Question about Element Chromalox SG1353-430326 Electric Replacement Water Heater
How do you know if it is the element that is bad or the therm-o-
The heater is giving less hot water than before-hot water runns out quicker. it has a 4100-59T on top and a 4000-59T on the bottom. i get eletrical continuity through the whole serquit. How can i tell if it is the element or the therm-o-disc that is bad or ?
    President:
  • 2,692 Answers
Disconnect the electric for the unit. Disconnect the two wires from the two eliments. Place a battery type test light or Ohm meter is more conclusive if you have one, Light should light when placing the two test leads to the two eliment contacts(while they are disconnect for the water heater wiring) should be dim but glowing. If no light the the eliment is open. If an Ohm meter the Wattage is written on the heater the heater. E=IR P=IE. It should work out to about 1200 -1400 ohms if 220 volt heater. If the light is bright just as if you had put the two test leads together,then you can say that the eliment is likely shorted. Either no light or a Very bright light requires the eliment to be changed.   To check the thermostats, Raise the ajustment one one at a time, until it clicks. Listen for the heater to be heating. Turn that one back down and do the other one the same way. I hope I have been clear enough. About one gallon of water should be drained for the bottom of the tank once a year along with checking the preasure/tempature safety relief valve by  operating it ,using the leaver,for  a few moments as preventive maintenance.
Posted on Feb 11, 2009
    President:
  • 1,902 Answers
The element will start to leak if it breaks sometimes so you can tell that way. The other way it might not be heating properly is if there is to much calcium build up on the element itself.
The way to check the thermo is to check for continuity. If it is closed then it is good. Open it is bad This is of course wit the power off
I have a Rheem Marathon 105 gal. electric hot water heater. No hot water ....
Check 240 circuit breaker.
Open top cover on water heater and push in ECO red reset button.
If reset button will not reset, then replace thermostat.
If reset is not tripped out, then either upper thermostat is bad, upper element is bad, or water heater might be getting 120V instead of 240V.
If you have some hot water, then best suspect is lower element.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 26, 2011 | Rheem MR105245 Marathon Electric Water...
I no hot water coming out. Have power to water heater.
Electric water heater is not making hot water.
That gives 4 suspects.
1) Breaker is not delivering 240V to water heater on both legs.
Open following link for checklist troubleshoot.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
2) Upper thermostat ECO reset button has tripped. Open top cover and push in reset button. Put insulation and cover back so thermostat not exposed to cooler air. If problem persists, replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Upper element is bad. If upper element goes bad, the tank will not have any hot water, even if lower element is good.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-it-works.html
4) Water heater is overheating and ECO reset is tripping.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on water heater or any do-it-yourself project.
Feb 22, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The water pipe to the hot water connection broke, after repairing the pipe, the water heater does not work. Is there an emergency shut off valve or something on the unit that would have shut off. I have...
For a price, expert works with you via e-mai l while you work on water heater or any do-it-yourself project.
Feb 22, 2011 | RELIANCE ELECTRIC WATER HEATER
Hot water runs out to quickly. Replaced bottom element but did not help.
If dual element water heater has some hot water, that says certain things.
-Water heater is getting 240V from breaker.
-Upper element is working
-Neither element is shorted to ground
-Factory insulation and covers are in place and thermostat not exposed to cool air.
-ECO reset is not tripped and there is not overheating event.
-Water pipes and heater are not clogged.
Here are remaining suspects:
1) Leaking faucet or TP valve is leaking hot water continuously. Check for leaks.
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) Loose wire/ bad wire between upper and lower sections of water heater: remove covers and check for loose wire and signs of high heat and burning.
Also do full troubleshoot:
3) Bad lower element
4) Sediment build up bottom of tank:
Sediment build-up causes lower part of tank to heat slowly, so upper part of tank can cool, and tank has less hot water.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
5) Bad upper or lower thermostat: Replace both thermostats for $28.
To preserve tank and save money long term
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Feb 20, 2011 | RELIANCE ELECTRIC WATER HEATER
No heat the water.
Suddenly no hot water: Red reset button tripped, circuit breaker tripped, bad upper element, bad thermostat, loose wire, TP valve is running hot water out of tank, leaking faucet is running hot water out of tank.
1) Check for leaks.
2) Check circuit breaker.
3) Open top cover on water heater and push in red reset button.
If reset is popped out and will not reset, replace thermostat:
4) Test upper element:
5) Loose wire
Do full troubleshoot:
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 01, 2011 | RELIANCE ELECTRIC WATER HEATER
It has cold water comign out no hot
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Jan 18, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a Rheem Model # 62SV-520 and I loose hot water after about 10 minutes in the shower. I think one of the heating elements is bad, but if so, which one.
There performance depends on your demand. If you are using an energy saving shower head I would expect you to have enough hot water for easily a couple of showers. But, if your using the "power flush" type shower heads that use 3.5 gpm or more, the 40 gallon heater is not enough. Also, consider type of water your heating. Is it well water or municipal. Unsoftened well (this includes some municipal well supplies too) water causes hardness ions to cake the heater element making them less efficient. If you have the low flow shower, it is likely you have an element burt out. They can simply be replaced and picked up at any big box store for less than $20 dollars. Each element can be tested in place with a continuity tester. If your not sure how to test, but would be willing to replace the elements - replace both of them. You will have to shut off power to heater and drain tank completely before removing elements. Replace elements with same wattage or higher. Most have two 2250 watt elements for a total of 4500 watts. you can easily install two 3000 watt elements and have a quicker recovery rate and more hot water than ever.
Jan 03, 2011 | Rheem 81VP6S/430126 Water Heater
Not enough hot water,running out before I'm finished showering.
Hot water heaters are a touchy thing. There performance depends on your demand. If you are using an energy saving shower head I would expect you to have enough hot water for easily a couple of showers. But, if your using the "power flush" type shower heads that use 3.5 gpm or more, the 40 gallon heater is not enough. Also, consider type of water your heating. Is it well water or municipal. Unsoftened well (this includes some municipal well supplies too) water causes hardness ions to cake the heater element making them less efficient. If you have the low flow shower, it is likely you have an element burt out. They can simply be replaced and picked up at any big box store for less than $20 dollars. Each element can be tested in place with a continuity tester. If your not sure how to test, but would be willing to replace the elements - replace both of them. You will have to shut off power to heater and drain tank completely before removing elements. Replace elements with same wattage or higher. Most have two 2250 watt elements for a total of 4500 watts. you can easily install two 3000 watt elements and have a quicker recovery rate and more hot water than ever. Good luck.
BW
Nov 27, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Should I drain and ?clean? out the water heater...13+ years.. model pgcs 50 102H It runs out of hot water increasingly quicker
I assume your is an electric hot water heater. Is your water "hard" in your area? If so, it would be worth a try. What usually happens in a heater your age is that sediment builds up causing the lower element to overheat and burnout, causing less hot water to be produced
Mar 03, 2010 | Water Heaters
Water not getting hot
You seem to have a burned out heater elemt. Most water heaters have 2 e.ements. If the upper one bruns out, it will not heat at all. If you have a cheap heater built by State, you probably have a bad lower thermostat. It will over heat and trip the protection device. If you reset the red button on the upper thermostat and it gets too hot (check in about 2 hours) then replace the lower therm. You could still have a burned out upper element.
Mar 31, 2009 | Water Heaters
Element Chromalox SG1353-430326 Electric Replacement Water Heater Logo
1,538 people viewed this question
Top Element Water Heaters Experts
Paul Carew
Lawrence Oravetz
richie46
Are you an Element Water Heater Expert? Answer questions, earn points and help others
