Question about HP Pavilion F1703 17" LCD Monitor
How do you remove the back or open an HPf1903 monitor?
Lots of board entries telling how to possibly fix monitor problems (specifically f170 and f1903 HP), but no mention how to open them up to actually look & check for possible fix. (or take to a tech shop)
Can someone please provide info on what the trick is to get the monitor back off or open in order to look at the inside?
The manual guide/book does not include this instruction or method, or show a schematic.
I have removed the screws on mine as well as stand, but cannot figure out how to open it up to look at. I do not want to force anything or crack the brittle type of plastic case that is part of the monitor, and cannot find any catches, releases, or buttons to release the front.
Thanks!
  • useHPmost Feb 12, 2009
    Thanks for the reply, but the F1903 is an HP 19" Standalone Monitor, not a laptop. The problem is that even when base and backing screws are removed, it does not separate or open or slide, in order to repair or even look at inside.
    Don't want to "Force it open and break something doing it, as there must be an easy release & opening method. However the monitor manual does not show such or even provide schematics to help.
    And HP is no help, except to tell you to take it to a certified HP repair place. I did and they wanted $85 just to look at it before doing anything. That's almost the cost of buying a new one, and without guarantee it won't be more or how long the fix will work!
  • 170 Answers
Http://www.instructables.com/id/How-to-Take-Apart-a-Laptop/
Posted on Feb 11, 2009
HP Pavilion F1903 flat screen monitor dimmer with grey lines
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Hp pavilion f1930 shows pic for 2 secs. then blank
Rather than guessing, or blaming the computer, I fix the F1903 backlight problem. Power the monitor and using a bright flashlight check the screen to ensure there's an image, or the menu when you press the menu button. Nearly every one of the F1703 and F1903 monitors I've repaired have all been backlight issues. If you have an image proceed with these instructions. This is a repair for those people competent in component level electronics repair with good soldering skills. Items needed, Crosstip screwdrivers, fine tipped soldering pencil, fresh rosin core solder, (4) "2SC5706" or "C5706" Transistors. Remove the 4 screws holding the base, set the base aside. Lay the monitor face down on a surface that won't damage the screen or Bezel. Remove the 4 screws holding the back on.Carefully pry the back away from the bezel. Be careful in doing this because the display controls are attached to the bezelremove the 4 screws holding the control board on. Turn Monitor face up, remove bezel. With the Monitor Face up remove the Machine screws around the edge of the case. Carefully place the monitor face down again without having the LCD fall out of the Monitor frame. Peel the foil Tape back on one end of the frame and using small pliers, unplug the 4 CCFL plugs (these go to the 4 lamps, I believe you have to remove the VGA and DVI connector Hex socket screws and screws around the power input. Carefully lift the back up and unplug the LCD, you'll have to remove the adhesive backed ribbon cable retainer. Set the LCD somewhere safe.The board with the 4 CCFL plug sockets is the Inverter board, unplug it fomr the Logic board, Remove the screws holfding it in as well as the 2 plastic clips (Squeeze these one at a tim with needle nosed pliers while gently lifting the board up.set the Monitor fram aside as you're going to focus on the inverter board. Using a LIGHTED magnifier, look for cold solderjoints, dull gray and pitted looking. One by one remove the solder with a desoldering braid (I mark the board with a sharpie pen to remember where all of the questionable joints are.) Using a fine tipped soldering pencil REMOVE the solder and replace with fresh rosin core solder. Be VERY careful not to disturb any of the surface mount components on the board. There are 2 large gray boxy looking capacitors with 2 transistors around each one. Check the solder connections there carefully on the capacitors. Look for signs of arcing, blackened spots or overheated circuit board. The 4 transistors in this area are (2S)C5706, replace them all, they're about a dollar apiece on EBAY, I would NOT recommend using a "SK or EGC Equivilent". Once the transistors are replaced, reassemble the monitor, up to the point of where you put the plastic case back on. with the monitor face up, plug in power and a signal cable form the computer and carefull press the power button on the Control board, the monitor should work. This is the most common fault with this monitor, if it doesn't work, go back and check all of the solder joints and resolder any you may have missed. Once the monitor works again, reassemble the plastics onto the frame, attach the base. I hope this helps, I can't promise this will resolve the issue every time, but it has in virtually every one of this model I've repaired. This repair helps the "no backlight or comes on then goes dark" problems. Randy L. Bray
Mar 29, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
I want to replace the power switch board on my hp vs19e monitor.
About your only hope for getting a replacement switch is to buy a "Parts Only" monitor off of EBay and carefully remove the switch. This one is tricky it's attached to the front bezel as you've likely found out. When you disassemble the monitor, lay it face down and remove the bac plastic then remove the 4 screws holding the button board on then take the rest apart. That's the safest way.
Mar 28, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Hp vs17e monitor says it's in sleep mode then goes blank
check the board postings for the HP f1903 monitor.I recall seeing a problem of the same there and a solution or fix. As it is only a newer version of the same model, it may be the same fix. Appears HP has a big problem with QA and this particular model. Lots of people have same or similar problems, and all appear to have a similar fix or solution. Tricky part... figuring out how to "Open" the monitor to check it inside!
Good Luck.
PS - if you figure out the opening part, let us all know!
Feb 02, 2009 | HP Pavilion F1703 17" LCD Monitor
Hp 1703 Video for 1second then Black but can see it but wery dark
sorry, not really a solution, but may help point you in right direction. I have similar or same problem with my monitor but is an f1903 (HP). I recommend you look at the f1903 board postings to see those answers. Several seem identical for fixes and fix may possibly be cheap, but unfortunately noone has posted how to open the monitor up to actually check it inside. This is the tricky part, as seems no catches or buttons are present and removing back screws do not let the monitor case open without some type of special trick or move. If you figure it out, please tell us all! Thanks
Jan 30, 2009 | HP Pavilion F1703 17" LCD Monitor
HP F1930 Capacitors
This is how I learned to open my f1703hp monitor not sure if f1903 hp is the same...I got my open and going to replace power board waiting for the mail LOL.
http://www.fixya.com/support/t862133-open_f1703
Jan 20, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Hp pavillion f1903
It has a bad capaitors in it open it up look for bulged capacitors replace all bad ones and it will run again i fixed more hps with this problem than any other and it doesn't cost much to fix its under $10.00 thank you have a nice day
Jan 12, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1903 monitor
sure the F1903
is a LCD monitor but is old , it has
and CCFL black lamp.
it has board inside that is the power supply /inverter
this board runs the lamps.
the lamps love to fail after 10 long year of service
so when monitor fails, push the menu botton on the front
is the OSD menu dead (monitor brains inside)???
see bottom of this page , see CCFL and PCB there?
if lamps bad replace them
if PCB bad replace it, seen sold on Ebay , vastly, there.
http://pcdied.com/black-screen.html#CCFL-examples
some of these old monitors.
have silly internal sleep mode,
turn that off. (push menu button on front)
see OSD (on screen,display menus)
see settings
see power saver mode, turn it OFF,
Jul 28, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
MY HP PAvilion F1903 19 " gone black blank
Problem is generally dry solder joints around the inverter transformer on the inverter PCB.
Feb 16, 2008 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
157 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
