Question about Kodak EasyShare C533 Digital Camera
Light turns green then red
new batteries wo'nt turn on when red light goes of.
  • 11,896 Answers
Try using without memory card. Bad memory card will prevent this form happening. Also a dirt particle may have gootten on the zoom and it got jammed when it closed in.
Posted on Feb 11, 2009
I have a philips 42" plasma t.v.model
hello sir Dave!!!
welcome to fixya..
Lets find out if that problem is worth to repair or not..I need some info regarding your TV such as how many flash of LED lights in front?..It will help to diagnose where the fault came from..
Please reply to this tread to post the info I need..
Thanks for using fixya..
regards,
Chester
Feb 24, 2012 | Philips Magnavox 42MF521D/37 Television
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
Turn ps3 on light goes green then flashes blue then back to red
PS3 turn on goes green then flashing red is not a new issue. Please read this post and you can find the solution :
PS3 Red Light Blinking Fix
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
I have a Sanyo T700 camera. Just got a new battery off Ebay. I inserted it inside the camera and a red light came on. Does that mean the battery is charging or does a green light mean that its...
The manual says that a red light is a charging error. Green means it is charging and the light goes out when charging is complete.
The camera must be turned off when charging the battery. They recommend a full 8 hour charge for a new battery, then allow it to discharge completely (leave the camera on I guess) and charge it again "before use".
You can download the manual from this page. Select the "Resources" tab.
Nov 05, 2010 | Sanyo Xacti VPC-T700 Digital Camera
Wo nt come onmy son pressed the ac power button while i was installing a sky hd box and now it wo nt come on
Hi i haven't had this problem before but i can try to help but i cant guarantee it will work.
First of all i would try turning it off and unplugging it by the switch for 30 minutes making sure you remove the card.
Then i would turn it back on and try from there.
If it still doesnt work i would try changing the fuse and if still no luck you have no choice but to ring sky because your box might have blew something inside it.
Hope this helps :)
Carl Redding
Jul 05, 2010 | Televison & Video
Sonny ericsson880i,phone wont switch on,red light flashes?
This is a common issue with SE phones. You will need to take the phone to a reputable mobile phone engineer or SE Service Point to get the firmware re-flashed
May 21, 2010 | Sony Ericsson W880i Walkman Smartphone
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Will not flash red/green
This means Battery is low to charge the capacitor.
I suggest you test this with unused new Duracell.
Oct 06, 2008 | Vivitar 285HV Flash
Green light goes to red
What type of new batteries did u put, same as original ?
Oct 03, 2007 | Kodak EasyShare C340 Digital Camera
Kodak EasyShare C533 Digital Camera Logo
261 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
