Question about Rolex Datejust SS
How do i use the watch band link tool i just got with no instruct
Bought a watch band link remover tool with extra pins, but can't figure out how to use it, as it came with no instructions. It has a handle that acts as a screwdriver, but i can't get it to push the pins out of the link - anybody know what i'm talking about and how to help???
  • 2,334 Answers
Rolex is using screws instead of pins. Get the small screwdriver and unscrew the bracelet screws.
Do not forget to rate, please.
Posted on Feb 12, 2009
How do I remove a link from the Stauer Colossus Hybrid Chronograph
Removing a link from the wrist band of the Stauer Colossus watch is a task that requires some mechanical talent. The links are held together with pins. These pins need to be pushed out. I strongly recommend the purchase of a "Watch Band Link Pin Remover" (got mine on eBay for $7). Prepared with this tool, the steps are as follows.
a) Separate the wrist band at the position where the strap and latch are held together. Careful! This pin is spring loaded.
b) The links that can be removed are marked with an arrow on the interior side. The pin should be removed in the direction indicated by the arrow.
c) With the previously mentioned tool you will be able to perform the hardest part, namely push out the pin by 3/16". In the image below note how the pushed out pin goes into the groove of the tool.
d) Use a small screwdriver or a punch with diameter of less than 0.07" (or 1.8 mm) in order to push out the pin completely (see second picture).
The push pin of the tool can be reversed which is helpful for re-assembly. I recommend smoothing the one end of the pin with a small file or sandpaper. This way the pin enters easily into the hole of the lower section. Else you run the danger of bending the link if the pin is not correctly positioned and you apply too much force.
Oct 24, 2012 | Watches
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    How do I reduce the size of a metal watch band to fit my wrist better
    mcdevito75 here, You"d need a special tool called a link pin remover, BEST BET, look for a small watch repair shop in your area, hold onto the extra links once removed as you may need them again.
    Jul 12, 2010 | Watches
    Is there any way to adjust the band without a special tool?
    Use a sturdy pin or thumbtack to push out the pin from the little hole on the link.
    Make sure to examine the watch and which links have pins. Some watches are designed to have a row of removable links with pins.
    Remove one end of the band from the actual watch itself. Then remove links as you see necessary.
    You may need to use something a little stout like a butterknife to tap the pins out from the links.
    The pin on the watch itself has spring loaded tips, push them in and it should release the watch from the band.
    Oct 04, 2009 | Festina 16177 3 Watch
    Want to fit a watch band. take links out.
    You need a link tool. You can purchase this item on Ebay or watch parts sites. Some have a little track that you put the band on and screw a pin into the pin on the band and it pushes the split pin out and you remove the link. Pay attention to the pins on the band. You need to push out the side with the split pin that looks like a flathead screw. It sometimes is. In most cases it is a pin. When the link is removed you have to connect to the next link and push the pin into the hole again and it shoul go in the direction of the other pins. The pin should go in on the side with the split looking pins. You will need special tools: pin pusher device, a pin block and hammer with pins to hammer out the pins on the band usually. Some or most folks take classes to learn this but you may be handy and figure it out.
    Dec 03, 2008 | Invicta Watches
    How to remove link from band
    The segments of your bracelet are held together with friction pins which have to be removed first in order to adjust it. This is a relatively complicated task requiring experience and a special tool to remove and return the pins and bushings back correctly without compromising the bracelet strength.
    I recommend taking your watch to an Omega authorised dealer for adjustment while you wait.
    Nov 09, 2008 | Omega Seamaster 2541.80 Wrist Watch
    Wrist band adjustment
    In addition to the Pin there is also a small inner "locking" collar about 2mm long that fits into the center section of each link.
    I did not notice this collar at first and it fell to the ground when I removed the first link. Without this piece the Pin's will just slide through the links with no locking mechanism.
    It fits neatly into the inner portion of the link directly opposite the arrow that shows the direction of removal on the band.
    Jul 01, 2008 | Casio G-Shock G7000D-8V Wrist Watch
    Fossil watch band adjustment
    throw the ******* thing away
    Dec 26, 2007 | Fossil AM3695 Wrist Watch
    Rolex Datejust SS Logo
    217 people viewed this question
    Top Rolex Watches Experts
    Samyfam
    Samyfam
    Are you a Rolex Watch Expert? Answer questions, earn points and help others
