Question about Logitech R-20 Computer Speakers
I can't figure out how to set up either of 2 speakers that I own
Both were working, but my 2 computers had to go into the computer and now I cannot get them working, I am sure that I am doing something wrong.
Even a diagram would help.
(1) Logitech R20 Nidek S-0153A has one plug going into a larger box, 2 speakers and only one green button to hook into the computer.
(2) I also want to hook up a mike, but it does not work either. Labtec AM-242 NCAT
(3)Monsoon Multimedia MH-500. Has 2 round ports that you hook up the left and the right ones (marked for each) It has a DC 125 V (22A). There is a female end for a male unit to fit into and a plug. There is a yellow female end for the male unit to fit into, but nothing that goes to the computer.
  • dbell4444 Feb 14, 2009
    I could not find a manual, but did find an email site that allows me to ask questions for which I am hopeful of getting an answer or even a HOW TO diagram.
    Thank you for taking the time to reply, that was great that you took the time and it is much appreciated.
    Feb. 14, 2009
    Brigadier General:
  • 5,158 Answers
Not sure if you have looked here for the manual... but you may be able to find it on this site,en?prodcrid=409
please take a moment to rate this solution thanks
Posted on Feb 11, 2009
Not working Dell A225 2 Speakers
Try the speakers on a different computer.
Try a borrowed set of speakers on your computer.
Go to any "Thrift Store" and pay $5 to $10 to replace the speakers.
Feb 02, 2014 | Dell A225 2 Speakers
I have an apple all in one computer. When radio shack set it up they put a password on it. I know it was simple but I don't remember what it was as the computer has been in storage for a while
Only 2 viable options, contact Radio Shack and have them figure it out or take a OSX DVD install disc and install the Operating System again. Unfortunately this is pre- 2012 Macs, after 2012 all Macs require a trip to Apple to reset the password from what I can recall...
Nov 10, 2012 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
Do s-150 usb digital speakers work for mac?
Hi, I had this problem too but thankfully I figured it out after a investigating a few settings. I was very frustrated because the light came on and the buttons would manipulate my MacBook Pro and MacBook sound, but nothing came out of the speakers. Solution:1.) Click on System Preferences, 2.) Choose "Sound", 3.) Select the "Output" button in the middle of the top bar, 4.) in the selectable menu, choose USB (of course your speakers must be plugged in for this to show). Tada! You can even balance the Left and Right speakers in this menu. Hope that works for you too!
Jul 29, 2012 | Logitech S150 2 Speakers
Dell A425 2 speakers not working. Computer setup was moved across a room. Everything was reconnected exactly as before; all connections and settings have been checked and re-checked. Nothing is muted. It...
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Feb 14, 2011 | Dell ADA425 2 Speakers
I recently needed to reboot my computer back to factory setting due to what I figure was a virus now my speakers won't work. I have speakers labeled Logitech X-530 do I need a disk to add this as new...
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 07, 2010 | Logitech X-530 Computer Speakers
Speakers not working - PS2 plug has come out
Honestly, if they are packard bell speakers they are 1. old, 2. may have a propritery connection that is no longer found. A new set of speakers will only cost $20 at walmart, might be easier to just invest in a new set!
Oct 04, 2009 | Packard Bell Speaker Computer Speakers
Only 2 of my 5 speakers are working. I have
Make sure u have the latest Sound Drivers installed and that in Control Panel, Sound, Speaker Settings u selected 5 speaker output.. Default it s 2.
Aug 07, 2009 | Logitech X-530 Computer Speakers
Need home theater hooked to TV with built in DVD
This is the easiest way 2 explain it. Hook up on the home theater should be labeled in and out. same as on the tv. The TV might no have that feature as the DVD is built in. You might just have an option for sound from the TV/DVD to the home theater. Again OUT from TV IN to receiver. Same with any other device set up.
Jan 27, 2009 | Durabrand 5.1 Surround Sound Computer...
Hooking up logitech surround sound to tv.
you need a "y" cable to bridge the output of the tv to the speakers.
Godd Luck
Jan 21, 2009 | Logitech X-540 Computer Speakers
My speakers don't work
Good day!
I figure is a 5.1 speakers? if so, tell me if your sound card model is one for 5.1 speakers. then according to manual for set speakers on the Logitech, you put the cables, usually
Green, Black, Orange and Blue. for Mic.
then test on the sound card program for sound test.
Good Luck
Nov 18, 2007 | Logitech S200 Computer Speakers
Logitech R-20 Computer Speakers Logo
500 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
