Question about Xtreme Sound WMS6100RW 10-Disc CD Changer
Need rf modulator for wms5100 stacker - Xtreme Sound WMS6100RW 10-Disc CD Changer
  • 2 more comments
  • adoptme4now Apr 09, 2009
    yes yes yes ! how much?
  • adoptme4now Apr 10, 2009
    got a pic ? ms
    is it on ebay yet? ill check thanks ms
    just text me at 402 208-2842 and ill paypal it. thanks so much ms
  • 28 Answers
Do you need the controller or the fm modulator? I have both.
Posted on Apr 05, 2009
  • itsalthat-ho Apr 10, 2009
    No pics. It is used and works perfectly. The wiring leads have not been cut, and have the identification/location stickers still attached.$12.00 and I can put on eBay with buy it now listing.To be clear, the modulator is the "box" that the controller and changer plug into.
I have a cheverolet Lumina 2006 Car 6 CD power problem but sometimes it work I tried to solve this problem from long time, Anyone can give advice how to power it. (All the fuses checked ok).
built in australia with our commodores
2006 Chevrolet Lumina Royale
cant see any original factory 6 cd stackers for sale in Australia anywhere
better to upgrade to a better after market unit
these CD stacker units do wear out /dry solder /corrosion /diodes
is this the factory cd stacker player that came with that model
..is this unit in the boot
only thing is check all the currents volts to the stacker
make sure the stacker has an individual earth wire
Aug 06, 2016 | Cars & Trucks
Hp 9050 laser jet stacker error
Probably just a bad sensor or dirty sensor causing the issue.
Stacker or stacker/stapler output bins
For the 3,000-sheet stacker or 3,000-sheet stacker/stapler, the output bins are the upper bin (face-up) and the lower bin (face-down).
The upper bin (face-up) is the top bin on the stacker or stacker/stapler. This bin holds up to 100 sheets of paper in face-up order as they exit the printer. A sensor causes the product to stop when the bin is full. Product operation continues when you empty or reduce the amount of paper in the bin.
Lower bin (face-down) is the lower bin on the stacker or stacker/stapler. This bin holds up to 500 sheets of paper and can stack or staple jobs. This bin is the default output bin.
Aug 19, 2014 | HP Stacker For LaserJet 9040/9050/9500...
Rf meter does not work
Does the radio have any rf output? Use a swr/watt meter to check. If if doesn't have any output that would be the cause of the problem.. then its another issues..
May need some test equipment to find the fault on that one.
You could send it in to us and we can fix it.
We do not charge to look at any radio -no bench fees-..
Let me know Ill get you any info that you need.
Oct 19, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
How do i hook up a rf modle.sws2103w/17 to dvd/vcr that dont have a coax out/or in,it has red/wt/and/yel. in and out.i just have basic cable in kids room.i put coax cable to in on the rf mod,out to tv,...
buy any old vcr and use coax.cable from that as in..then use output from vcr to input for your t.v...t.v. must then be in the proper input source mode.
Oct 23, 2010 | Televison & Video
The driver seat heater just quit. all fuses are good. how do you tell if the relay is good?
Swap it with a relay you know to be good and see if it works again,pick a relay that is not important to the function of your car.
Nov 01, 2009 | 2004 Cadillac SRX
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
Extreme Sound WMS5100 user manual
WMS6100RW manual is the same, the 6100 just had mp3 capability
Apr 04, 2009 | Xtreme Sound WMS6100RW 10-Disc CD Changer
No color output from philips 751/171 dvd player
Hello.
The RF modulator sends on a certain frequernzy(Channel) usally around channel 36 on UHF. If there is a adjustmen screw on it try and turn it util the picture disapears and then search for it on the tv again just to make sure nothing else is interfearing on the channel the RF modulator is sending on now.
An alternative if there is no adjustment on your RF modulator would be to change the frequenzy on your VCR or other devices attached to your TV that might send on the same frequenzy as your RF modulator.
Regards..
/Tech5508
Feb 15, 2009 | Philips Televison & Video
I am trying to install a phillips apapter RF modular to a televison. I have no idea whether to hook it up to the cable box or the TV. To be honest am not sure where the input cords go. Phillips SWS2326W/17
Hi and welcome to FixYa,
Initially, the video (yellow) and audio (red & white) OUTPUTs of the cable box should go to the Video/Audio INPUTs of the RF Modulator. Thereafter, the TV should be set to Channel 3 (or whatever it is the RF Mod is using). This is done if and only if the TV has no A/V INPUTs and/or the cable box has no RF OUTPUT.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 14, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Some sound missing from DVD playback
plug out your dvd for about 2hrs and plug it in back then start all over.good luck.
Apr 01, 2007 | Zenith ZHX-313 System
Xtreme Sound WMS6100RW 10-Disc CD Changer Logo
121 people viewed this question
Top Xtreme Sound Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Are you a Xtreme Sound Car Audio and Video Expert? Answer questions, earn points and help others
