Question about GE Kitchen Ranges
Knob broken How can I get a knob fixed?I have an old GE stove and one of the knobs which makes the oven work has broken.thanks for your help.
  • 10,865 Answers
Go to this site and you will be able to order a new knob.
http://www.repairclinic.com/0047_13.asp
Posted on Feb 12, 2009
How do I fix the broken oven knob on my GE XL44 oven?
First you need to check the value body (around the value stem) for leaks.. you can use soapy water, your nose for smell...if you suspect a gas leak... turn the gas off to the appliance (located behind the stove) and call your gas supplier or a service tech...
You can use a thin pair of needle nose plyers to hold the stem.. or an easier way is to cut a playing card in half, poke a hole in the middle of it so it will slide over the stem... cut a line for the edge of the card to the hole so you'll be able to pull the card out from under the installed knob...
Jun 21, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
How Do I Calibrate An Old Maytag Oven
If the knob is consistently 25 degrees off from the indicated temperature the simplest and cheapest fix is to make a new indicator mark on the stove 25 degrees from the original.or some knobs have a glued on ring with the temperature numbers on them . Removing the ring and regluing it at the correct position could also work. Hope this helps.
Dec 31, 2013 | Ovens
Hello. I just received a new Glass Touch ASM (WB27T10875) for my GE stove. My previous one cracked and needed to be replaced. Problem: While installing/ connecting the ASM to the stove, once I connect the...
Funniest thing. I was having the very same problem on Monday. Every time I laid the glass touch panel down on the stove, it stopped working but worked when I held it up. After failing to install the panel so it would work for 30 minutes, I walked away from it and ate dinner. Coming back later, I decided my problem was the connections on the back side were coming into contact with the metal so I placed a tightening knob in the center of each of the outside holes making sure the underside of the knob went exactly into the middle of the hole. I then lowered the left side of the panel down to where the threads started and very carefully partially tightened the left knob so none of the panel back touched the stove. I then lowered the right side until the knob touched the knob and tightened that side finger tight. I keep testing the buttons to make sure they were still working. When the out side knobs were finger tight, I finger tightened the 2 inside knobs. Success. My oven is now working.
Aug 03, 2013 | GE GLASS TOUCH ASM WH - WB27T10873
I have a 17 year old Ge double oven electricI have one stove top burner that stopped working. I bought a new one and it doesn't work. What should I do?.
Sorry to read about your problem, I hope this helps you out.
Unless you are knowledgeable, on range repair, I suggest you call a service company.
you may have a bad control knob. defective socket or broken wire.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | GE Spectra JBP78 Electric Kitchen Range
How to use stove timer for auto oven?
See if this helps. Page 26 shows a digital clock. Even if the buttons and knobs are different on yours the procedure may be the same.
http://genet.geappliances.com/DocSearch/pdf/49-4751.PDF
Oct 21, 2009 | General Electric Stove/Oven/Range Chrome...
GE Oven won't stay lit
gas ovens have fail safe device known as a ffd flame failure device sounds like you will need a new one fitted by corgi registered fitter
Jan 11, 2009 | Kitchen Ranges
Old Eaton Viking Stove - broil won't turn off.
I have the same stove, and just had the same problem. I looked all over the internet to try to find an answer, and then went back to my stove to check the serial number and where the fuses are was the instructions printed on the stove itself.
SO HERE'S THE SOLUTION
1. The timer start knob (the one with little running guy picture) must NOT be pushed in. If it is, turn it slowly until it snaps out.
2. The timer stop knob (the one with the picture of the stop sign) must be completely pushed in.
I hope that helps everyone out!
Dec 21, 2008 | Viking Stove/Oven/Range Timer Knob -...
Display goes blank, no heat, no oven
This I hope will be an easy solution for you. I think you have a circuit breaker tripped or a fuse if you have a fuse panel.. I am guessing you have an old fuse panel. When you have a fuse blown on a 230 volt appliance and you turn a swith on (like your knob) it feeds back to other circuits on the 120 circuits and will make it do crazzzy things, like making lights and clocks work..Regardless if you have fuse or breaker you dont have the 240 volt to run the range..You only have one120 volt leg powering your stove.
Nov 03, 2008 | GE Kitchen Ranges
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Kitchen Ranges Logo
307 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
