Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Oven wont heat
Hi i have a FEF365BWF frigidaire oven and it wont heat .Checked the oven sensor its fine .
  • robert samples May 11, 2010
    try the broiler see if it works does the oven light works and how about the ssurface elements
  • 6,784 Answers
This may be a control panel issue. i would also check the glow ignition as well , assuming it is a gas range.
Posted on Feb 11, 2009
My Frigidaire dual fuel oven wont get hot. Both heat elements and temperature sensor have been replaced and it still only gets warm. No error codes are displayed.
Thank you for your post, Chrissie!
I understand that your Frigidaire duel fuel oven is not heating properly. I see that you have replaced your temperature sensor and heating elements and your oven is still not working. This could be a possible issue with your control panel or wiring harness. Since it could be anyone of these underlying issues I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this is helpful information. -Matt
Jun 01, 2015 | Frigidaire Ovens
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have Frigidaire oven when I press bake it gives me F3 on the panel wont start baking, then I have heat up the surface by turning on . Then only it will work ???
For Frigidaire ovens, F3 means that there is an open somewhere in the oven temperature sensor system or the wiring between the sensor or the oven control.
Since this goes away when you heat up the surface, I suspect a wiring fault. There is probably one broken wire in the unit, The thermal expansion of the wire when the surface is heated makes the two ends of that wire make contact again.
This wiring needs to be checked and probably replaced. (If the wiring is good, then the sensor is at fault.) If the appliance is still under warranty, contact the manufacturer.
I hope this helps.
(the wiring harness has a number of wires between the sensor and the control; each one will need to be checked when the entire range is cool and the open connection is present.)
Apr 21, 2012 | Frigidaire Ovens
I have a frigidaire oven and every thing works but the oven wont light,the glow plug come on but just wont lite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Feb 12, 2011 | Frigidaire FFEW2725LB Oven
F1 and beeping sound on electric stove model FEF365BWF
Hello, the F1 and the beeping sound is as a result of the Electronic oven Control Failure (EOC), and you need to replace the electronic oven control also called the EOC or clock.
Thanks
Jun 13, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Frigidaire pleb30t9fcc double oven -- top oven heats fine --- bottom oven does not heat up all the way
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 14, 2010 | Frigidaire PLEB30T9FC Stainless Steel...
Frigidaire oven (CFEF357CS) wont heat up after small explosion - no burn signs - surface rings and display OK - oven elements test fine
Take out the bake and broil elements and have them checked appliance places will check for free.Hope this helpsHappy Thanksgiving.
Nov 25, 2009 | Ovens
Frigidaire oven F-10 error
HI. this is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
May 24, 2009 | Frigidaire FGB24S5A Gas Single Oven
Oven wont heat
check the outlet for 220 and the power cord
May 25, 2008 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
266 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
