Question about Craftsman 10" Table Saw
Blade does not turn
I was cutting a piece of 1 1/2"x 6"wood plank with a Craftsman10" table saw.The board kicked back slightly and the blade stopped. I turned the saw off and back on and the saw motor hums bud the blade is froze. Where do I start?
  • Anonymous Mar 24, 2014
    the blade/motor doesn't stop and it smokes
    President:
  • 2,692 Answers
Disconnect the electric from the saw. Remove the throat blade cover. Bring the blade all the way up. Look for wood  caught between the blade and anything else. Finding none,remove blade. Try motor w/o blade. If it runs now,w/o the blade then the motor is likely ok . Reinstall blade. Now if it stil stalls, Replace motor.
Posted on Feb 11, 2009
Working on a plank 5' long 10"depth a thickness of 1.5" will a scroll cut into this hollow plank to a depth of 5"then go across 1.5"then return 5"
Cole, The cut you are describing is challenging, but possible on a 20" scroll saw. First the blade--- you call this a hollow plank. If this is something like a hollow-core door, then the 1.5" thickness will be no problem. If you have to cut through a solid 1.5" (as you would at the edge) then you have a slow go of it unless you can find a pretty coarse pitch blade (big teeth). Second, making the turn----- assuming you are making this cut somewhere near the center of the 5' lenghth, then you won't be able to simply make a 90 degree turn after you cut the initial 5 inches. But you can make an approximately 60 degree turn, then stop the saw, leave the workpiece in place with the blade still in the cut, and reset the blade to cut sideways (so that the teeth of the blade are facing to your left or right rather than pointing toward you.) Before you make this blade turn, however, you should make the other 5 inch cut, so that you don't have to make the blade turn twice. Alternatively, if the 5 x 1.5 piece you are removing is just scrap, then you can make your two 5 inch cuts just converge to a point at the middle of the 1.5 inch line so that you can remove most of the scrap without moving the blade. Then you can reset the blade more easily with the workpiece removed from the saw. I hope you found this helpful.---- Oh, one more thing! The 1.5 inch part of the cut would be a lot easier simply by using a coping saw - they are about $15. Actually, you could do the whole cut with a coping saw. Good luck! Al K
Jul 29, 2011 | Dewalt DW788 Heavy Duty 20" Variable Speed...
I bought a ls1016 coupond mitre saw this week. I was cutting cedar 2x6 's today and had a few kick backs. I am building my deck and do not feel safe using the saw after the kick backs. Why as this...
Sounds as if the blade is dull. Or perhaps bent. A dull or bent blade blade will 'grab' the wood, rather than cut it, resulting in binding, or kickbacks.
Solution; replace the blade with a fine-toothed, good quality blade. If the blade is new, then check that the blade is bolted tight on the arbor. If the blade is loose, it can result in kickbacks.
Also, check that all the bolts/fasteners/locking mechanisms on the saw are tight, and in good working order. Sometimes a tool new out-of-the-box will have loose screws/nuts/bolts that need to be tightened up.
Also, when cutting, use a smooth, slow, motion, being sure to give the saw the time it needs to make the cut.
Jun 19, 2011 | Makita LS1016LX 10inch DualSlide Miter Saw...
Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Dec 30, 2010 | Craftsman Saws
I'm a wife with a do-it-yourself knack. I recently purchased a Ryobi 10 in. BTS211 table saw. I find the manual complicated as far as how to actually use the device. Can you recommend where I can get...
I am a retired contractor.
I have a shop with a 10" table saw.
And I have opinions about safe operation.
For safety, turn saw off when making adjustments.
1) Raise blade:
There is a handle you turn to raise the blade.
If you are cutting 1/2" plywood, then set your blade at 3/4" or a bit more.
Keep blade low and away from hands.
Keep hands high and away from blade.
For 1-1/2" thick 2x4, I usually set the saw at 1" and run the board through, and then flip the board over and run it through again, taking 2 passes to make really thick cuts.
2) Blade angle
There is a second handle you turn to set blade at an angle up to 45 degrees
Angle cannot be set if saw blade is fully raised >> lower blade to half way or less and experiment.
Angle cuts are difficult if wood is not perfectly flat and square, or too long or too short (boy is that helpful ... but cutting angles takes some experimentation)
3) Table Guide
You stand behind power saw to operate
The saw table guide is on left side of blade and clamps across the table
The guide markings show inches >>> these are usually approximate
To set guide for accuracy, measure distance from blade to saw guide, and then clamp guide down.
4) Push sticks push sticks push sticks and other safety stuff
Let me emphasize safety first last and always
A table saw will chop your fingers off in a blink
On the plus side, I hear it doesn't hurt. But OMG.
There is a very strong human instinct to reach in with your hand when working on stuff
Train your mind >> if the saw is running, do not lean or reach into the saw
If a board is stuck >>> turn off the saw and wait for full stop
If you wear baggy clothes of a loose shirt, the saw will grab you and pull you in too fast for you to react
Keep your clothes tight and your arms bare
Always use push sticks or push boards::
Notice the saw blade is set low
Two push sticks are used to assist when cutting short board > one stick holds down the board ahead of blade, the other stick is pushing board through saw.
Keep your hands away from the blade no matter what.
The person stands behind and to the side of the board being cut.
The cut wood is supported by a catch table (in this case there are rollers)
Where to stand
Obviously you stand behind the saw to cut wood, and sometimes with long pieces, you can move in front and pull them through, and sometimes with large plywood you stand kinda back and to the side.
Why not stand directly behind a saw? Because saws throw stuff back.
When 'ripping' a board lengthwise as shown in photo above, if the saw catches the board just right, it will throw it backwards like a spear.
If a board 'binds' the saw causing saw blade to stop, then turn off saw, back up the board, and cut again.
Crosscut guide
The saw comes with a T-shaped guide that fits into a groove.
This is a 'push stick' >>> you use it to cross cut a board, and it lets you stand to the side of the saw blade so things wont flip back on you
When using the cross cut guide, remove the table guide that clamps across the saw, or push the table guide WAY back so pieces don't get caught in a bind and the blade flips up the piece and hits you in the face
Remember, the saw throws everything backwards
The saw is strong and fast, and you are best when traveling slow and without rush around your strong friend.
Oct 15, 2010 | Garden
Saw worked fine until today. Kicks breaker withing seconds of starting. both 15 and 20 gfci's kicking within seconds.
What I would check for and follow closely, is UNPLUG tool turn blade by hand to make sure it turns freely, there could be a piece of offcut wood jamming the blade. then turn it on its back or however you can to see about cleaning with compressed air, check the cord condition for breaks if all the above checks out and sounds like you have tried different power sources you have an electrical short and troubleshooting this is involved.
Oct 03, 2010 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Wood feels like its "pinching" between blad and fence
Possibly the problem is the wood itself. If it is burning both sides of the kerf then it is probably that your kiln dried wood is picking up moisture on the outside from the environment which causes it to bow inwards as it passes the saw. I have even had this problem with plywood. Just keeping timber in an unheated workshop for a while can cause the problem but after a few months it should equalize and the problem disappear at about 15% moisture content. (kiln dried timber should be nearer 10%)
Cut part way along a plank and then mesure the kerf at the end of the plank and at the front of the cut. if it is significantly narrower at the plank end then that is your problem.
These hard woods you mention are always a problem to cut on domestic saws at usually a maximum of 2000 watts . I use a 4500 watt motor in my saw and it will still complain at dry oak, ash and maple etc. especially if they are moving a bit as I cut them. Before I retired I had a panel saw half as powerful again as that and still those hard woods could cause trouble.
Jun 01, 2010 | Craftsman 10" Table Saw
I have a Craftsman 10" table saw model number: 137.248830. The saw doesn't make square cuts, it is more of a problem when using the miter. I have followed the alignment procedure so that the right...
I assume that your alignment procedure is about adjusting your miter gage. But you should first verify if the blade is parallel to the miter slot (the slot the miter gage slides in). This is adjustable underneath the saw, and sometimes comes crooked from the factory or comes loose later on. To check if the blade is parallel to the miter slot you can do this.....1. unplug the saw. 2. Raise the blade as far as it will go. 3. Clamp a piece of wood to your miter gage so that it just touches the blade as close to the front of the saw as possible. 4. Use a marker and mark that spot on the blade. 5. Now slide the miter toward the back of the saw, and rotate the blade by hand so that your piece of wood hits the same spot as where you checked in the front. You can see a large misalignment by eye. But you can get a little precise by using a piece of paper between the wood and the blade as a feeler gage. Or better yet, use a drop indicator instead of the piece of wood and you can measure the difference. If this isn't as close to parallel as you are able to measure it, you need to turn the saw over and find the bolts that attach the whole assembly under there to the table top. Once you have this in alignment, you should be able to set your miter to be square against any good square. If you don't have a high quality square, you can go to a tool store (Sears or whoever) with your miter gage in hand, and set it to be square against their most expensive square. If the square is square, and the blade is parallel to the slot and it still won't cut square you either have a bad blade or there is too much play in the saw's arbor. Try to wiggle the blade side-to-side - any wiggle at all is too much.
Jan 20, 2010 | Craftsman 10" Table Saw
Fix hardwood flooring replace damaged hardwood flooring wood planks
During the whole process be aware of the edges of the flooring that is going to stay. First prepare the area for dust control. Mark the boards to be replaced. With a flat wood bit in your drill, bore a hole near, but not at both ends of the pieces being replaced. Bore only to the sub-floor. Set your circular saw to cut thru the flooring but barely touch the sub-floor beneath. Make two passes with the saw about 1/2" in from each edge. Lift out the center of the piece being removed. With a sharp chisel split the small end pieces at each saw cut and remove. With a chisel, tap the groove side of the piece toward the middle and remove. There may be a little chisel work to get it out. There will be a bit more chisel work on the tongue side. Chisel the tongue side until the fasteners are located and remove them. Remove the piece completely and remove any paper between the flooring and the sub-floor. Vacuum the area to prepare for the new board. Lay the new piece next to the opening and mark the length. If this is end match, t&g at teh ends cut the ends square. I mark heavily and leave my mark when I cut. It can be cut again if it is too long. Choice here are, cut the bottom of the groove and or the tongue off the new board. I leave the tongue and hook the piece in place. Easier to remove it though. Back cut the length on a table saw, being careful not to reduce the size of the face. This will make the bottom of the board narrower than the face. A sander can be used if no table saw is available. Once sized put glue on the sub-floor and put in the replacement piece. If the tongue was left, it must be tapped sideways to get to the point where it will drop in. Do not hit the wood directly. Used a scrap piece as convincer. When lined up, use a scrap piece of wood to drive the new piece down into place. The new board will be thicker and will need sanding. Congrats.
Dec 29, 2009 | Saws
Hi, Just bought a new Ryobi ETS-1525SC table saw and I cannot stop the blade moving awy from the plank and tapering every cut. I've checked the blade is 90 degrees and checked the rail, but for every 1...
Ive seen this before. The sawblade that comes with the unit isnt very good. Upgrade to a good carbide blade from craftsman or even a dewalt/vermont american. Also slow your cut down an let the saw do the cutting. Hope this helps
Nov 19, 2009 | Saws
Delta 10
Replace the blade. It is very dull. Cherry is very hard wood and should be only cut with a very sharp blade.
Nov 13, 2008 | Saws
Craftsman 10" Table Saw Logo
367 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
