can repair them.
  • eheskey11 Feb 13, 2009
    And how do I go about doing that?
    Problem Solver:
  • 11 Answers
Your phone need a bloody good clean and then it should fire up
Posted on Feb 12, 2009
Casio hr100tm won't print, shows E, won't feed paper. It calculates in On mode only.
mi sumadora, de repente se queda en E y no me deja seguir sumando cantidades que solucion tiene esto
Aug 22, 2012 | Casio HR-100TMPlus Calculator
Lamp light flashes and tv won't come on
It could be the lamp depending on the replacement you installed. Some of the Generic last a year or less--original or OEM have a 2,000 hour life and that determined by how much set is on.
First thing to look at is lamp.
NOTE: at the time this set was made in the menu was a Quick on feature---it runs the lamp all the time(when set is off it dims down but does not go out) THIS FEATURE WILL IF ENGAGED DRASTICALLY SHORTEN THE LIFE OF THE LAMP not to mention using more electrical power in your home.
SD TECH
Apr 22, 2012 | Televison & Video
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 25, 2011 | Acer Computers & Internet
I purchased lenovo z 570 laptop.clarification of regarding battery i am making 0 battery for every 15 days. (A) BATTERY is fully charged (100% ) , even though iam keeping plug in socket & using...
Not really, the older NiCad batteries get a memory effect if you keep charging from a half charged state, but modern Lithium batteries do not suffer from this problem.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.These rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 10, 2011 | Computers & Internet
My Sony Trinitron KV27EXR25 won't turn on. The "on/off switch" on the front seems to engage (tic-tac sound) but nothing powers up nor do any lights blink, flash or show any sign of life (I...
You will need to check the continuity of the main line wire which goes to the main switch and then to the SMPS. in most cases one of the POLES of the switch can fail If so replace the switch after checking the continuity with a multimeter. If power goes to the main board then the fuse can be open and so the SMPS could have failed. Also check for dry solder joints in the main board. Take precaution with HT circuits.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
Sep 03, 2011 | Televison & Video
We can put in the minutes and temp., then when we close the door the clock times down and the fan blows, but nothing cooks. Fridgidaire model cfmv156fmc. For a while if we put a piece of cardboard in by...
I threw mine away because frigidaire would not do anything for it and was less than 6 months old . local dealer would not look at it as we bought from a big box store not them .
Dec 09, 2017 | Frigidaire Microwave Microwave Oven
Zune 120 GB My Zune hasn't been used I bought it in 2008, still have the receipt and everything. So when I decided to put it in use... It won't turn on. the logo will come on the screen and it...
Unfortunately, batteries have a shelf life. If the player sat for three years without being charged, the battery is probably bad. The chemical reactions inside the battery continue, even when it's not charged.
My advice is to replace the battery if possible.
Jul 15, 2011 | Microsoft Zune JS8-00001 Digital Media...
My Pentax Optio M90's Flash has stopped working.. it doesn't matter if I have selected the flash to be on or off it still won't work. Even when setting are set at auto it still won't work...
Hi kerritm,
This indicated that it's time you need to replace your flash , therefore you can get it done via a service center,
The camera's flash has a certain life and you can't expect it to be ok for many years together ,
In unfortunate cases , it stops working due to hard ware failure.
Therefore , Please get the flash replaced and you would be able to use it.
Hope this helps..:)
Jun 19, 2011 | Pentax Optio M90 Digital Camera
Hello, the battery on my dell vostro 1500 is fully charged, at 65% of its life and passes the dell diagnostic tool, but.. when i take out the plug the battery fails in less than 5 seconds. any help is...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 05, 2011 | Dell Vostro 1500 Notebook
Tom tom 125.se will not recharge battery threw my lighter type power supply. i put this lighter power supply in myself it runs other thing just fine . it just won,t recharge the tom tom battery.
You have another option. Connect the GPS unit to a USB port on a computer. And please use the USB cable supplied with your unit.
Dec 30, 2009 | Tomtom GPS
Sony Ericsson W380i Cellular Phone Logo
97 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
