Question about RCA F27252GY 27" TV
RCA model F27252GY TV has no Video button or AUX channel for DVD
The back of the set has the 3 RCA input plugs matching the output of the DVD player but there is no "VIDEO" button on the remote or on the set. How do I use an alternate input device? There is no AUX channel either.
  • 2 more comments
  • jgeorge102 Feb 11, 2009
    I have the original remote. There is a DVD/AUX button on the remote but it does nothing. I just changed the batteries and tried it again.
  • May 11, 2010
    There should be a button on the remote that says "INPUT". That's the one that switches to the A/V inputs. Let me know if that takes care of the problem.
  • May 11, 2010
    Do you have the original remote control, or are you using a universal replacement?
Try putting the tv on channel 00, that is where this tv apparently shows the input from at least one on the video channels.
Nancy
Posted on Mar 01, 2009
I used a universal remote and I just held the TV button and pushed "00." Worked perfectly.
Posted on Apr 03, 2009
I have a 42" Hannspree TV. What channel do I put
h;
your DVD player has an output of Audio and Video, and at the back of your TV has and input A/V
you have to connect a RCA cable to this inputs, your RCA must have 3 connectors yellow for video,red for left channel audio white for right channel audio,
then set your TV to AV1 if connect it to AV input 1,there are two AV input at the back,and also SVideo input,
you have to set it by pressing INPUT or TV on remote or button of your TV.
Sep 03, 2011 | Televison & Video
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
Jun 28, 2011 | RCA DRC8300N DVD Recorder/VCR
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
RCA TV model F27252GY. Don't think I have original remote. Need to set to input or video channel to use my new DVD. How do I do this?
You can try channeling up or down to get to channel 99.Rca in the past has used this to get to the video input. If this does not work you can buy a universal remote. In most cases, after programming the universal remote the major functions such as channel select, volume control and input select will work.
I hope this helps.
Skyassoc
Dec 12, 2010 | RCA F27252GY 27" TV
How to hook up dvd player to tv
You need an RF modulator to convert the A/V output (RCA jacks) of the DVD player into a Coaxial cable you can plug into the back of your TV. I'm including a link to one at radioshack.com. This one costs $27.49. You might be able to find a cheaper one at a discount store. You can also use an old VCR if you have one to do this conversion but the connections get a little bit tricky. Plug the A/V outputs of the DVD player into the A/V inputs of the VCR. You'll have to set up the VCR so it knows to use the A/V inputs. Some VCRs have and AUX setting for this. Then connect a coaxial cable from the VCR output to the TV input. You'll have to setup the VCR to send it output to a specific TV channel, usually channel 3 or 4. Then you'll have to set your TV to that channel.
http://www.radioshack.com/product/index.jsp?productId=2103095
May 21, 2009 | RCA Televison & Video
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Magnavox MWR10D6 can't record from camcorder wrong channel
OK...try this...plug your RCA cables from your camcorder into the RCA input jacks on the back of the recorder. If you have a VCR, it can be plugged into the coax input on the back of the recorder. Use the coax output and plug it into a RF modulator (about $20 at Wal Mart). Plug the RCA output cables from the recorder into the RF modulator as well (Don't ask me why, but it seems to work on mine). Connect a coax cable from the RF modulator to the TV. Make sure the TV and Recorder are both on the right channel. The RF modulator will have a channel switch to use channel 3 or 4 on the TV. Make sure the recorder is set to E1 (Rear). You can check this with the channel +/- buttons on the bottom right of the remote. Good luck.
Jan 06, 2008 | Philips Magnavox MWR10D6 DVD Recorder
No display
Press the DVD button on the Philips remote. Make sure the yellow part of the RCA cable is plugged into Output/CVBS/Out on the back of the Philips, and that it is plugged into a yellow input of your TV. Change your TV channel to Av1, av2, video 1, video 2, aux, aux 2, or whatever the correct video channel is on your TV. Then press setup - you will get your picture.
In order for the coax connection to work on Ch. 3 of your TV, you will have to get an additional piece of equipment - an RF modulator. It's better just to stick with the RCA red, yellow, white cables.
Sep 02, 2007 | Philips DVDR3455H/37B
RCA F27252GY 27" TV Logo
1,720 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
