Pioneer VSX-D308. Unit goes to "muting" and no audio. Seems to be a common problem from internet questions. I have a repair manual and have checked voltages and muting transistors. Can insert audio to final power amps and get sound but middle drivers won't pass audio and display jumps to muting. Preamp section has audio also using signal tracer Seems to lose it at the tone control IC. I don't mind paying for assistance that is correct but don't need any guesses!
  • 2 more comments
  • jmobley947 Feb 12, 2009
    welcomejee has requested service manual but I have no e-mail addrees to send it...help me out
    For welcomejee, please give me an e-mail address to send the manual. I have the 5 volts and data to chip...what else?
    Pioneer VSX-D308. Unit goes to "muting" and no audio. Seems to be a common problem from internet questions. I have a repair manual and have checked voltages and muting transistors. Can insert audio to final power amps and get sound but middle drivers won't pass audio and display jumps to muting. Preamp section has audio also using signal tracer Seems to lose it at the tone control IC. I don't mind paying for assistance that is correct but don't need any guesses! I have 5 volts and data to chip. I can send manual if given an e-mail address to send it to!
    All driver and output chips are new. All necessary voltages are present.
  • 4,234 Answers
There are a number of possibilities here. Check the voltages at the tone control IC. If there is no supply there, the signal will stop. Also, verify that the voltage regulator ICs have correct voltages as well. The next step is to determine whether the muting transistors are being told to mute or not. You should see a mute line on the micro. I don't have the manual with me so I don't know if that line is high or low, but the manual should indicate which.
Let me know the results and we'll continue from there.
Thanks,
Dan
Posted on Feb 12, 2009
  • ABRsvcs Feb 12, 2009
    Just spoke with a buddy of mine at a Pioneer service center. If you have the remote, hit the mute button. There is no provision for this on the front panel, but the unit might have gotten confused at one point. Let me know if that clears it. Other than that I will get the service manual and check for you.
    Dan
  • 10,594 Answers
You need to pay attention on system control power supply ( +5 V ), Serial Clock and Serial data signal amplitude should be as per service manual in system control and DSP (digital sound processore)
I do not have Pioneer VSX-D308 service manual and if you can email me that service manual then I can help you out more precisely.
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Feb 12, 2009
    welcomejee at yahoo.com
    Please forward service manual on above email address.
    thanks.
    Shahid Electronics Feb 15, 2009
    Hi Jmobley,
    Thanks for forwarding service manual. I'll get back to you shortly with possible suggestions and solution.
    Based on your comments [ Can insert audio to final power amps and get sound but middle drivers
    also using signal tracer Seems to lose it at the tone control IC.]
    Please confirm output with signal tester at IC207 pin 1 & 7, found OK then pin 5 & 3 as inputs, found signal then go back to IC202 pin 2 (L in) and 19 (R in) Please make sure to test supply voltage at pin 20 (9 V) and pin 1 (4.6V) with DVM
    IC206 (44Khz Low Pass Filter) should have +12 V at pin 8 and -12 V at pin 4
    Let me know results so move forward if all above is clear.
    Thanks.
  • 153 Answers
It might be the panel buttons problem
  • nicra7 Feb 12, 2009
    check for the buttons in panel i got this trouble and changed the panel in tat now its perfect
    Master:
  • 848 Answers
Hi
you need to explore the output protection circuit ( relay, fuse ,electronic switch) and find out the bad amp(s) and replace the output transistors or modules (mounted on the big heatsink.) . The repair is expensive ....rate this solution as fixya if it is helpful....
VSX-D308 Pioneer Receiver
You most likely have a shorted amp IC.
May 04, 2013 | Audio Players & Recorders
I have a Pioneer VSX-D308 reciever and I have... no idea how to hook it up to my big TV (bought receiver used). Do I need the red/white cords? Do I need other cables? HELP! Wanting to hook up to big...
What your unidentified TV >>requires<< is the BEST Video from every video source. That would be the DVD, SAT Box. It probably has multiple high-end video inputs, right?
What your receiver needs is at least a basic composite video connection to the TV so you can set it up and manage it.
A web search for "Pioneer VSX-D308 manual" will find the manual.
ALL of the BEST Audio should go directly to the Pioneer. That includes the SAT and DVD player.
Your TV can exist just fine with basic audio from the video sources. And you could still watch it/them without the Pioneer turned of if you want.
I can't find the exact manual for free anywhere but if you download something similar like http://www.retrevo.com/support/Pioneer-VSX-D409-Receivers-manual/id/385ci977/t/2/ it should give you the basic guidance you need.
I recommend
Do some web searching for what the cables are for. It's all basic and standard.
Sep 07, 2011 | Pioneer VSX-D308 Receiver
My Pioneer vsx-d308 keeps giving me an "overload" message and will not work
Do you guys know how to turn up front speakers on this amp????
Sep 02, 2010 | Pioneer VSX-D308 Receiver
Pioneer Elite vsx-27tx receiver with no bass!?
There may be a subwoofer mute function on your amp. The sub out is nothing more than a preamp output with a low frequency response. It is meant to be amplified by an external amp. Either check your powered subwoofer for operation or look through your operators manual for a sub mute function.
Feb 11, 2010 | Pioneer VSX-27TX Receiver
Standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Jun 14, 2008 | Pioneer VSX-D308 Receiver
Need an manual
Go to http;//audio.manualsonline.com maybe there you find the answer good luck
Jun 12, 2008 | Pioneer VSX-D308 Receiver
Pioneer VSX-D308 Receiver Problem
go through your mode channels to put it on surround sound
Jun 09, 2008 | Pioneer VSX-D308 Receiver
VSX-D308
Maybe the audio amplifier IC is damaged and you gotta change it.Good luck.
May 26, 2008 | Pioneer VSX-D308 Receiver
Pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Oct 04, 2007 | Pioneer VSX-D307 Receiver
115 people viewed this question
 Grubhead
Grubhead
