Question about Dell Dimension 4550 PC Desktop
No pci simple communications controller driver
Please help
  • wasikk58 Feb 12, 2009
    thanks it worked fine
    Scholar:
  • 75 Answers
you will need to install the modem driver please check the model no and the modem that you have on the system, select appropriate os and download the appropriate driver from dell support site. Dell support
If you can figure out which modem is in your system and you haven't ever replaced it please call Dell tech support and provide your system service tag they will be able to help you with this aslo you can check your system configuration on the site itself if you have the service tag ready. check dell system configuration
enter the service tag and check under original system configuration will be listed as MDM
Posted on Feb 11, 2009
Hp nc6400 PCI Simple communication controller required please.....also unknown device driver???
The PCI simple communication controller is probably bluetooth or modem. Also install the Texas Instruments Media Card Reader driver. All the drivers for this model are (CLICK HERE)
Apr 18, 2011 | Computers & Internet
Drivers for pci simple communication controller for toshiba
Check out the Toshiba Support Site.
Select your Toshiba model to download the require drivers.
PCI simple communication controller - ie the 56K internal modem drivers.
Hope it helps.
Mar 23, 2011 | Computers & Internet
Description: PCI Simple Communications
Hello sainz_pm,
This Driver Detective site might be able to help:
http://www.driver-fix.com/updatedrivers.php?t=Pci%20Communication%20Controller%20Download
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jan 28, 2010 | Gateway BCM94306MP Network Adapter
I cannot use internet for my modem driver has ? i need driver for pci simple communication controller. please help me.. so that i could use internet again. i'm using windows xp.
Look for the brand name of your modem and model. You can find it in the box of the modem. If you have it then go to there website in the internet and download there the driver.
Nov 29, 2009 | SimpleTech SimpleStation (STI-PNPR/PCI) PC...
Asus EN7200GS
PCI simple Communication controller refers to a modem which is installed in your computer but with no driver installed.
Here is the web address for your graphics card:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Regards,
Graemevm
Apr 20, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Motherboard Simple PCI Communications Driver Code 28 for modem
Hello, Mike.
In case you still need this:
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware.
Hope this helps.
Mar 29, 2009 | Gigabyte GA-7VA Motherboard
Pci simple communications controller
i cannot get the sound from the TV tunercard as the PCI simple communications controller in the device manager is showing yellow question mark
Feb 21, 2008 | EliteGroup 741GX-M Motherboard
PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Dec 07, 2007 | Gigabyte GA-7VT600 1394 Motherboard
Dell Dimension 4550 PC Desktop Logo
941 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
