No remote for set-up
When power comes on for vcr srceen is all blue and says auto set-up [set]enter which appears to be only on the remote i do not have only buttons on vcr are power play rec stop/eject FF REW pause channel up/down i set up my brighthouse remote to my vcr but no buttons sets it up
  • 11,896 Answers
You should purchase a universal remote.
Posted on Feb 11, 2009
How do I set the clock on a fisher fvh-7600 vcr I do not have a owners manual
Also having no manual for a Fisher FVH-7600, I eventually guessed how to set the clock after finding a remote control (Fisher RVR-7600) that works with it.
With the TV and VCR connected and powered on, the TV set to channel 3, and the remote's FUNCTION switch and VCR/TV button both set to VCR, I see a blank blue TV screen.
Then I press the PROG. button on the remote, and a menu with instructions appears on the TV screen. CLOCK SETTING is item 1 on that menu.
Sep 23, 2014 | Televison & Video
I have apex dt-250a digital converter box and I lost the remote. Purchased RCA universal remote and I have not a clue what codes I need or how to enter them. Can you help?
I programmed a Radio Shack 5-in-one remote to my Apex DT-250. Select cabel/satelite, hold p until the light blinks twice, then enter the code 0749. It works! If your universal remote uses a three digit code, use 749. If it uses a five digit code, use 00749. I HAVE A PROBLEM THOUGH... I don't know how to scan for channels! It says "please do auto channel search", but how do I do that? Please, if anyone has this answer, let me know. I finally programmed the universal remote, but it's basically useless without being able to do an auto channel search.
Jan 31, 2011 | RCA Televison & Video
I have an auvio 15-304 remote that I am trying to program to my gpx DVD player and can't remember how because there is no code for the DVD player brand.
i have an Auvio 15-305, so this might help. Manual Code Search.
1) Power on the device that you want to control. For VCR and DVD players, you must insert a tape or disc first.
2) Press and hold SET, then press (TV, VCR/DVD, AUD, DVR,SAT/CBL, AUX) at the same time on the remote. The LED will stay lit indicating it is on setup mode. NOTE: DO NOT HOLD DOWN THE KEYS MORE THAN 3 SECONDS OR THE REMOTE ENTERS AUTO SEARCH MODE.
3) Press POWER on the remote. The remote enters a manual code search mode, the LED will start flashing.
4) Press POWER on the remote continuously until the device turns off.
5) When it turns off, turn on the device manually. then try pressing the other buttons on the remote except for the POWER, SET, and DEVICE keys.
If most of the buttons work then press the selected DEVICE key that you selected in Step 2.
i hope this helps.
Dec 02, 2010 | Televison & Video
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Need 4 digit code forsylvania tv dvd combo model ld195sl8a
Unfortunately, your remote control predates TV/DVD combos and as such the manual does not list a code for a Sylvania TV/DVD combos.
To make this control work with a TV/VCR combo, one would enter 0054 for the TV controls and 0081 for the VCR controls. May I suggest you try the following codes for the TV: 0054, 0030, 0096, 0020, 0381. If these codes do not work, try running through the auto-code search.
The manual for the URC-4330 does not list any Sylvania DVD codes at all, so I recommend running through the auto-code search. Here are the steps:
  1. On the remote control, press DVD once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the DVD and slowly alternate between pressing POWER and DVD. Stop when the DVD turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Oct 15, 2009 | One For All URC-4330 Remote Control
What sequence do I use to punch in codes 4 a VCR,start to finish?
1. Press the "DVD/VCR" button on the remote.
2. Press and hold the "SET" button on the remote until the red LED blinks twice, then release the button.
3. Enter the 4 digit code for the VCR. (Red LED should blink twice after you enter the code.)
4. Aim the remote at the VCR and press power. The VCR should turn on. If not, try another code until you find the right one.
Oct 07, 2009 | One For All URC-3021 Remote Control
How to select the correct device in drop-down box when programing
Sony Home Theater System - 'Mini System' Samsung Blue-Ray DVD Player - 'DVD' VCR Orion - 'VCR'
No matter what you enter the devices as, the software will determine what it actually is and set the type.
Hope that helps.
Jan 13, 2009 | Logitech Harmony 520 LCD Remote Control
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
I can't get my cable to run through my sanyo vhr 5428 to display
You can't press enter without the remote. Your only hope is to go on eBay and search for the very same remote control. Be patient and check for a couple of weeks if you have to. Especially now that it's Christmas a lot of people will be selling their old remotes on eBay.
Dec 24, 2008 | Sanyo VHR-5428 VHS VCR
Quasar vhq41m
Hi , set remote to auto program set enter /on sreeen will appera then stop if no channel appear ,then select channel.
Jan 21, 2008 | Quasar VHQ400 VHS VCR
Televison & Video Logo
172 people viewed this question
Top Televison & Video Experts
Electro Med Services...
