Question about Insignia 2.0 Speaker System (2-Piece)
I have 2 Insiginia 2.0 speakers. One isn't working.
Okay, so I have the 2 piece Insignia 2.o speakers. The speaker with the volume control and power button works perfectly. However, the other one which is just attached to the main speaker doesn't work. It's done this before where it stopped working then came back moments later.
It hasn't been functioning for about a good hour now.
  • Korso55 Apr 13, 2009
    What can i do if one speaker is working and the other one is not? what are my options?
  • Stacie White Mar 20, 2012
    We purchased ours a few months ago. We had the same problem. All connections were correct and wires were attached. The green light was on and then went out too. They fizzled out. Originally the sound was good. My thoughts are you get what you paid for them.
  • 11,896 Answers
Most likely a short in the wiring. Either on the speaker, or a short in the plugin jack.
Posted on Feb 11, 2009
No audio working
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Sep 22, 2011 | Insignia 2.1 Speaker System (3-Piece)
Cant hear sounds
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 07, 2010 | Insignia 2.1 Speaker System (3-Piece)
My speakers are not working.
drivers might have been corrupted or you might have the wrong speakers selected
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 25, 2010 | Insignia 2.1 Speaker System (3-Piece)
My speakers (insignia) are not putting out sound and windows is telling me they have no audio device. but, my speakers are plugged in and have power.
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 01, 2010 | Insignia 2.1 Speaker System (3-Piece)
MY OLD INSIGNIA SPEAKERS (WITHA SUB-WOOFER) WENT UP SO I GOT A SIMPLE 2 SPEAKER INSIGNIA 2.0 POWERED SPEAKERS. NOW I CANT GET ANY SOUND. ANY THOUGHTS?
1. Try looking in the taskbar of the Windows screen and selecting the volume control ( a speaker icon) check the mixer see if the volume is not muted or in the "0" position
2.Check the "input port on the sound card where you connected the new speaker assembly.
3. Check the volume control knob on the speaker assembly to see if it is not in the off or lowest volume position.
4. Check the new speaker by connecting them to another computer that has the sound already on and working this will let you know that the speaker assembly is good.
6. check the sound card drivers to the internal sound card that is on the mother board if this is where your sound card is located. Use the "manager" to see if it is working properly. If not then do a "reinstall of the sound card drivers or use the "update feature in the hardware window for the sound card to install the latest version of sound card drivers.
I hope this helps. Have a great day!
Sep 25, 2010 | Insignia 2.0 Speaker System (2-Piece)
No sound
If you know your speakers are working and there is nothing wrong with them go on your computer and go to sound settings in control panel and adjust treble bass and volume.
May 30, 2010 | Insignia 2.0 Speaker System (2-Piece)
Low volume sound
your better check the volume control of your computer....i mean the vol contrl on the start menu-accessories........
Feb 02, 2010 | Insignia 2.1 Speaker System (3-Piece)
My speakers are not making any sound... I recently reinstalled windows and they doesn't work anymore... How can I make them work? I Have windows xp
I am assuming these are speakers connected to the audio connection of your PC or the USB
Are you sure the audio is not on mute. Look for the speaker icon in the bottom right of your windows screen. If it has a red line across it. Right click the mouse on it and make sure the mute button is unticked in the volume control panel.
Also try to check if the volume levels are ok. In case you have got a separate power adaptor then use it instead of relying on the USB power.
Nov 16, 2009 | Insignia 2.0 Speaker System (2-Piece)
My speakers won't work
check the volume on the computer and also to speaker it self.....
Jan 21, 2009 | Insignia 2.0 Speaker System (2-Piece)
Insignia 2.0 Speaker System (2-Piece) Logo
386 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
