Question about RCA CDRW121 2-Disc CD Recorder
CD trays will not open.
The screens says open but the tray does not open. I have tried different outlets, but still the same result. I was recording with a CD digital audio disc and it did not finish finalizing (it took 15 minutes for a 10 minute recording and it did not complete the finalization process).
Use a paper clip. If you push a wire in the holes of each tray it will release the trays. The proper holes look like little dashes on the face of each tray, one end or the other.
Posted on Mar 20, 2009
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Tray error on a denon dn 4000
The cd transport is up the swanny (broken , kaput).
take it to your nearest registered denon repair/service centre
Sep 05, 2012 | Audio Players & Recorders
The tray will not open/eject on either deck; it tries to open but just says TOC no disk.
I have the same problem with both trays on a Sony RCD-W3 not ejecting. If you push the tray sometimes it opens, but takes a few attempts. the recording CD sometimes doesn't see the disk but ejecting and re-entering it normally gets around that. I have no permanent solution, I'm afraid. Probably needs to be opened up and rails greased/oiled or something like that.
Aug 31, 2010 | Sony RCD-W1 2-Disc CD Recorder
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
I cant open my cd tray on my tascam dp01
Look on the front of the CD tray for a little hole... push the end of a paper clip in the hole and the tray should open.
Dec 12, 2009 | Tascam DP01 All-In-One Recording Package...
I put a blank CD into the tray to record. It
If there is a tiny hole somewhere near the tray you need to poke a needle or something like that in there to open the tray.
Dec 02, 2009 | Philips CDR785 3-Disc CD Recorder
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
Disk Tray
  1. Ensure the child lock feature is disabled.
  2. IMPORTANT: If necessary, consult the instruction manual for specific steps about how to disable the child lock feature.
  3. Attempt to open the disc tray.
  4. If the issue is not resolved, turn off the DVD player.
  5. Unplug the power cord from the electrical outlet for 30 seconds.
  6. Plug the power cord back into the electrical outlet.
  7. Attempt to open the disc tray.
  8. If the disc tray still does not open, simultaneously press the POWER+STOP+EJECT buttons; this will sometimes cause the disc tray to open.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
see this
Sergio
Mar 29, 2008 | Sony RDR-HX825 DVD Recorder/HDD Recorder
TDK DA 3826 disc tray not functioning
Is the motor spinning to try to open the drawer?Can you hear it? Can you get something under the tray edge to try to 'help' it out when pressing eject?
Jan 05, 2008 | TDK DA-3826 2-Disc CD Recorder
Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Sep 18, 2007 | Philips CDR795 2-Disc CD Recorder
RCA CDRW121 2-Disc CD Recorder Logo
255 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
